Which primaries should i use?
  • WeStSiDePLaYa
    • Mar 2006
    • 63
    i have a choice of using 2 different types of primaries in my psu.
    brand new 820uF panasonic ED series.
    or a few year old pulls that are 1200uF panasonic FM series.
    its for a mushkin HP-550 that already has its secondary recapped. its original primaries were 1200uF jenpo's or asia-x brand (cant recall 100%)
    Specs
    DFI AM2 LANPARTY UT NF590 SLI-M2R/G
    X2 3800+EE AM2
    2x1GB OCZ PC2-6400 Platinum XTC
    XFX 7900GS
    Maxtor 6L250S0
    Maxtor 6V300F0
    Western Digital WD2500JS
    Mushkin HP-550(Cap/Filter Modded)
    Cooling
    Swiftech Apogee
    Swiftech MCW-60
    Swiftech MCP-600
    HardwareLabes Black Ice Extreme 2
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Which primaries should i use?
    never go down on the primary caps.
    i often upgrade to have a margin of safety during a power flick.
    • WeStSiDePLaYa
      • Mar 2006
      • 63
      so the older caps should still have enough perfomance in them to outperform the brand new caps?
      Specs
      X2 3800+EE AM2
      XFX 7900GS
      Maxtor 6L250S0
      Maxtor 6V300F0
      Cooling
      Swiftech Apogee
      Swiftech MCW-60
      Swiftech MCP-600
      • yanz
        • Nov 2004
        • 910
        yup. but there is nothing wrong with the TS-ED anyway, 820uF sounds right for ~500W PSU, although im expecting 1000uF.
        days are so short when you actually do something..
        • zmezm1995`
          lenovo thinkpad t15g gen2
          by zmezm1995`
          hi need bios my for my laptob lenovo thinkpad t15g gen2
          bordnumber hp550/hp750 nm-d491 rev1.0
          SN PF-3JA8X3
          proplem I updated the bios and now it works without any image.
          and this my dump...
          10-13-2025, 10:15 AM
        • kotel studios
          Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
          by kotel studios
          Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
          State I got it in:
          Squealing from the PSU
          After logo I get a blank screen
          After 10 seconds of having a blank display w/ backlight the TV dies
          Give it 7-10ish seconds again and it starts to bootloop.
          What I did so far:
          Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
          Checked all voltage rails:
          5VSB - 4.8V
          AMP+13V - 14.4V
          13V - 12.98V (in manual 12V)...
          09-21-2025, 02:00 AM
        • markk8799
          Confirmation on replacement caps
          by markk8799
          I'm replacing a swollen cap in the PSU of a Samsung UN40EH8000F TV. The cap is a Samyoung 10 V, 1200uF, 105 degree C, NXE series. From what I can gather, the NXE series is essentially those specs, with 20% tolerance, ultra-low ESR, low impedance, and long life (3-4,000 hours). On Dikigey, I was looking at the Panasonic EEU-FC1A122 or EEU-FK1A122L. The only thing I can discern between the two is a difference in impedance (44 vs 52 mOhms). Any suggestions are greatly appreciated. Thanks!
          05-23-2025, 08:25 PM
        • kotel studios
          Compaq PDP-124P - loud screeching when running
          by kotel studios
          Recently I got my compaq PDP-124P to "work" and it now screeches loudly when running (you can hear it from 60cm away!).
          There's nothing shorted on it, caps were already checked and replaced when they were close to being above 20% of rated spec, apart from the primaries. Fan isn't the issue too.
          I didn't have time to measure the voltage rails (beside 12V, that one had 11.7V) due to the unexpected sound.
          Load was only an single sacrificial board w/o CPU power since these PSU's don't work without mainboards.
          Any ideas what could be...
          03-25-2025, 11:58 AM
        • ktmmotocross
          hp550 bad graphic ic?
          by ktmmotocross
          hello.
          have this hp550 intel, that have strange problem. on start it freeze on windows desktop start and on wake from sleep. if i go to safe mode and than restart, it start total normal. do u think its a bad ic?
          03-27-2018, 09:17 AM
