FSP 350PN high pitched sound
  • elod
    • Jul 2006
    • 8
    Just bought a 350PNF. Really cheap, expected somewhat bigger rectifiers on the output side. Don't know what they are, because you can't see them (and i don't want to void the warranty - yet). The unit is not sealed, so you can open it up without losing it.
    There's one big, no, Huge problem with it. It constantly emits a high pitched noise (whine, really). It's not the fan, i stopped it. It's electronics. Could be a cap. Caps are cheap (OST 680u/200V, Teapo & OST on output, nothing really small or really big: 2200u, 3300u).
    There's one other guy who noticed it (search google for 400PN high pitched).
    Did someone else notice this (maybe with other psu)? It's driving me craaazy.
  • gonzo0815
    • Feb 2006
    • 1600
    Re: FSP 350PN high pitched sound
    Probably one of the coils, either the PFC coil or the one in the output filter. I doubth that there is mutch to do than either using some glue or buy an non or A-PFC unit.
    • elod
      • Jul 2006
      • 8
      Passive PFC is really easy to remove. I'll open it up once more and try to locate the source.
      Heatsinks are really small, so i tugged a thermocouple in between. 40 C, under load (A64 Venice, 2.4Ghz, GF62000 - yeah, pretty lame).
      • Spacedye69
        • Nov 2005
        • 698
        • US
        Not that this is any help, but I have a similar problem on a Lite On made Dell psu. The whine starts when I plug it in, and stops after what seems like a cap discharge, slowly going down in pitch, after I unplug it. Caps look ok, but it is pretty old. All UCC and Pubycon from what I can see.
        • tiresias
          • Feb 2006
          • 489
          • Spacedye69
            • Nov 2005
            • 698
            • US
            LOL
            • elod
              • Jul 2006
              • 8
              Mine is dead silent in standby. It starts when i push the damn button. Today I saw an enermax doing the same thing. And the owner doesn't even notice it. In 10 years maybe I won't hear it anymore.
              I've got to check the discharge thing. Even stanger is that I did not notice the noise when it sat before me.
              Tomorrow is psu hacking day. Again. I've got an Antec to service (my first repair - i hope), I know it's not worth it (SmartPower SL350), doing it for experience .
              • elod
                • Jul 2006
                • 8
                Apparently it's NOT. And it's not the passive PFC. It seems to be the stand-by transformer. When I measure the voltage on the big diode nearby the sound changes in pitch. The same thing happens when I start start the unit.
                Just as Spacedye69 said, it goes away slowly (discharge) if i pull the plug.
                Damn PSU makers. They can't even buy a decent enough transformer. The 3 main transformers are labeled "DASH 2 B-5". Don't know if that specifies the manufacturer, but I want them to suffer .
                Has someone got a recent Fortron to confirm the noisy stand-by transformer?
                • tiresias
                  • Feb 2006
                  • 489
                  Hi Elod,
                  Yes, one of my kids' machines uses a slightly older FSP-300PN (PF) model, and it does have a small degree of buzzing. It is very quiet though, hardly something you would notice unless you were to place your ear very close and really listen out for it.
                  I had always assumed it was the large passive PFC coil, but now that you mention it - you could be right about it being the transformer for the +5Vsb line.
                  All small ones are marked DASH-something indeed. The main one reads "SPI..."
                  • elod
                    • Jul 2006
                    • 8
                    Originally posted by tiresias
                    Hi Elod,
                    On the side of the transformer "SPI 8TC00206". This is the small one (stand-by). The big one is "SPI 8TG00212". DASH is on the last line, don't know what it means.
                    Well, I can hear it from across the room. Not when it's in stand-by, but when it's on. It's definetly not the PFC coil. I removed it, listened to it while on, it's completely silent.
                    Thanks for replying. At least I know that it's not just mine.
                    Tips for another, SILENT & cheap but reliable PSU? I really liked this one, because it's really cheap, and I don't want to invest a fortune in another psu, after 2 antecs caused me trouble (one exploded, the other one had one leaky Fuhyjuu cap).
                    • tiresias
                      • Feb 2006
                      • 489
                      Well, as you can probably see from this section of the forum, one could talk forever about the ideal PSU for an particular situation.
                      Personally, at the moment I would recommend (if you're willing to spend over $100), one of the Etasis-made Silverstone-marketed models, such as the ST56ZF. The ST75ZF is more expensive, but you only have to look at its components, specifications, and also importantly, PCB layout, and you'll see that it's in a class of its own.
                      In the more affordable (sensible) range, which I think is what you're looking for, I've always been quite pleased with the Enermax-branded units. If you take a look at their "noisetaker' series, they should make a 325W, or 375W rated model for a good price.
                      • PeteS in CA
                        • Aug 2005
                        • 3583
                        • USA, Unsure of Planet
                        P/S mfrs usually design and build their own transformers. Most SMPSs switch at 25KHz or higher, and should not be audible. The exceptions I've heard have been where the P/S was in current limit or was oscillating due to a design goof or a wrong componet was used. One recent exception to this with which I have no experience is regulator IC that reduce the switch frequency to improve efficiency at light load or when operating in standby mode. I realize that this doesn't accord with the experiences of many folks here.
                        PeteS in CA
                        • Shroomie
                          • Apr 2006
                          • 356
                          Ditto. I have the 420 - haven't opened it up yet, I know some of the smaller caps are the mediocre jPce TURs, but I'm not too concerned. It seems like a good quality unit, fairly heavy, and is basically silent. I'd recommend one.
                          I've heard great things about Silverstones, too. Cost is high, but arguably worthwhile.
                          It's really sad to see Fortron/Sparkle go downhill like this - the Fuhjyyu caps were bad enough. Sharp contrast to their older models, heavy 200-watters from '98 and '99 with all Chemi-Con caps. Decent fans, too.
                          You know there's something wrong when you open up a PSU and are glad to find Teapos.
                          Why I don't buy cheap cases!
                          • kc8adu
                            • Nov 2003
                            • 8832
                            • U.S.A!
                            check for loose cores in the transformers/chokes.
                            i have seen a few that were loose that would annoy me enough to pull out dr. glock and shut it up.
                            ca can be squirted in and hit with zip kicker.
                            • elod
                              • Jul 2006
                              • 8
                              Nothing seems to help. I've poked around many times, with a rubber-ended pencil, no loose cores, no change in the annoying noise.
                              I've been to the shop today, and listened to another one, it's the same thing. Unfortunately they did not have a Greenline, so I couldn't check that series.
                              I'll buy a greenline & a seasonic S12-430 for two new builds, just to see how they compare, and if any of those makes strange sounds.
                              • gonzo0815
                                • Feb 2006
                                • 1600
                                Think both a great units, IMHO all A PFC, wich means no big PFC inductor. I think they should suite your needs, especially the Seasonic one.
                                • LEECH666
                                  Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                  by LEECH666
                                  Good day ladies and gentleman!
                                  I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                  This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                  I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                  01-19-2024, 05:46 PM
                                • Christos Tsiligiannis
                                  Marian Trace Alpha sound card repair help
                                  by Christos Tsiligiannis
                                  Hello to the forum.
                                  My name is Christos, I am new to the forum here and i am posting from Greece.
                                  So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                  To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                  So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                  11-18-2024, 05:26 AM
                                  HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                  This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                  09-12-2024, 02:30 PM
                                  HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
                                  HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
