Antec SL-400 5vsb Mod with NCP1200
  • LDSisHere
    • May 2012
    • 727
    • U.S.A.
    Re: Antec SL-400 5vsb Mod with NCP1200
    I got around to changing out the 5vsb current sense resistor last night. It turns out the original one was marked as 1 ohms and actually measured 1.3 ohms on my DMM so it really was 1.1-1.2 ohms. The largest value resistor less than 1 ohm that I could find measured 0.24 ohms on my Blue ESR tester. Using a DMM on a resistor value this low is pointless which is why I turned to the ESR meter.
    I did not know what if anything would happen using a value this low as a replacement but since I could not find anything else I decided to go for it. I also went from a FQPF4N60C to a FQPF5N60C for the FET. I wanted to go bigger but I needed a FET with full length leads to reach through the holes and this was the biggest I had on hand that did not have the leads trimmed.
    I mentioned in post 2 that I could hear a slight whine from the 5vsb circuit before when it did not have a load. Well, when I turned it on this time there was nothing slight about it. At this point I did not have much time to mess with it or write down numbers but the 5vsb voltage was slightly lower than what I had been seeing previously. I started adding load 10 ohms at at time in parallel all the way down to 2.1 ohms. Each load resistor changed the sound as it was added, but never eliminated it.
    I guess the big question is if it will hurt anything to run it like this for testing (if I can stand it) or will it damage something?
    • Toasty
      • Jul 2007
      • 4171
      re:whine
      You're running the 60kHz version, yes? Could it be the wrong freq for the circuit?
      I'm aware that all the mods for this circuit so far are ~60kHz with the DM311 being the highest at 67kHz.
      -but-
      Has anyone -measured- the original circuit freq?
      My 2¢
      T
      veritas odium parit
      • LDSisHere
        • May 2012
        • 727
        • U.S.A.
        Originally posted by Toasty
        re:whine
        -but-
        My 2¢
        T
        You had a good idea about the frequency so I put on 100k chip to see if it would help. Unfortunately, it was still squealing very loudly.
        I do not have the means to measure the circuit frequency. I have an oscilloscope on my wish list, but it will be a while before I am able to get one.
        I will probably order some .75 and .5 ohm resistors to try and see if that makes a difference.
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          As far as I know, the squealing is from instability (ringing/oscillating) in the circuit. Could be the feedback is not adjusted quite right, and/or the frequency the transformer is switched at could be adding to the problem.
          Muh-soggy-knee
          • LDSisHere
            • May 2012
            • 727
            • U.S.A.
            I finally was able to give this project some attention again last night.
            Due to an intolerable ringing, I pulled the 0.24 ohm current sense resistor that I had previously tried and replaced it with a 0.75 ohm resistor. I also pulled the 5N60C FET and replaced it with a 7N65C.
            I resumed my 5vsb testing at the same point I had stopped, which was a 1.3 ohm load. Previously the voltage quickly started dropping at this load which, at Everell's suggestion, was the reason for lowering the value of the current sense resistor.
            I still had a slight ringing but it was much less than with the 0.24 ohm current sense resistor. I noticed that the ringing seemed to stop after the supply warmed up under the 1.3 ohm load. I ran the supply for 1 hour at this load. The 5vsb was steady at 4.94V for the duration of the hour.
            I then tried adding another load resistor taking the load down to 1.1 ohms. It ran fine when I turned it on and it was still above 4.9V. While these load tests are running off to the side of me I usually work on other projects, which was the case last night. After about five minutes, I looked over and the 5vsb voltage was slightly above 0V. As I went to turn off the power to the supply I could smell something burning.
            I have not yet had a chance to see what died, but I suspect it was the diode on the output of the 5vsb transformer since Everell had a similar experience with his experiment.
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Can't wait to see the carnage LOL
              Muh-soggy-knee
              • LDSisHere
                • May 2012
                • 727
                • U.S.A.
                #27
                I hate to disappoint you but the carnage, if can call it that, was minimal at best. The diode was shorted and it was a SB340 which is the same as what Everell had fail in his Bestec experiment. I am actually surprised that it held up as well as it did considering the load that was going through it and what it is rated to accept. I have a good SB340 that I may throw in it just to verify everything else is working until I get a better replacement.
