Desoldering Station Switching Power Supply Problem Cold
    • Jul 2011
    • 6070
    When I bought this desoldering station I recap both board and work good except when the temperature is less than 40* F them the power supply will switch ON for 2 seconds then would shut down for 2 seconds and might do this four or five time before it will stay ON
    I had used some FC FR KY KME what would fit on these two boards
    when it 60*F or warmer it works jum st fine with no problem
    Can anyone tell me why this power supply would be doing this
    The first time I turn this unit ON out of the box before I recap it ,it did the same thing power up two or three time before it would stay on
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Desoldering Station Switching Power Supply Problem Cold
    Reminds me of my Soyo SY-K7VTA-B motherboard with Deer 250 W PSU!
    One morning, (likely 2002) when it was less than 40 F, right after hitting the power button, I got that bitchy lady's voice message "The VGA card might not be installed properly".
    But it booted after pressing the reset button on the case. (or after power cycling)
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
      03-31-2024, 02:12 PM
      07-01-2024, 06:34 AM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      After all of...
      07-13-2024, 08:14 PM
      DVR camera recorder switching power supply capacitor failure really
      These cheap non brand capacitors at it again
      Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
      Well at least I have the cameras back on line I to try the...
      01-22-2022, 06:28 PM
