700mv ripple on Akai Sampler linear supply
  • sumilumi
    • Jan 2022
    • 3
    Hi fellow troubleshooters. This is my first post on badcaps. I've recently setup an electronics workbench. i'm also building a studio with old equipment bought faulty at low cost.
    I've been into electronics since the mid 80's and particularly in the last few years though only getting hands on with repairs now. My knowledge gaps are significant so I'll be posting here to seek guidance advice and general practical applied learning.
    On my bench today is an old ca. 1993-95 Akai hardware sampler. This runs on both a linear and Smps supply. Both are getting on in age and ripple seems fairly high. The smps gives me some 150mv on average but rather alarmingly the supply feeding the sensitive DAC output stage is fed from the unregulated linear supply. This goes to two LDO + - -15v regs that in turn feed the dac through a couple of 78/7905 By this point ripple is down to 34mv but I'd. like to minimise what the main supply feeds and get on top of this rather loud ripple.
    The sampler isn't playing well. I see ringing peaks on square and saw waves so there are other issues but i figure start with the supply.
    I've attached a shot of the psu board. this is fed by a separate smps which appears ok given its age. These were expensive devices back in the day and Akai specced them quite well.
    I've done a quick in circuit cap esr test with a ‘peak' meter and most including the main filter caps look good. The only suspect is the small .47 next to the rectifier which I'll desolder for test later today.
    I'll also measure all voltages under load and update the image with these printed in case that helps the process.
    So I'd be most grateful for suggestions on what could be amiss here. Is 700mv ripple normal ?
    Thanks in advance
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: 700mv ripple on Akai Sampler linear supply
    Yes that ripple would be normal for a linear power supply.
    They probably do this to get less noise to the ADC or DAC:
    A switching power supply might have allot more high frequency noise that is hard to filter out...
      • 31277
      i would re-cap the power section,
      those caps are so old i cant find a datasheet!
      they have a 1000hour rating and are 85' listed.
      also, they are "audio grade" and shouldnt be in the power section to begin with.
      • sumilumi
        • Jan 2022
        • 3
        Thanks for your answers. I have ordered replacement caps, mostly panasonic FC for the the recap.
        This was an expensive device new aimed at recording studio racks.
        In 94 these cost nearly £3K new so i expect Akai probably used audio caps in line with what some audio people seem to do. I agree psu needs low esr low ripple first. I've ordered Panasonic FC. Do you guys recommend a specific cap for Linear supplies. I'm also recapping the supply in an Emu sampler that is SMPS. What caps would you guys use for switchmode.
          • 31277
          for switchmode i like panasonic FR,
          for linear you just want long life and high ripple handling and 105' is nice.
          so you have a good choice there.
          panasonic F-something, or rubycon ZL / ZL-something all fit that description
          • Zeugitai
            Akai S01 sampler limited failure
            by Zeugitai
            I've enjoyed my S01 since the early 90s, and it was still working well up until a few months ago. It was in a rack in a heated room and suffered no shocks. Powered up, floppy confirmed, channel lights lit, digital display on, data knob responsive, but the edit contol subpanel remained dark & unresponsive. Everything in the box appears good. No capacitor leakage. Has anyone been here before? I could use a/some guidance. Obliged 🙏...
            03-20-2023, 11:52 AM
          • chth96
            Is it no harm to replace with capacitor without ripple current rating?
            by chth96
            When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
            Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
            But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
            Rubycon YK DataSheet (b...
            04-19-2024, 05:19 AM
          • Antonynl
            What are typical ripple voltages on a laptop motherboard?
            by Antonynl
            I have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
            So I have two questions:
            1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
            2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
            Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....
            12-09-2022, 06:51 AM
          • Ady2017
            Is there a manufacturers tolerance for ripple?
            by Ady2017
            Hi all
            I need to replace a 680uF 35V SamYoung NXB cap which has got a ripple of 1820. Whilst passing my local little electronics shop I picked up what they had in stock which was a 680uF 35V Panasonic FC with a ripple of 1655.
            As the ripple rating is only 9% below what the original was I am wondering whether to risk it and fit it.
            The catalogues specify a capacitance tolerance of +/-20% but state nothing about the ripple. If there is a similar tolerance for ripple then I might be worrying about nothing. Does anybody know?
            11-13-2021, 11:46 AM
          • Antonynl
            Lenovo 530 Vcore : what is the maximum ripple?
            by Antonynl
            Hi
            I have a Lenovo 530 14ikb i5 8th gen motherboard and it fails to start Windows: it normally dies after I try to load Windows. Getting into bios screen works fine.
            Made some measurements and I suspect that there is to much ripple on the 2 Vcore coils.
            What is normally the maximum ripple allowed on say any of the power supplies? A few %??
            The ripple is on both Vcore as outlined in red in attached photos.
            Could be a bad driver?
            Cheers...
            04-29-2023, 04:59 AM
