How long do you think till this thing blows up?
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    A customer brought in his computer because it wasn't working properly and had viruses. Even if it's unrelated I always look at the power supply first, and when I saw that LC in the model number, naturally reacted "oh shit...."
    But anyways, I fixed the no boot issue and viruses. I then called him and told him I highly recommend he get a new power supply because the one he had was probably going to blow up soon. He insisted that the one he had was fine and that he "just bought it new and installed it 3 weeks ago" Well....not exactly brand new and the warranty sticker was already broken which is why I took some pics. Besides the normal horrible build quality the main thing I'm worried about is it only has a Mospec 10A fast recovery rectifier on the 12V......The rest is a 16A fast recovery for 3.3V, 30A schottky for 5V, two C4106 switchers. YC and Jun Fu caps
    It has to power:
    Pentium 4 S478 3.2/512/800 (82W TDP)
    4 sticks of DDR 400
    Asus P4G800-V motherboard
    2 DVD drives
    1 IDE HDD, 1 SATA HDD
    AGP GeForce 6200 256MB video card
    1 floppy drive, 1 external card reader
    3 PCI cards
    120MM Fan
    Do you think this thing will fail soon? I think it will....since it's an old system it works pretty hard in Windows 7 and that CPU usage is usually very high. if anything the ripple is going to be high, the caps will fail and that poor 10 year old motherboard is going to get stressed pretty hard...
  • dmill89
    • Dec 2011
    • 2534
    Re: How long do you think till this thing blows up?
    Oh Dear, another Deer (L&C).
    I wouldn't expect it to last long at all. At best it will run really hot and kill the caps fast, at worst it will fail in a spectacular fashion and take everything else with it. The 10A fast recovery on the 12V rail is of particular concern. An 82W TDP CPU will draw nearly 7A by itself at 100% load, throw in a video card, motherboard, drives, etc. and the 12V rail is likely at max load or overloaded most of the time. It may handle this for awhile but will definitely not be stable long term and of course the ripple will likely be through the roof.
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      Exactly what I was thinking....at least the heatsinks are better than a lot of L&C's I've seen but yeah this thing kicks out a lot of heat...
      • SuperDuty
        • Mar 2011
        • 299
        • France
        I have two of those ! One is an "Heden" branded variant. I got it in a case back in...2003. It still works and served me well in Socket A rigs until 2010 at least...it does have a buldged cap. Rated at 350W...sure sure. It does have a little bit more components than this one.
        I also have another one, "ACC+" branded, with a much improved filtering, a true 4A bridge rectifier, a bigger ERL35 transformer, a pair of 13009 on the input, but it still has the 10A super fast on the 12V... rated at 380W, I'd say 300W at best.
        • prongs12
          Salvage Master
          • Mar 2013
          • 8
          • Indonesia
          the secondary caps will mostly blowing up first... even without see the details i could guess the caps value
          you could see the most common damage caps below.. and the value
          Micron Scrap
          Buying Electronics scrap since 2005
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            And you're on 230V so they'd do better in general. Lucky!!
            Yeah, those were 2200uF caps. And who knows how much wear was already on this thing so they could bulge any day now
            • Pentium4
              CapXon Be Gone
              • Sep 2011
              • 3741
              Guy brought his computer back in cause he wasn't getting video, I wonder if the ripple killed the old video card? He wanted a new AGP card and still didn't want to replace the PSU. It has an X1300 Pro now....
                master hoarder
                • May 2008
                • 12170
                • Bulgaria
                I give it a year at the most. With that high of a load on the 12V line, this thing will heat up quite a bit inside - even if the fan is wired to run on 12V all the time (and if the fan is wired to run on 12V all the time, then the fan will likely fail before the caps do). I doubt the output caps will last long, especially considering their brands. Moreover, you got those big load resistors right next to them... as if the heat from those undersized rectifiers isn't enough already .
                Tell him the power supply killed the old video card and that the warranty sticker on the PSU is broken so he didn't actually get a new PSU. Hopefully that should get him to reconsider.
                • Pentium4
                  CapXon Be Gone
                  • Sep 2011
                  • 3741
                  Yeah it kicks out mega heat! And it's one of those pathetic little fans that just says "Sleeve Bearing" on it, no info or anything!
                  He is set in his ways, won't take my advice...
                  • Skgod
                    Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu
                    by Skgod
                    Hey I am having Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu. Works fine when I open any game or whatsapp windows application. The issues are :
                    Black screen, freeze
                    The weird thing is that when as long as the laptop is running on igpu the problem keeps happening. But as soon as I open any game or whatsapp windows application, the laptop works completely fine.
                    When the screen freeze or black screen I used to move the display lid up and down and it usually works like that.
                    So can anyone tell me what would be the possible cause?...
                    10-16-2024, 08:11 PM
                  • szreder6
                    HP Pavilion 14-ce0505sa, 5 long 3 short, no display. g7a-2g da0g7ambd1
                    by szreder6
                    Hello guys,
                    I have a problem with my laptop as in the title, black screen, capslock displays error code 5 long 3 short, no voltage on the coils above the CPU, before removing the drive I had 0.8v there, power led flashed 5x long and the battery would not charge (current jumped from 0.5a to 2.8a), now on the power led I have a steady white light or orange when the battery is connected.
                    What I did:
                    - Laptop was not detecting ram, loose pins on ram slot, error 3.2 disappeared, ram working tested in another laptop
                    As far as I know the laptop was in another service center...
                    11-22-2024, 05:17 PM
                  • edugimeno
                    Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                    by edugimeno
                    Hi There!
                    I'm trying to help my friend who owns a restaurant be just bought.
                    He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                    It's stuck using, I guess, the 2 sided tape that comes with the strip
                    The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                    09-05-2024, 09:34 AM
                  • Ferimonka
                    HP Envy 15-FH0501sa 3 long 2 short capls lock light
                    by Ferimonka
                    Hello guys,
                    As per title says I have a Envy 15-FH0501sa , Ryzen 5, 16 Gb version.
                    Motherboard number is JPB51 LA-M798P rev.1.0
                    SN CND3362R3S
                    The laptop is getting power and funs stop spinning after few swcconds. It was liquid damaged so we get it to turn on. However 3 long and 2 shor Caps lock lights showing. Power button turns the laptop on but not off.Battery is charging.
                    Please help and advice. I attachet the bios dumb in case the bios is the problem.
                    Many thanks.​...
                    04-29-2025, 02:17 AM
                  • drake441335
                    OLED65G6P-U.BUSWLJR Temperature sensor issue
                    by drake441335
                    I am a very beginner at tv repairs. I am trying to fix my tv before I end up buying a new one. I do not know names of boards, but I will do my best to explain what I have done so far.
                    Tv is an LG OLED65G6P manufactured in april 2016. I had a warranty on it till September of 2021. Warranty is done. The problem I am having is when I turn the tv on after about two or so minutes a popup comes up and says the temperature sensor issue, and then it powers itself off. The tv works as designed, picture, sound, wifi, settings and everything, before it just powers itself down.
                    So i did what any...
                    02-13-2022, 03:34 PM