                Following Petes_in_CA's advice in Everell's Bestec thread, I am looking at ordering some 9 to 10A diodes to replace this shorted one. I also may look through some of my parts piles to see if I can find a heavier rated one to use until I place my next order. These are the diodes I am looking to order:
                http://www.digikey.com/product-detai...Q040-ND/352058
                http://www.digikey.com/product-detai...5GI-ND/2153531
                I also wanted to make a correction to my previous statement. The 5vsb FET is still a 5n60C. I had ordered some 7N65C to use for the 5vsb but I had forgotten that I decided against using it when I swapped out the resistor a few weeks ago. (It was a while before I got around to doing these tests.)
                • Toasty
                  • Jul 2007
                  • 4171
                  #28
                  You're overloading the 5vsb, so what do you expect?
                  The SB340 is rated for 3A and you're pushing 3.8A through it...?
                  The PSU is rated for 2A on 5vsb.
                  Lowest resistance (for *max* current) would be 2.5Ω. Using a "rule of thumb" for (continuous) static load testing, I would use nothing lower than 4Ω. That's a 60% load.
                  No wonder it's ringing/squealing. You would too if overloaded by 90%...
                  Unless you're redesigning the trafo and other components, this is an exercise in futility.
                  T
                  veritas odium parit
                  • LDSisHere
                    • May 2012
                    • 727
                    • U.S.A.
                    #29
                    You may see these experiments as an exercise in futility. I see it as how much juice can I get from this lemon or maybe how to have an indoor fireworks display. It is also a good learning exercise. I was able to trace out and modify the two transistor 5vsb and then discover where the other weak spots in the circuit are located. So after I get a better diode I will then see what pops next. If I melt down the transformer, I may try my hand at winding a replacement or just move on to another supply which I will torture back to the death from which I previously revived it like I have done with this one. Also one thing this experiment does prove is that you can get more from a 5vsb circuit using an IC to drive a FET than you can using a one chip PWM like the DM311 or Viper22A, etc. and the heat is better dissipated because the 5vsb FET is already attached to a very large heat sink.
                    The squealing/ringing was occurring under no load and would actually get quieter as the load increased. It seems to be directly related to the current sense resistor that goes between the 5vsb FET and ground. As the value of this resistor value gets lower the noise gets louder, as the load increases it gets quieter.
                    • everell
                      • Jan 2009
                      • 1514
                      I replaced my SB340 with a SB540 diode. So far it has not blown. Should it fail, I also bought from Digikey the SB1040-E3 in TO220 case. If I install it, I want to install it to the secondary heat sink.
                      The SB340 is directly beside and touching the C36 filter capacitor which usually is bulging. Judging by the amount of heat from the diode in the experiments, I am not surprised that the capacitor doesn't like the location.
                      When my SB340 diode failed, it was too hot to touch!!!!!
                      Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                      • LDSisHere
                        • May 2012
                        • 727
                        • U.S.A.
                        #31
                        Everell I will have a look at those diodes before I place my order.
                        I used the SB340 I had laying on my table to replace the shorted diode. The 5vsb came back to life and it seems the ringing went away. This diode may have been damaged in my earlier experiments before finally failing completely. I did not try any heavy loads this time, those will be saved until I get a higher rated diode.
                        • LDSisHere
                          • May 2012
                          • 727
                          • U.S.A.
                          #32
                          Well I put a VS-90SQ040 (9A 40V) diode in place of the SB340 that had shorted in my previous test. Last night I got a chance to run it so I started where I left off which was a 1.1 ohm load on the 5vsb. After about 45 minutes of it running fine I noticed that the voltage had suddenly dropped to basically zero.
                          Today I decided to see where the problem was this time but I started my checks with the diode I replaced. Much to my surprise this new 9A diode was shorted just like the one it had replaced.
                          I have a SBL1040-E3/45 to try but I will have so squeeze in a heat sink with it if it has any hope of lasting longer than the previous diode. I thought for sure something else would pop before the 9A diode that I used would be a problem. My goal is to get this supply to run 5A on the 5vsb for one hour and I am almost there, I may just need to point a fan at it when it is running.
                          • ben7
                            Capaholic
                            • Jan 2011
                            • 4059
                            My guess is that larger switching spikes from the larger currents involved is killing your diodes. Try either a higher reverse voltage diode, or a snubber across the diode.
                            Muh-soggy-knee
                            • LDSisHere
                              • May 2012
                              • 727
                              • U.S.A.
                              #34
                              I thought you might be onto something here then I thought why not use my new oscilloscope to actually "see" what the circuit was doing. I have been want to use it for something practical and this was my first chance.
