Question about 12V ripple
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Worried ripple might be too high on this system I'm using daily. It's my Xigmatek PSU https://www.badcaps.net/forum/showpo...postcount=1156
    I think it's good for 350W at least but I'm worried about the 12V ripple. All it has on the 12V is 1 pi coil and one 4700uF Panny FR cap. It's powering a Core 2 Duo 2.4GHz proc, 4GB RAM with a BFG GTX 260 and a single SSD drive. Sometimes when doing medium gaming, the PSU gets around 200W. Efficiency is around 77% I don't have an oscilloscope but as a guess would you say the ripple isn't that bad?
  • Wester547
    • Nov 2011
    • 1268
    • USA.
    Re: Question about 12V ripple
    Though I would recommend at least two filtering capacitors for each output, 4700uF x1 should be theoretically enough for the +12V rail... so long as the ripple is well under 120mV (that's quite a bit of electrical noise and heat), you should be okay. Any PSU that gives off 100mV of ripple on the +12V rail isn't one that I'd feel safe with, though. I would guess that the heat output from the PSU itself isn't bad, overall? If you don't feel safe with it right now, I don't think it would hurt to add an extra 2200uF capacitor on the +12V output (if there's room). Note that 120mV is the limit for the +12V rail and 50mV the specified limit for the +3.3V and +5V rails.
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      Yeah I wish there was another slot for a cap but there wasn't, that's why I put a huge 16V cap in the only spot I figured the coil would help some too though, even at 200W it doesn't kick out a ton of heat because my room is around around 15C
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Just a note - adding/decreasing capacitance and/or esr can cause MORE ripple in some psus!
        Muh-soggy-knee
        • Wester547
          • Nov 2011
          • 1268
          • USA.
          ^ I would guess that augmenting capacitance can increase ripple because as capacitance goes up in capacitors, ESR goes lower (larger can sizes, usually, so higher ripple current and lower ESR rating...).
          • c_hegge
            • Sep 2009
            • 5219
            I have load tested a similar PSU (http://www.hardwareinsights.com/wp/a...520c-review/2/). The ripple was a little high, but still in spec.
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Originally posted by Wester547
              ^ I would guess that augmenting capacitance can increase ripple because as capacitance goes up in capacitors ESR goes lower (larger can sizes, usually, so higher ripple current and lower ESR rating...).
              It affects the way the control loop works, and the frequencies that get filtered out.
              Muh-soggy-knee
              • Pentium4
                CapXon Be Gone
                • Sep 2011
                • 3741
                Shoot....I hope the ripple isn't higher! I used my little ESR meter and the Panny cap was actually 0.01 higher than the Teapo if I remember correctly
                • c_hegge
                  • Sep 2009
                  • 5219
                  a 0.01 ohm difference isn't going to make much difference.
                    master hoarder
                    • May 2008
                    • 12175
                    Only somewhat true.
                    Increasing the capacitance alone without lowering the ESR or increasing the ripple current will actually decrease the output noise and ripple. However, Wester547 stated a valid point - the can size of the capacitor often becomes larger with increasing capacitance, so that means the ESR is lowered and the ripple current increased - and this is exactly what can cause the PSU to actually output more noise.
                    The 4700uF Panasonic FR should be fine, though - of course, all depending on the TDP rating of the Core 2 Duo and the 260 GTX. I've successfully ran a 107 W TDP CPU with a Macron MPT-301 PSU that has only a single 3300uF 16V Chemicon KZE cap for the 12V rail.
                    • Wester547
                      • Nov 2011
                      • 1268
                      • USA.
                      EDIT: Nevermind, his PSU is a half bridge too...
                      • Pentium4
                        CapXon Be Gone
                        • Sep 2011
                        • 3741
                        Originally posted by momaka
                        Only somewhat true.
                        Cool They're both running at stock speeds and the case has good airflow. And at least it has an SSD instead of a spinning disk, so slightly less 12V needed
                        • Wester547
                          • Nov 2011
                          • 1268
                          • USA.
                          I was of the impression that there wasn't such a thing as "too high a ripple current" in capacitors... if only because it increases the maximum amount of ripple they can handle (the maximum permissible ripple current for the capacitors, though I know that lower ESR ratings and higher ripple current ratings in capacitors are almost unavoidably synonymous with larger can sizes), but then a good design will be such that there won't be much ripple to begin with.
                          However, in saying that, if capacitors allow more ripple into the PSU (and thereby out) since they can handle it with a higher ripple current, it does make sense... unless you mean that the higher the ripple current, the more ripple has to be "released" to ground.
                          • ben7
                            Capaholic
                            • Jan 2011
                            • 4059
                            I think it is more the different esr and/or capacitance messes with the pole in the feedback loop. Unique sure could tell us.
                            Muh-soggy-knee
                            • chth96
                              Is it no harm to replace with capacitor without ripple current rating?
                              by chth96
                              When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                              Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                              But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                              Rubycon YK DataSheet (b...
                              04-19-2024, 05:19 AM
                            • Antonynl
                              What are typical ripple voltages on a laptop motherboard?
                              by Antonynl
                              I have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
                              So I have two questions:
                              1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
                              2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
                              Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....
                              12-09-2022, 06:51 AM
                            • Ady2017
                              Is there a manufacturers tolerance for ripple?
                              by Ady2017
                              Hi all
                              I need to replace a 680uF 35V SamYoung NXB cap which has got a ripple of 1820. Whilst passing my local little electronics shop I picked up what they had in stock which was a 680uF 35V Panasonic FC with a ripple of 1655.
                              As the ripple rating is only 9% below what the original was I am wondering whether to risk it and fit it.
                              The catalogues specify a capacitance tolerance of +/-20% but state nothing about the ripple. If there is a similar tolerance for ripple then I might be worrying about nothing. Does anybody know?
                              11-13-2021, 11:46 AM
                            • Antonynl
                              Lenovo 530 Vcore : what is the maximum ripple?
                              by Antonynl
                              Hi
                              I have a Lenovo 530 14ikb i5 8th gen motherboard and it fails to start Windows: it normally dies after I try to load Windows. Getting into bios screen works fine.
                              Made some measurements and I suspect that there is to much ripple on the 2 Vcore coils.
                              What is normally the maximum ripple allowed on say any of the power supplies? A few %??
                              The ripple is on both Vcore as outlined in red in attached photos.
                              Could be a bad driver?
                              Cheers...
                              04-29-2023, 04:59 AM
                            • sumilumi
                              700mv ripple on Akai Sampler linear supply
                              by sumilumi
                              Hi fellow troubleshooters. This is my first post on badcaps. I've recently setup an electronics workbench. i'm also building a studio with old equipment bought faulty at low cost.
                              I've been into electronics since the mid 80's and particularly in the last few years though only getting hands on with repairs now. My knowledge gaps are significant so I'll be posting here to seek guidance advice and general practical applied learning.
                              On my bench today is an old ca. 1993-95 Akai hardware sampler. This runs on both a linear and Smps supply. Both are getting on in age and ripple...
                              01-02-2022, 10:12 AM
