And now for the dead Antec SP-400
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Well, actually I had two Antecs that died on me. The SP300 is now alive after replacing a bunch of caps and the toroid filter inductor. Now it's time for the SP400 to live once more.
    I see a lot of postings about replacing the +5VSB circuitry. Well it's dead on this unit, but is there a particular reason why? I don't mind any inefficiency but if it just is impossible to fix, then I'll understand.
    I found it weird that though the 5VSB uses the same 2-transistor topology (as far as I can tell) it actually uses an IGBT to pull down on the primary - this would be the first PSU I've seen an IGBT.
    Also it's weird, this PSU uses the TL494/KA7500 controller + TPS3510 monitor instead of the UC3842 the SP300 used, though I think both supplies were made by Channel Well Tech. And both are full of Fuhjyyu's. Surprisingly they aren't exploded or leaking just yet for the most part...except for the two 1mF +5VSB output caps whose ESR are off the chart as well as some small caps here and there.
    One unfortunate thing I did notice is that one resistor (R54, close to the +5VSB transformer, closer to the "tickler" (in the middle) and main transformers) is heating up and smoking when I plug it in. I'm not exactly sure why, anyone seen this resistor heat up? I measured 1.5K in-circuit (with caveats of course since it was measured in circuit) which means something is really wrong, if it's dissapating 1 watt (utter guess, because it's a 1/4W resistor and it'd take at least 1 watt or so to smoke) across a 1.5K resistor, there would be almost 40 volts across it.... Since it's across the mason-dixon line from the mains input this should be low voltage but I don't quite get why it's heating up... Anyone seen this failure mode before?
    (I'm in process attempting to get a photo without removing the heat sinks...)
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: And now for the dead Antec SP-400
    I found another capacitor that was well out of spec, and replaced it. I measured the voltage across that smoking resistor and now it's a reasonable 4.8 volts. In fact +5VSB is now around 4.8V and I'm getting a solid 9+ volts on the KA7500C PWM IC - should be enough to run the device. Alas still no power. out. Hmm... need to study this circuit more...
    • LDSisHere
      • May 2012
      • 727
      • U.S.A.
      Check pin 14 on the KA7500, you should have 5V on this pin. If you do not most likely the KA7500 is bad. I had a SLP-450 that had the 5VSB go out of control and it took out a couple of transistors attached to pins 8 & 11 of the KA7500 in addition to the KA7500 itself.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Thank you LDSisHere. Yep you were right, the KA7500C was kind of messed up, I measured 100mV on the Vref-out pin. I desoldered it, put it on a protoboard and put in +power on pin 12, and GND on pin 7 (normal power pins for those joining in) ...
        At first I started with around +6 volts and noticed from my bench psu that it was drawing 100mA... curious, not quite right... I raised it to 18V and the current draw dropped to near 0 (!) and I measured 12V out from pin 14 (!).
        Well if I didn't fry it, it's dead now.
        I did the same experiment to a DBL494 I salvaged a while ago from another PSU, this chip was correctly sending 4.99 volts out from pin 14.
        I soldered this DBL494 in, and did a quick check for any seriously broken transistors - which I didn't see any - and...
        IT LIVES! The dead-for-years Antec SP400 once again can be put back to service. I tested it real quick with the same headlight bulb,... eh... crappy regulation (12.2V unloaded, 11.8V with 4A load, but then again the unloaded number does not meet minimum load requirement of 1A.)
        Thanks again!
        • LDSisHere
          • May 2012
          • 727
          • U.S.A.
          I am very pleased that my advice was helpful and I want to thank you for posting back with your results. Good job on reviving your power supply.
          • goodpsusearch
            • Oct 2009
            • 2850
            • Greece
            Well done
              master hoarder
              • May 2008
              • 12175
              Nice.
              By the way, when you put the DBL494 in place of the KA7500, did you have to do any rewiring or are the DBL494 and KA7500 pin-compatible?
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                You know, I went back and looked at the specs. The DBL494, TL494, KA7500B, KA7500C are all pin compatible and electrically compatible - mostly. I just realized that the KA7500C is higher binned however - these are +/- 1% on Vref compared to the others that are +/- 5%. So I sort of downgraded my PSU a bit with a bit of accuracy loss, but I didn't have any spare KA7500C's...
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  Just wanted to post, 9 years later... I got to fix again.