                              After putting the SBL1040-E3/45 in the supply, I attached my scope to the output side of the diode. It does not look like the voltage is spiking above 8V and these images were captured with the load at 1.1 ohms. I of course have no idea what the wave form means one way or another as far as if the circuit is operating normally or not. I understand the base voltage is approximately 5V that swings a much as 3V above and below the base line during the periods of oscillation. I did not run it very long at this load as I did not have time.
                              • ben7
                                Capaholic
                                • Jan 2011
                                • 4059
                                Your only looking at the forward voltage drop of the diode. Instead, look at the ac waveform from the transformer secondary.
                                Another thing is, your diode might be overheating.
                                Muh-soggy-knee
                                • PeteS in CA
                                  • Aug 2005
                                  • 3579
                                  • USA, Unsure of Planet
                                  #36
                                  I had similar thoughts as ben. Maybe use a 50V or 60V rectifier. The V(f) will be a little higher, but it will tolerate spikes. Unless your scope and probe are 100MHz or better (and the probe equalization is properly adjusted) the spikes might be there, but the scope can't "see" it. The unpleasant part is that the 11pF-22pF capacitance of the probe might also be enough to diminish spikes. OTOH, even a short probe ground lead could pick up noise. BTW, another frustrating thing, different types and brands of rectifiers and MOSFETs will have different parasitics (i.e. ringing).
                                  What you're doing is finding the things limiting the circuit's maximum current performance. The output rectifier, switch MOSFET and current sense resistor are three factors. Several others are the MOSFET gate drive (does the turn-on and turn-off get sloppy at higher currents), the transformer primary wire, the transformer secondary wire, and the PCB trace width and thickness. And if there is a separate O/P inductor, the gauge of its wire.
                                  One extra note regarding transformer and inductor wire. With AC, a characteristic called "skin effect" limits the current carrying capacity of wire. As the frequency goes up, current increasingly concentrates in the outer part of the wire. Skin effect is relevant as low as 400Hz (the frequency used for power for US military electronics). At 30KHz or 200KHz, that AWG #18 wire good for 10A DC may only be good for 3A-5A. There are a couple of ways to work around this, both of which increase the amount of "skin". One is to use copper foil for higher current secondary windings. Basically, foil is all "skin". The other is to use Litz wire, which is strands of smaller gauge magnet wires (i.e. each strand is insulated from adjacent strands) twisted together. If you're thinking that neither option is cheap, well, you're right. But using AWG #12 or #14 wire for a 10A O/P isn't cheap, is bulky, and is not fun to wind (try winding AWG #10 on a 1.57" OD toroid and you'll experience what I mean - BTDTGTTS, a drawerful in fact) or to terminate to transformer bobbin pins.
                                  PeteS in CA
                                  • LDSisHere
                                    • May 2012
                                    • 727
                                    • U.S.A.
                                    #37
                                    I will take a look at the secondary AC side as soon as I get a chance. I think by attaching the TO-220 package directly to the heat sink I will have eliminated any heat problems I was getting from the cylindrical packages of the other diodes I was using.
                                    My scope is a Owon SDS7102 100Mhz which I have only had for 1 week so I am still trying to figure it out. I am trying to be careful not to do anything stupid and blow it up as I know that is a distinct possibility when playing with power supplies. I have an isolation transformer on its' way to me which I should have by Wednesday.
                                    Yes, these things are what I am curious about finding out about and what effects modifying them have on the rest of the circuit. The trick I suppose is to figure out where the cause is located that is creating the effect.
                                    You have provided me with a lot of very good useful information here that I very much appreciate. I could follow most of this but then I get lost. I have an understanding of the skin effect but not a good one. I will have to do some reading on this subject.
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      #38
                                      My only "contribution" to this thread is to point out that .BMP files are 1.3MB whereas a JPG version of it is only 66KB and I can't see the .BMP as a thumbnail.
                                      --- begin sig file ---
                                      --- end sig file ---
                                        The Owon scope does not natively output PNG.
                                        PNG is for screenshots, graphic line art, etc.
                                        JPEG is for photos.
                                        • retiredcaps
                                          • Apr 2010
                                          • 9271
                                          #40
                                          I don't have a scope or even used one, but see
                                          EEVblog #279 – How NOT To Blow Up Your Oscilloscope!
                                          http://www.eevblog.com/2012/05/18/ee...-oscilloscope/
                                          • AJ847.63e
                                            Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                                            by AJ847.63e
                                            Hi Folks,
                                            Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                                            I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                                            The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                                            05-06-2025, 10:37 PM
                                            HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                            This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-12-2024, 02:20 PM
                                            HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                            09-06-2024, 10:56 AM
                                            HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                            HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
