Trust PW-5150 370W
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Trust PW-5150 370W
    I don't know if anyone of you is familiar with that name. I got that power supply from a friend, he told me his computer stopped working.
    By the time I opened the case it looked familiar. Either Macron Power is the OEM or they copied them. Just compare the add on board of MPT-350 and Trust, the layout of the PCB, the spot of the fan connector, the 5vsb output caps and choke, etc.
    Even the psu case is the same, apart from the black paint.
    "XHY-300AB", the PCB code is located at the same place where the MPT-301 and MPT-350 have "ATX991 2P Macron Power".
    But is it a decent power supply?
    -The input filter is ok but there are no MOVs.
    -3A diodes instead of a bridge rectifier. I could forgive that.
    -2x470uF 200V CS caps. Real capacitance is 352uF and 323uF. I call those 330uF caps.
    -2x 13007 switching transistors. This is more like a 250W (300W peak) unit, not 370W.
    -Good ERL35 transformer
    -3.3V: S20C45C (20A), 2x2200uF 10V BH caps. Good to see 2200uF caps on a psu like this.
    -5V: S20C45C (20A), 2x2200uF 10V BH. The 30A the label claims is just a lie.
    -12V: U20C20 (20A) 1x2200uF 16V BH
    All the caps are BH, except a Sapcon 100uF 50V and the CS primaries. 2 10uF 50V BH caps are bad with esr up to 20ohm when the maximum allowed is 3.5ohm. There is severe heat discoloration on that area. Maybe that's the reason it stopped working.
    There is something really nasty on the back side of the PCB, something like glue that is very difficult to clean...
    One of the two 13007 gives me a short between Base and Collector. Is this normal or it needs to be replaced?
    Re: Trust PW-5150 370W
    I have seen them a lot in the UK; I would say they make a lot of stuff, but more than certainly they just import re-branded junk.
    • Wester547
      • Nov 2011
      • 1268
      • USA.
      A number of BH capacitors lie about their capacitance (primaries, AFAIK and as stated, but that could extend to secondaries) so those '2200uF/10V' capacitors on the secondary may be 1500uF/6.3V/10V. Some parts in this PSU look like they have merit in keeping and it may be worth a repair but it generally looks like junk...
      Looking at how this PSU measures up it looks more like a 200W PSU continuous, 250W peak... at least that's how I'd rate it. And that glue on the PCB is conductive.
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        I took it out to test it... It's semi-shorted. Time to find a replacement...
        • lti
          • May 2011
          • 2557
          Originally posted by Wester547
          BH capacitors lie about their capacitance so those '2200uF/10V' capacitors on the secondary are probably 1500uF/6.3V/10V.
          I have a BH 470uF 35V cap that measures 479uF, and it has had 36V applied to it without any problems.
          • goodpsusearch
            • Oct 2009
            • 2850
            • Greece
            I found a replacement transistor from a dead psu, it's a E13007F. It is in TO-220F package and the collector dissipation is only 40W, when the original was 13007 in TO-220 package with 80W dissipation...
            1) What impact this could have on the psu performance?
            2) Is there a problem that the two 13007 transistors on the power supply are not be identical?
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              Yeah, looks more like a 200W continuous, 250W peak PSU to me. Not worth new caps IMO (although old but tested-good Teapo and Ost would make a nice upgrade for this PSU).
              The 5VSB looks like it's about to go south. Check the 5VSB voltage under all loads. If it hisses, whines, or makes weird noises with a 1 to 2A of load, it's time to replace the output filter caps on the 5VSB along with the controller supply filter caps, even if they all look good. If the 5VSB still makes noises afterwards, those ceramic caps on the primary of the 5VSB circuit are the next suspects. At that point, though, I would just say it's not worth it unless you're really desperate to get a working PSU .
              1) Probably won't be able to pull as much power out of the PSU - if it works at all. I never tried it.
              2) Not sure, but I don't think it's a good idea. Best to replace them in pairs. While you did find the shorted one, the other one could have failed open.
              A few other things worth mentioning:
              - The E13007F is in an insulated TO-220 package, which won't allow it dissipate as much heat on the heat sink as the regular metal tab TO-220.
              - Check the snubber diodes across those switching transistors - they may also be shorted or intermittent. If in doubt, replace them. They need to be of the ultra-fast recovery type, rated for up to 1000V. They usually are 1 or 1.5A on these generic PSUs.
