Just fixed the 5vsb of a Spire 600W PSU (decent construction, but really crappy caps everywhere, considering a full recap but will have to ask the owner first). It was made with a 3842 and i thought i'd share how i fixed it.
Output caps were both bloated, replaced. No go. Switching MOSFET tested fine. I found the startup cap bad too. Not bloated, just dry. No capacitance. Replaced and Vcc still sat at 8.9v and the controller did not start up, no output, no Vref. Checked startup resistor - measured at 150kOhm which is exactly what the color code said. Checked all pins of the 3842 for shorts to GND or Vcc - nothing.
Then i decided to measure the current consumption. So i lifted one end of the startup resistor and set my meter to mA. It read 3.7mA. The datasheet says that 1mA is enough to start the reference regulator. So i replaced the 3842 and hey presto, 5vsb is up.
The rest, i'm leaving for tomorrow. The owner had already replaced a few caps, i pulled both heatsinks and replaced the remaining bloated caps in the secondary. I'll swap out some of the small caps too before i put the heatsinks back on.
PS. Add Jenpo to the bad caps list. Even the primaries were bad, and this PSU doesn't even have dust in it, it's almost brand new. It does have APFC tho.
