Antec SL-400 5vsb Mod with NCP1200
  • everell
    • Jan 2009
    • 1514
    Re: Antec SL-400 5vsb Mod with NCP1200
    ^Agreed +3. I am having a similiar problem with my Bestec
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
    • kaboom
      "Oh, Grouchy!"
      • Jan 2011
      • 2507
      If it's powered up again, it'll probably be unstable now for the same load it was stable at before it overheated. If the transformer is unwound, the wire varnish will at least be darkened, possibly cracked.
      Also, if there's no, or a too-low value, resistor feeding the aux supply limiter zener (tertiary/line side), said zener could be bad.
      "pokemon go... to hell!"
      EOL it...
      All style and no substance.
      guilty,guilty,guilty,guilty!
      guilty of being cheap-made!
      • LDSisHere
        • May 2012
        • 727
        • U.S.A.
        #83
        I probed around the supply tonight and I did not find any points of failure I could identify so I decided to power it on an see what would happen. I just had my standard ATX tester connected to it along with my DMM for voltage reading. Much to my surprise it worked, with a reading of just over 5.1V, (I do not remember what the last two digits were.)
        It does appear that the waveform on the secondary diode has significantly changed. So the theory about the transformer being damaged my be correct, it just may have been pushed too far. If this is the case I am not really surprised, the only thing that surprises me is that it did not happen sooner.
        It looks like it could be time for someone to learn how to wind a transformer.
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          If your going to wind your own transformer, you might as well make your own smps, with pcb... xD
          There are plenty of things online that are about designing smps transformers
          Muh-soggy-knee
          • LDSisHere
            • May 2012
            • 727
            • U.S.A.
            #85
            I finally got around to hooking up my ring tester to the 5vsb transformer. It only went up to three red LEDs so I think the transformer must be damaged. Well this is not surprising considering what I was trying to do.
            A couple of weeks ago I tore apart a 5vsb transformer from a scrap supply just to see what it would take to rewind one. Well lets just say I have better things to do with my time and I will wait until I can find a another Antec supply from which I can scavenge the 5vsb transformer.
            • AJ847.63e
              Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
              by AJ847.63e
              Hi Folks,
              Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
              I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
              The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
              05-06-2025, 10:37 PM
              HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
              This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
              09-12-2024, 02:20 PM
              HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook 1000 Specification for Upgrade or Repair
              This specification for the HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load & Asset Tag boardview and 1050 G1 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
              09-06-2024, 10:56 AM
              HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
              This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
