Re: Repairing Bestec TFX0250D5W
Nice work everell! Great photos as usual too.
With 17A available on the 12V rail, spec-wise this looks like a really nice 250W PSU.
After replacing the bad caps, the power supply tester LEDs just blinked, the fan just gave a tick. So I measured the output diodes thinking that maybe one was bad. No, they all checked good. So I started tracing the output circuit to see what was in this power supply. To my surprise, there are NO load resistors on the output rails. So I set up a jig with a 12 ohm resistor for the 12 volt rail, a 5 ohm resistor for the 5 volt rail, and a 3.3 ohm resistor for the 3.3 volt rail. The power supply now came up working as expected.
The reason for writing this post..............make sure the power supply you are working on has load resistance on the output rails - or you may be chasing a ghost.
For anyone else working on this particular model Bestec, here are some drawings of the 5vsb circuit and the output circuit. Also a roadmap of the output capacitors. Perhaps this will be helpful to someone.Leave a comment:
Had a Bestec TFX0250D5W come my way. It had several bloated capacitors. So I thought I would try replacing them and see if that fixed it. It didn't fix it! Here are some pictures I took of another Bestec, same model, not as many bloated capacitors. The earlier Bestec that I fixed was a dead 5vsb with bloated C36 capacitor. This one had a handful of bloated capacitors.Tags: None
by FrancescoVGood morning everyone,
I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
The firmware reported is the following:
M:1.00/11107BLP
D:?.??/????????
O:1.00/11107AL
The DSP firmware given the question marks seems corrupt.
On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...-
05-11-2025, 02:59 AM -
by marce002Hello
I have this board working fine designed to 42v fixed output using lm324n chip and i really need to make adjustable output (ideal if Vol and Current with 2 pots but at least only Vol).... i was trying to do it with datasheet and several diagrams but could not
the pins 1 2 and 3 are unconnected so it is using only 3 op amps in the chip.... How do you think I can mod it?
or any hint for an schematic similar.. thks in advance... -
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by bauto601Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
A "nice" YoungYear unit? - Badcaps
The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish.... -
by sam_sam_samI have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
I bought this from an eBay seller but unfortunately they only had one
I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
I bought three of from them to also make battery packs with this output power limit in mind
I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery... - Loading...
