Compaq PDP-124P - loud screeching when running
This topic has been answered.
  • kotel studios
    • Dec 2024
    • 141
    • Poland
    Recently I got my compaq PDP-124P to "work" and it now screeches loudly when running (you can hear it from 60cm away!).
    There's nothing shorted on it, caps were already checked and replaced when they were close to being above 20% of rated spec, apart from the primaries. Fan isn't the issue too.
    I didn't have time to measure the voltage rails (beside 12V, that one had 11.7V) due to the unexpected sound.
    Load was only an single sacrificial board w/o CPU power since these PSU's don't work without mainboards.
    Any ideas what could be the issue?
  • Answer selected by kotel studios at 06-15-2025, 03:20 AM.
    kotel studios
    • Dec 2024
    • 141
    • Poland
    Yep, it was the short on the dip 8 component at fault. Or that and the out of spec 220uF 25v cap. Odd since there wasn't any short before on it.
    Now the PSU works without any fuss with the original caps. I will do further testing to confirm whether this PSU is safe for normal use.
      • 31015
      what are you testing caps with?
      are you checking ESR & Leakage?
      • PeteS in CA
        • Aug 2005
        • 3580
        • USA, Unsure of Planet
        This may seem odd, but since the P/S is probably more than 20 years old, there is the possibility that:
        * Output caps you replaced now have capacitors that are "too good", their impedance is too low, causing instability;
        * Output caps you did not replace are high impedance, causing instability.
        PeteS in CA
        • kotel studios
          • Dec 2024
          • 141
          • Poland
          I don't think it's the first assumption since I used the same caps as with my LC clones, but who knows what hp did with their stupid engineering.
          lcr t2 tester. Sure, it's nor that reliable but it gives me an rough example of what the real capacitance should be. ESR is always 0ohm (tester limitation) and V loss is either 0.2% or 0%.
          • kotel studios
            • Dec 2024
            • 141
            • Poland
            Okay still same sound, even after replacing an 10uF 50v cap connecting to 5v rail (I didn't see that one of the legs was broken). Maybe even worse. This time I measured 5v rail and it was 5.14v
            Another idea would be that the primary caps are cooked and need to be replaced, but the only 470uF 200v caps I have report as 320uF which is not normal (they are from an LC clone). I think for testing they should be enough.
            Any ideas?
            • kotel studios
              • Dec 2024
              • 141
              • Poland
              Primaries were replaced but the sound is still there..... So this can't be the primary side. Gotta take a closer look at the secondary or better yet, put the original caps in.
                • 31015
                screaming usually means it's running at the wrong frequency - often caused by overloading or instability.
                so i'm sure the problem is on the output side
                • kotel studios
                  • Dec 2024
                  • 141
                  • Poland
                  Overloading shouldn't be the issue. The board takes waaaay less than 180W the PSU is rated for.
                  Old caps in and the original fan and still the same issue. 12v is 11.84v.
                  I think the sound comes from near the transformator. If it had shorted windings then the PSU wouldn't start up right?
                  I will need to pull out the transistors near it and check them out of circuit (in circuit they are fine).
                  I am running out of ideas now. I should also replace all of the smaller caps on the secondary side, but who knows if that'll help.
                    • 31015
                    take something insulated like a bic pen without the refil and poke at the transformers and coils to see which is doing it
                    • kotel studios
                      • Dec 2024
                      • 141
                      • Poland
                      Actually, after removing all of the transistors I noticed the dip8 component on the primary side had two legs shorted. Odd, don't think I've done that while desoldering the transistors and whatnot...
                      And now after putting everything back together I get no life at all from this PSU. Not even the bulb protection. I guess the 230vac wires got screwed.
                      • kotel studios
                        • Dec 2024
                        • 141
                        • Poland
                          • 31015
                          what is the part number of the 8pin device?
                          • kotel studios
                            • Dec 2024
                            • 141
                            • Poland
                            UC3845B PWM chip. I think it was ground with output shorted. Gotta recheck once I get to finalization of this repair.
                            • kotel studios
                              • Dec 2024
                              • 141
                              • Poland
                              Okay, since everything seems to work fine I decided to rework the case a bit and guess what? The 4pin CPU power is proprietary. Instead of 12v or 12.4v high power it's 12.8v (no load is 13.20v while with an 12v 5w bulb it's 12.9v)...
                              I'm not gonna write about "downgrading" the rail here since this post was just to fix the screeching noise.
                                • 31015
                                it's probably "within spec"
                                atx is pretty lax with it's numbers
                                • kotel studios
                                  • Dec 2024
                                  • 141
                                  • Poland
                                  Okay under general load (as I would run it) the cpu 12.8v goes down to 12.66v and seems to be going slowly up. So ig it should do the trick.
                                  Generally this whole repair could've been avoided if I cleaned this PSU and waited like 6 months before testing it without a sacrificial board.
                                    • 31015
                                    i always clean stuff before starting on it - makes everything a lot easier that way.
                                      HP Compaq Compaq SG3-240ES Compaq SG3 220 Specification for Upgrade or Repair
                                      This specification for the HP Compaq Compaq SG3-240ES can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-240ES boardview and Compaq Compaq SG3-240ES schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-12-2024, 03:44 PM
                                      HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) Compaq Elite 8000 E5500 Specification for Upgrade or Repair
                                      This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
                                      HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower Compaq Pro 6005 B59 Specification for Upgrade or Repair
                                      This specification for the HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower boardview and Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                                      09-12-2024, 03:36 PM
                                      HP Compaq Compaq dc7900 Compaq Q9400 Specification for Upgrade or Repair
                                      This specification for the HP Compaq Compaq dc7900 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq dc7900 boardview and Compaq Compaq dc7900 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                      09-12-2024, 03:30 PM
                                      HP Compaq Compaq SG3-331IT Compaq SG3 245 Specification for Upgrade or Repair
                                      This specification for the HP Compaq Compaq SG3-331IT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-331IT boardview and Compaq Compaq SG3-331IT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