                  The crap caps I put in for 5VSB blew up again (surprise surprise) and I replaced once again with the caps I had on hand.
                  LOL... I bet in another 9 years (or sooner) I will need to change them again...
                    • Jul 2011
                    • 6069
                    You like to live dangerously you could run out of luck doing this
                    But seriously this is a nice write up on this repair
                    Thanks for posting it
                    • R_J
                      • Jun 2012
                      • 9592
                      It's called Job security
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        fortunately I knew exactly what to check when I noticed the 5vsb line was oscillating thanks to LEDs on the motherboard I was working on... as well as the keyboard LEDs. definitely improper behavior, ESR meter and instantly knew what was bad without opening the psu.
                        now need to mark on the psu case that it had been fixed again. Just that 8mm 1mF caps are hard to find, had to use a 1cm cap extended off the board
                          master hoarder
                          • May 2008
                          • 12175
                          Well, no wonder I couldn't recall replying to a thread about someone fixing an Antec SP-400.
                          Holy ancient thread revival, lol. Just look at the post I made back then - I didn't even know that KA/TL7500 and TL/DBL494 were pin-compatible.
                          I swear, those fixes will give me anxiety one day.
                          Sure. If you're lucky.
                          Get a lottery ticket too if you feel extra lucky.
                          LOL, exactly!
                          You know, those 2-transistor 5VSB designs don't really have much in the way of over-voltage protection. So when the output caps go bad, you are literally relying on the motherboard to just hold up and not croak when the 5VSB starts going crazy. Unfortunately, not all motherboards are designed well. The FIC AM-37 that was often paired with the Bestec ATX-250-12E "mobo killer" PSU in those infacmous eMachines PCs had a bunch of TTL logic gates specced to 5.25V max Vcc... and these were directly connected on the 5VSB without any protections. So what happened? - A lot of these mobos died as soon as the 5VSB started going even slightly out of spec.... let alone the Bestec ATX-250-12E, which sometimes wouldn't stop until the KB and MS wires melted (and yes, I've seen one like that.)
                          So I honestly don't think it's a good idea to rely on your motherboard to tell when the 5VSB is starting to act up again. Next time, however soon that may be, might end up with something in smoke / biting the dust. Of course, it is your hardware after all, so your call how you want to play it. But like Sam x3 said, maybe it's more fun to live "dangerously" like that.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            True, luckily I usually have this psu powered off so it didn't have much time to do any damage, and this board was already toast pretty much -- unsure why it's so unstable now, works for a few minutes perfectly and then freezes solid regardless of what PSU I connect to it... sigh.
                            • s_henya
                              Antec VP-600P and NE550M dead
                              by s_henya
                              Got in these 2 nice PSUs, both died after power surge.
                              Both seems to be suffering from the same fault.
                              Blown main fuse
                              Shorted N mosfet 550v
                              VP-600P: 5R280CE short between GDS
                              NE550M: MDF18N50 short between GDS
                              In terns of board layout these seems pretty identical.
                              From past knowledge, once gate get shorted, most likely the for the driver to go bad as well.
                              I never tried to salvage blown fuse PSU with shorted Mosfet due to that.
                              Is it worth to try and replace the mosfets? is there a chance that the...
                              12-03-2024, 10:00 PM
                            • Rgyver2
                              Antec EA-430D 5VSB issue
                              by Rgyver2
                              I have an Antec ea-430d that will not turn on due to a problem with the 5VSB circuit. the TNY278PN has a burn "drain" pin (pin 4) and the two diodes (D901 and ZD901) near it look burnt with black on the board. (they were covered in that white goop which i removed).
                              The TNY278PN needs replaced and likely the 2 diodes as well. I found the TNY278PN, but need to know what to order to replace diode D901 and the zener diode ZD901.
                              From reading other posts, it seems wise to also replace the large 450V 270uf cap.
                              The diode info and any other advice of what else to...
                              04-18-2021, 12:00 AM
                            • double_DD
                              How can I be sure that my EC chip is dead?
                              by double_DD
                              As the title suggests, how can I be sure that my EC chip is really dead?
                              I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                              Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                              03-12-2025, 07:47 AM
                            • прямо
                              Viper22A 5VSB circuit
                              by прямо
                              So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                              In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                              01-13-2024, 07:05 PM
                            • kotel studios
                              FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
                              by kotel studios
                              Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
                              Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
                              I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
                              Any ideas where to go next?
                              02-23-2025, 11:47 AM