              • goodpsusearch
                • Oct 2009
                • 2850
                • Greece
                First of all thanks for the detailed answer!!!
                I checked all the capacitors on that psu and only the 2 10uF 50V BH were found bad and I replaced them with G-Luxon I am not going to waste good caps on that thing.
                I checked the diodes and the non shorted 13007 and found them good.
                Time for AC test
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  You're welcome.
                  Hm, I wonder what caused all of the darkening on the 5VSB then. Probably the ceramic caps going out of spec or just the circuit was designed badly.
                  Time for AC test
                    If ceramic caps get hot YOU'RE DOING IT WRONG!
                    Seriously, they have nearly zero ESR. Their ESR is as close to a metal conductor as you can get; they are just layers of metal and ceramic insulator. It's close to 0.5mohm for 1206 size devices.
                    More than likely it's simply the MOSFET getting hot... remember it's mostly in use during standby, when the power supply fan is off so there's limited cooling from the heatsink and a lot is dumped into the PCB.
                    • goodpsusearch
                      • Oct 2009
                      • 2850
                      • Greece
                      It works
                      You are right. The NPN transistor used for 5vsb is BU3150, with collector current 3A continuous at 25C, not so good. And the tiny primary heatsink doesn't help.
                      Originally posted by momaka
                      You're welcome.
                      It all makes sense now that I powered that thing. The fan controller sensor is attached to the secondary heatsink that stays fairly cool, while the primary heatsink gets too hot to touch even without any load! The fan nearly moves any air...
                      I am going to mod the fan-controller. Then it is going to be a quite decent 230W-250W psu.
                      • Behemot
                        • 4845
                        • CZ
                        You may wanna try to swap the 13007's for some more decent transistors. They will likely produce less heat too.
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          It works
                          Nice! . I like it when kludge repairs unexpectedly work.
                          Hm. I don't mean to be negative, but I don't think you'll make it even to 200W with that insulated-tab TO-220 E13007F transistor - not for too long anyways. More like 100W to 150W max.
                          • goodpsusearch
                            • Oct 2009
                            • 2850
                            • Greece
                            I put Arctic Silver 5 between the E13007F and the heatsink to improve contact.
                            But the E13007 needs to be insulated with insulation tape, and this has also an impact in the heat transfer from the E13007 to the heatsink. This makes me believe that E13007F is not that much worse. Please correct me if my thought is wrong.
                            Another good thing is that I took the E13007F from a dead Enlight 250W and those Enlight psus seemed honest about their ratings.
                            About the fan mod, I put a 5.6Kohm in parallel with the thermistor and the fan gets 10V-12V instead of 6V-7V. It is not a silent power supply anymore, but the air is still warm, due to the primary that gets hot.
                            Overall, I don't think it will do 250W. The primary heatsink gets too hot, even with psu off and 3W load at 5vsb......
                            I would replace the primary caps with 680uF and the transistors with E13009 in TO-3P package, maybe replace the primary heatsink as well and do a full recap on this thing, but it is not worth it when I have some Jou Jye 400Watt psus waiting for recap.
                            Thank you all for your help
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              You may be right then.
                              IMO, something is definitely wrong with the 5VSB then. To get the primary heat sink that hot, the 5VSB must be dissipating at least 3-5 watts. So it's probably doing less than 50% efficiency!
                              I know 5VSB circuits aren't generally too efficient to begin with, but I think this is just crap!
                              I wouldn't put it in a computer (that I cared about) if I were you.
                              By the way, why not pull parts from this PSU instead and fix the Enlight PSUs?
                              • goodpsusearch
                                • Oct 2009
                                • 2850
                                • Greece
                                Is is usual for me to see power supplies that get too hot when off. That's why I advice all my friends and people I know to turn off theis computer completely.
                                On that psu they should have used a better 5vsb transistor and better heatsink..
                                A friend gave me an Athlon 64, gforce 7300 with a dead K-Mex and he doesn't want to pay for a decent recapped psu. Guess what I am giving him for free
                                I have 5 or 6 Enlight psus. 2 of them are used for parts, the other ones are keepers. They are decent power supplies but they are clearly designed for 5V PCs: 10A rectifier on 12V, 1A label rating for 5vsb, they even miss the ATX 12V connector.
                                Due to the financial crisis here in Greece no one is interested in good power supplies anymore. When their old psu fails they just buy the cheaper they find. Then they buy another one...
