This is the little brother of the Chieftec HPC-360-202 of the other thread I have created. I thought, since I fixed the other, why not fix that too?
I have posted again about that power supply here.
There are some interesting things about it.
The passive PFC is connected to psu with 4 wires, not 2! It is connected right after the bridge rectifier and is in series with both the + and the -.
Another thing I've never seen before is the output filter of the 5vsb. Instead of the usual configuration, capacitor-coil-capacitor, it is capacitor-coil-capacitor-coil, as seen on the link:
https://www.badcaps.net/forum/attach...9&d=1353028791
The 5vsb caps are 470uF 25V Teapo SX and 100uF 25V Teapo SH. I am replacing both with 2x1000uF 16V Rubycon YXF. That's the usual capacity of modern 5vsb circuits.
The soldering is very good.
There is only 1 bulging cap and it is G-Luxon 2200uF 6.3V on 5V output.
The filtering of the 12V output is done with 1 coil and 2 caps, 1x1000uF 16V Teapo SH and 1x 10uF 50V Teapo SEK, same odd configuration as Chieftec HPC-360-202.
The fan brand is "Magic". No comment on that.. There is a "sense" wire from the fan that can be connected to the motherboard and be used for fan monitoring.
All the wires are AWG18, except the ATX12V that uses 20AWG.
Unfortunately, the label lies about the 12V rating. It says 13A, but the rectifier is rated for just 10A (YG902C2). I am planning to replace it with MBR20100CT (20A). I am also in the process of replacing the 1000uF 16V general purpose capacitor with 3300uF 16V entry low esr. After that, I hope the power supply could be used with 12V systems.
What do you think?
What do you think?
). I already got probes too (well, 1 of them).
