Cooler Master Real Power Pro 850W
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Please see video:
    http://vimeo.com/57336606
  • mariushm
    • May 2011
    • 3799
    Re: Cooler Master Real Power Pro 850W
    Connect the fan. The power supply may turn off without it.
    Make sure the soldering is done right. measure the continuity between the capacitor leads and some point on the pcb next to each lead.
    Test with the multimeter the 5v standby voltage and so on.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      Nope, it did the same thing when it was still put together (which is why I got it for $3) and the fan does spin for a second...
      I know the soldering is good because it makes a slightly different buzzing noise when there is no cap at all.
      But thanks for trying to help anyway any more ideas?
      • Khron
        • Sep 2006
        • 1350
        • Finland
        5Vsb coming up fine?
        Any shorts on any of the output rails?
        Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
          It's a really bad idea to run any kind of converter with no output cap. Without the cap, it has nowhere to dump the energy from each switching cycle. The ripple approaches whatever the control loop wants, so it could be 10Vp-p (0-10V) assuming a typical control loop.
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            What measurements should I be getting on the +5v and +12v rails at a molex connector? what is the best setting to use at my multimeter for this?
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              When I press the button the power supply tester rapidly so the psu doesn't have a chance to turn fully off the voltages fluctuate a lot (obviously because it's going on-off-on-off really fast) however they all seem fine.
                Could be because of no load -- some crappy PSUs can't start properly with no load due to lack of Vcc for controller IC.
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  nopr,
                  does the same thing with two hard drives attached
                  • Khron
                    • Sep 2006
                    • 1350
                    • Finland
                    5V stand-by = the purple wire in the 24-pin ATX connector. It should be up and working the whole time the AC is plugged into the PSU, whether it's turned on or not.
                    +5v/ +12v = ATX standard says they should be at 5/12v, +/-5%, so 5v should be between 4.75 and 5.25v, and 12v should be between 11.4 and 12.6v, to be in spec.
                    If your multimeter doesn't have auto-ranging, then setting it to the 20V (or 40V?) range should be fine.
                    PS: I don't have a PSU tester, i do all my testing "hands-on" As far as i can figure, any half-decently designed PSU should be stable (enough) with no load - that's what the minimum load resistors inside should be taking care of.
                    Plug in AC though a "bulb tester", check for 5Vsb. With active PFC's, the bulb trick doesn't work that well for "ON" testing - it's gonna light up quite well, and the voltage on the main cap(s) won't be anywhere near 380-390v DC, but for a few seconds at a time, it should do. Next step, bite the bullet and skip the series bulb
                    • shovenose
                      Send Doge Memes
                      • Aug 2010
                      • 6575
                      Finally got around to this
                      purple wire is reading 4.64-4.65 fluctuating.
                      I think I'm reading my DMM correctly and the 5V rails and 12V rails are both shorted to ground, but I have a hard time believing that's true.
                      What do I check next? Thanks!
                      • c_hegge
                        • Sep 2009
                        • 5219
                        Maybe a shorted rectifier?
                        EDIT, no, that can't be it. It wouldn't stay running for as long as it did if that was the case. Maybe a bad small cap
                        • shovenose
                          Send Doge Memes
                          • Aug 2010
                          • 6575
                          which cap should I try?
                            master hoarder
                            • May 2008
                            • 12164
                            5VSB is out of spec. Primary and secondary auxiliary winding rails may have bad caps. Pictures of both sides of the PSU as well as a few high-res ones of the 5VSB area would be very useful.
                            What resistance measurement do you get?
                            • shovenose
                              Send Doge Memes
                              • Aug 2010
                              • 6575
                              I removed that capacitor.
                              • c_hegge
                                • Sep 2009
                                • 5219
                                Don't power the PSU on with parts missing. You can damage other parts. I'm still thinking you could try replacing all of the really small caps.
                                • shovenose
                                  Send Doge Memes
                                  • Aug 2010
                                  • 6575
                                  No, as you can see in the video I replsced the bad cap but it didn't help. So I just took it off.
                                  • c_hegge
                                    • Sep 2009
                                    • 5219
                                    Try replacing the tiny vent-less caps as well.
                                    • shovenose
                                      Send Doge Memes
                                      • Aug 2010
                                      • 6575
                                      Nope. Not doing it. Anybody wanna buy a PSU? $7 + shipping
