Split apart ferrite cores of SMPS transformers?
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    How do you go about splitting the two ferrite 'E' pieces, without breaking one or the other?
    I need to make a transformer for an analogue ESR meter, and I have a few small SMPS transformers to harvest the cores from.
    Muh-soggy-knee
  • kaboom
    "Oh, Grouchy!"
    • Jan 2011
    • 2507
    Re: Split apart ferrite cores of SMPS transformers?
    Soak it in mineral spirits, laquer thinner, or naptha, in a small container.
    I used a combination of mineral spirits and vodka for some cores.
    Let them soak for a few hours- nothing will appear to happen at first. After 24 hours, most should come apart. Sometimes, you can remove the tape that covers the finished windings. It'll help whatever solvent soak in better.
    Also remove the tape that covers the outside of the cores. This helps penetrate the varnish seal at the edges of the two E's. The middle leg of the "E" naturally takes longer.
    -Paul
    "pokemon go... to hell!"
    EOL it...
    All style and no substance.
    guilty,guilty,guilty,guilty!
    guilty of being cheap-made!
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      -Paul
      Ok, I removed the tape from the ferrite core, and put it in some paint thinner (mineral spirits).
      Will see how it works, in a day or two.
      Muh-soggy-knee
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Woo!
        It worked well!
        I put two transformers in.
        One did get a small crack in the ferrite when taken apart.
        The other came out perfect!
        That paint thinner smell lingers though
        Muh-soggy-knee
        • dkneyle
          Onkyo DX-V500 Laser Disc Player - weird SMPS fault
          by dkneyle
          This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
          Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
          02-01-2022, 02:08 AM
        • abhishekkumar1902
          Huntkey HK340-72FP SMPS shut on load above 2 amps
          by abhishekkumar1902
          I have this Huntkey HK340-72FP PC SMPS where I am facing a strange problem where the SMPS shuts down when the load on any of its 12v output rails goes above 2 amps while the rating of each 12v rail is above 10amps capable.
          I have checked the following:
          1. All output caps are OK, and all output rails read correct voltages at no load
          2. All output diodes are OK
          3. NTC is ok
          4. Hi voltage cap on input correctly reads 150uF on LCR meter per the spec, also the bridge rectifier is OK
          5. No short in main switching MOSFET
          6. All other components...
          12-18-2022, 09:52 AM
        • rewease
          Replacement for the Siemens Bakelite caps in an early 1980s SMPS
          by rewease
          There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
          Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
          Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...
          09-17-2023, 12:53 AM
        • dkneyle
          MK1210 chip SMPS based supply - can I fire this up?
          by dkneyle
          Power supply used in an Onkyo laser disc player, circa 1995?
          Came into the Repair Cafe after another tech had a go and gave up. Only evidence I could see of a repair was C22 (2200uF) cap had been changed and D25 was missing. The power plug had been left disconnected so I figured I wasn't going to apply power until I'd checked everything out. I replaced the usual suspects: the SMPS chip ML1210, all the electros except the main charge caps, the 33V zener, replaced the missing high-frequency rectifying diode. I meticulously checked over remaining components with my meter and all seem...
          01-30-2022, 01:44 AM
        • ketone
          SMPS - Can they all handle wide range of Input Voltage?
          by ketone
          Hello Forum - See I got this SMPS Module!....its sourced from a US device and I'm in Australia.
          As we know Supply voltages in Australia 240v Versus 120V US.
          The Model of the SMPS is EAX39561401 and is used in LG and JVC DVD/VCR Player/Recorders...same model is used in both Australia and US...but perhaps they have differences??
          What's the chances I can use it in Australia - plugging it in to 240v instead of its origin country at 120v?
          Is it expected that most SMPS in such devices would handle between 100-240V by default?
          How can I...
          12-17-2022, 02:40 AM
