Help Me pls... About may Hp LCD Monitor No Power?
  • lorins_core
    BlackSmith
    • Dec 2012
    • 552
    • Philippines
    Sir I would like to Request the Schematic Diagram of This
    HP 5EL1T02001 Power Supply / Backlight Inverter. Thank in Advance.
    Re: Help Me pls... About may Hp LCD Monitor No Power?
    Do you know the model it came from?
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      According to shopjimmy
      HSTND-2B06
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • gabri2211
        I'm looking for the wiring diagram for led monitor model DHI-LM19-L200
        by gabri2211
        hello everyone, I'm looking for the wiring diagram of this led monitor.
        the model is DHI-LM19-L200, but I think that any other diagram of a DAHUA monitor could be equivalent.
        I really hope that among you someone can help me to repair this monitor, the screen is black, it doesn't seem like a backlight problem.
        I see the presence of 12 volts, 5 volts, but without a diagram the repair is very difficult.
        thanks to those who will answer
        12-10-2024, 04:37 PM
        03-31-2024, 02:12 PM
      • mikey5791
        Philips 196V3L monitor power led off
        by mikey5791
        Hi, i was given this lcd monitor last week with the issue of power led blinking. Upon checking the power board, i found 2 pieces electrolytic caps bulged and replaced them.
        Later, when i switched on ac power and detected 5v and 15v dc at output pins. But as soon as i pressed on the front power button, the led on power button lights for 1 second and it turns off.
        So, i tried disconnect the flex ribbon cable from t con board. But all i got is a white screen with nothing on. I suspect there is something short somewhere that prevent the display being turned on. Can someone with...
        01-25-2024, 07:52 PM