                                • ben7
                                  Capaholic
                                  • Jan 2011
                                  • 4059
                                  Yes, those two transistor designs aren't that efficient.
                                  It would have to be pumping out at least 10W of heat to make that heatsink burning hot... with only a 3 watt load.
                                  Muh-soggy-knee
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    • Bulgaria
                                    Most 2-transistor 5VSB PSUs do run hot indeed, though not THAT hot. The IC-based ones run fairly cool, however. And they have very decent efficiency. I have only a few of these so I leave them on. The 2-transistor ones I turn off from the back when I'm not using.
                                    It wouldn't have helped much. If the circuit is still as inefficient as it is now, there would still be that much heat to dissipate regardless. The only difference is that the heat wouldn't be as "concentrated" on the components and would be dissipated better with the bigger heat sink. That might save the PCB from burning, but it still doesn't fix the original problem.
                                    I actually have an old Morex 235W PSU that has its 5VSB transistor mounted on a tiny heat sink - similar to the Enlight PSU you showed above. With a 1.1A load (PSU is rated for 1A on 5VSB), it runs hot - but not burning-hot. And that 2-transistor 5VSB doesn't have any caps on the primary either. So apparently it was just designed well.
                                    Well, in that case, what you're giving him looks A LOT better than what he had .
                                    I think I will stop with my complaints about the 5VSB of that PSU now .
                                    Probably true. I didn't want to sound too pessimistic, though .
                                    • spleenharvester
                                      • Mar 2010
                                      • 921
                                      Hehe, old thread I know, but I have one of these that's 8 years old and still running perfectly. It's been on an 8800GT with E2140 for some time now. Just goes to show the odd crap brand box can surprise you!
                                      Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
                                      • Pentium4
                                        CapXon Be Gone
                                        • Sep 2011
                                        • 3741
                                        If you haven't replaced the caps yet, you should! I think this thing has potential, usually if a PSU has a 35 transformer, it's worth upgrading. Bigger input caps, 13009's, 20A schottky's in parallel for the 12V and you've got a nice *inefficient* 350W PSU Although the main toroid is a little on the small side
                                        • madan1
                                          Aaand that is why I have trust issues..
                                          by madan1
                                          Finally managed to find some time (and will) to replace my "temporary" ghetto full bridge rectifier, removed the diodes, soldered the new one (of course according to its polarity), powered the unit and after few pops the magic smoke escaped. Right, must have done something wrong, install a new one, check for shorts and bad regulators.. power on.. and again the familiar popping sound, but this time managed to cut the power before the magic smoke had escaped. After several hours of wild goose chase I found that the polarity of some of the brand new rectifiers was reversed.. so just keep...
                                          11-20-2023, 03:25 PM
                                        • Pentium4
                                          LC Power LC420H-12-US (office series) rebuild
                                          by Pentium4
                                          I'm sure some of you are familiar with this brand who normally is in Europe. I want to use this in a very low powered system. The PSU in this system now is way overpowered and I want to use it for something else.
                                          This system at its peak uses a mere 75W so this thing will be fine I believe. However, I do think it needs some modifications.
                                          Overhead shot:
                                          Look at those input wires! Nice. They're all 18 gauge with lots of insulation. The input is solid and is only missing MOVs. Speaking of, does someone know of a MOV part that I...
                                          08-04-2023, 11:00 PM
                                        • Topcat
                                          MajorGeeks / Simplix Win7 Rollups - Trust or Not Trust?
                                          by Topcat
                                          https://www.majorgeeks.com/files/det...pdatepack.html
                                          Seems its a liked rollup.....but when the support site for it is in Russian, lets just say I'm skeptical. I've rolled it out on a couple test systems, nothing exploded....but what's the man behind the curtain done that isn't known? What's say any of you?
                                          10-05-2021, 09:45 AM
                                        • elpiko
                                          Trust 40 no backlight
                                          by elpiko
                                          I got a trust 40 inch tv when power no backlight not turning on.but I can see logo if I use a flash light on screen. So I when to check the led strips one by one and all light up fine. Now on my main board just before the led ligh connector the m7 diode is shorting. but when I remove the diode from circuit no short.im suspecting the led driver ic OB3350 any idea?
                                          12-19-2020, 03:09 AM
                                          Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
                                          by momaka
                                          This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
                                          Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
                                          Macron Power Technology Co. LTD.
                                          Let’s look at the PSU itself.
                                          The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
                                          06-02-2021, 10:05 PM
