APC Back-UPS RS 1500 LCD
  • altitude
    • Dec 2012
    • 7
    This unit warned of no battery life remaining so I replaced the batteries.
    Problem is, they discharge but won't recharge. I knew the batteries were good because they came from another APC unit.
    Voltage at battery terminals without the batteries connected: 20V so I thought charging circuit problem.
    Look what I found rattling around in the UPS when I opened it. The board now looks like a launch pad for a space capacitor
    Questions:
    1. Could the cause of this mess be the capacitof itself?
    2. Would it be safe to just replace the capacitor, see if it charges, and put the unit back into service?
    3. What should I replace it with,
    Thanks!
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: APC Back-UPS RS 1500 LCD
    Questions:
    Thanks!
    WOOHOO!
    Epic man!
    There is one other picture on the web of a capxon capactor blown out just like that
    Oh yeah, the capacitor is the problem, I am CERTAIN! :P
    Also, check the fuses on the PCB. The capacitor fireball might have caused a short (and a blown fuse). The PCB has char marks, and balling. This will have to be cleaned off. Any melted tracks will have to be replaced with a strand of wire.
    Replacement suggestion will come in a few min!
    -Ben
    EDIT: DO us a favor, and get us a little wider shot of the problem area (your second pic)
    Muh-soggy-knee
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      CapXon never ceases to suck they never last long especially next to hot resistors. We use a lot of those APC units at work, I'll keep an eye on them. How long has that one been in service?
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Here is a replacement you can order from Mouser.
        http://www.mouser.com/ProductDetail/...DGjjIl6aGC4%3d
        It's a 400v, 22uF, 105C, ~8000 hour lifespan (long life) capacitor.
        It's also 20mm in height, it should be a good fit in there. Is there any chance you can measure the diameter and height of the original (burnt) capacitor?
        Here is the area that I was talking about getting a close-up shot of.
        I want to be able to see the chips too, not just right where the capacitor was. I also will show you where/how to check the fuse, and also check the bridge rectifier diodes. I suggest you wait until we make sure no other parts are bad, THEN order the replacement(s).
        Muh-soggy-knee
        • altitude
          • Dec 2012
          • 7
          This UPS was in service since 2008. I cannot really tell you if it made noises or smelled of anything as it was used in the server room.. I didn't notice anything odd with it until it wouldn't charge anymore
          I took 3 more shots of that area
          and 1 more shot of the capacitor area after I cleaned it up
          The 3 fuses are not blown unless the continuity comes from somewhere else
          Thanks alot
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Thanks alot
            Check the resistance of R27. Also check the diodes D43, D44, D45, and 47 with the diode test setting. Test each diode in forward bias (should read about 0.6-0.7), and in reverse bias (should read OL, or something like that). If any diode measures less than 0.5 in BOTH directions, then it must be faulty.
            I am not sure yet what the value of R27 is. We might need some schematics for that!
            -Ben
            Last edited by ben7; 12-19-2012, 04:07 PM. Reason: Forgot attachment, AGAIN! :bash:
            Muh-soggy-knee
            • smason
              • 1652
              Is that cap shrapnel on IC3? Also IC11 looks odd.
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                That stuff you see might be from a sharpie or marker.
                Muh-soggy-knee
                • altitude
                  • Dec 2012
                  • 7
                  R27: reads 20 ohm
                  Diodes D43-D47: I put the multimeter on diode check (->|-) and by default it reads 1. When I test with the negative lead on the diode close to the 'D', they all read between 550 and 556. When I test the other way around, they all real between 1250 and 1275. I have no idea what that means!
                  IC3: yeah that looks more like black ink
                  IC11: take a look at it in 06.jpg it looks much better there than in 07.jpg
                  A collegue of mine has this exact same UPS at home so I thought might as well replace this capacitor on his as well.
                  If that's the case I could use his board to compare the readings
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    R27: reads 20 ohm
                    Looks like the diodes are good, but you should take pics of your friends UPS, and replace the capacitor in that one. Also, check to see if you will have to add any traces that were melted and burned off on yours, under the capacitor. I suggest that you compare the diode readings too, just to be sure.
                    Muh-soggy-knee
                    • carrzkiss
                      Cyberpower cps1500avr not charging batteries
                      by carrzkiss
                      Hello, all.
                      Cyberpower Battery Backup Unit.
                      I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                      When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                      In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                      Checking the voltage, it was down to 22v.
                      I quickly removed everything...
                      06-15-2024, 02:10 PM
                    • domix
                      LG Air Conditioner AC unit bypass
                      by domix
                      i have Lg AC indoor unit connected to heatpump warm water. To flow thru unit. I have it to heating up garage. I have previus old indoor ac unit. It was only connected to power supply and is was woking.
                      Now i have new one which has a problem, it needs outdoor unit. It has error, 5 blinks which means that outdoor unit is not connected.
                      how can i bypass this :/
                      I need only to turn on and i need only fan to blow, and adjust speed od fan. To blow over a warm pipes....
                      11-25-2025, 02:54 PM
                    • howardc64
                      Where do repair shops buy MB replacement batteries?
                      by howardc64
                      Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
                      Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
                      BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
                      07-25-2024, 10:42 AM
                    • ngml
                      Repair of an LG split AC system indoor unit PCB
                      by ngml
                      I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                      This indicates an error in the communication between the outdoor and the indoor unit.
                      The outdoor unit is fine, so the problem is the indoor PCB.
                      The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                      I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                      Does anybody have the schematics of this board,...
                      02-01-2025, 12:55 PM
                    • Astonished
                      Fixing the Charge Circuit of the Batteries of the DC Motor
                      by Astonished
                      Hi friends of electronics
                      What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                      The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                      Please help me fix this circuit.
                      (the datasheet of the IC: https://pdf.datasheet.live/28...
                      01-28-2025, 06:24 AM
