Quick 3842 troubleshooting
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Just fixed the 5vsb of a Spire 600W PSU (decent construction, but really crappy caps everywhere, considering a full recap but will have to ask the owner first). It was made with a 3842 and i thought i'd share how i fixed it.
    Output caps were both bloated, replaced. No go. Switching MOSFET tested fine. I found the startup cap bad too. Not bloated, just dry. No capacitance. Replaced and Vcc still sat at 8.9v and the controller did not start up, no output, no Vref. Checked startup resistor - measured at 150kOhm which is exactly what the color code said. Checked all pins of the 3842 for shorts to GND or Vcc - nothing.
    Then i decided to measure the current consumption. So i lifted one end of the startup resistor and set my meter to mA. It read 3.7mA. The datasheet says that 1mA is enough to start the reference regulator. So i replaced the 3842 and hey presto, 5vsb is up.
    The rest, i'm leaving for tomorrow. The owner had already replaced a few caps, i pulled both heatsinks and replaced the remaining bloated caps in the secondary. I'll swap out some of the small caps too before i put the heatsinks back on.
    PS. Add Jenpo to the bad caps list. Even the primaries were bad, and this PSU doesn't even have dust in it, it's almost brand new. It does have APFC tho.
    A working TV? How boring!
    Re: Quick 3842 troubleshooting
    3.7mA across 150k is ~550V; so no wonder it didn't start. Odd failure there... it must have become leaky. Might have worked in the early stages on high line voltage or at certain temperatures.
    I still remain skeptical that APFC cooks caps. In many cases the ripple current should be lower. The difference is it's at a higher frequency, so general purpose primaries are a no go - something like Hitachi-AIC HV caps are good, and they're relatively cheap.
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      The resistor dropped exactly 357.3v at that 3.7mA. PFC voltage is 367v. As for the caps, they were just crap, finding a bunch of bloaters (and some that failed without bloating) in an almost new PSU clearly says something about their quality.
      The PSU is very interesting, i'll post some pics in the build quality pictorial. It uses half bridge topology with BJTs, classic circuit with TL494 and LM339, they just added an APFC stage before it. However, it does look like it has enough beef for 600W - the transformer and inductor are large, the rectifiers are overspec'd by a healthy amount, and there's a 120mm fan on the bottom, as well as a 80mm on the exhaust. The soldering is crap tho. I think it is Sirfa who made it.
        I have a 500W power supply with active PFC which uses the same half bridge topology. Mine is stuffed with crappy Teapo everywhere, primary and secondary.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          The OEM is actually Topower - it's got TOP written on all the transformers, and there's also TOP-600P5 written in tiny text on the label. I'll put up pictures shortly.
          I guess Spire asked them to use cheap caps - it's the same platform as used here, and i don't think Hipro would accept to use such low quality capacitors. Spire blew all their budget on those fancy cables...
            Mine is a HIPER. Maybe a pretend "Hipro". If/when I recap it I'll try to figure out the OEM.
            • Pentium4
              CapXon Be Gone
              • Sep 2011
              • 3741
              Do you still have these pictures to upload?
              It's probably Andyson. I have a Hiper unit with some bloated Teapo, and it's made by Andyson
              • blues_spirit
                practical courses for troubleshooting pc motherboards
                by blues_spirit
                Hello from France,
                mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
                Do you think this is feasible for me? I...
                12-18-2022, 12:56 PM
              • flyhotstuff
                Alienware m15 r6 not charging.
                by flyhotstuff
                I bought this laptop sometime ago with an issue of it not detecting the battery but would work only with the charger, eventually, I found the problem was a missing resistor and replaced it and fixed the trace to it, it would detect the battery, but it would still not charge, it would detect the charger but fake charge. I recently moved so I did not have my regular microscope, I used a digital microscope I had to reflow/retouch the contacts of PUB1 which is an ISL95522A. I did not realise that I had bridged pins 16 and 17 and when connected to the charger, it blew the IC and the 10a (PRB13) resistor...
                03-19-2025, 11:41 AM
              • MicroSMD Lab
                MSI MS-16W1 no power, EC replaced by other.
                by MicroSMD Lab
                Hi, I'm working on a MSI laptop, Motherboard number MS-16W11, GF-65 Thin 10SDR-459US. Went to another shop because the screen was flickering, but it was working well on an external monitor. The LCD was ordered and the laptop was returned to the customer and it no longer worked. It was then sent to another tech (by the shop who ordered the LCD) and the EC (ENE KB9028Q) was replaced with a donor from another MSI board with different board number and no programming was done. It looks like work was done on PU6 (TPS51225) as well as one of the GPU mosfets was burnt (I removed all three GPU mosfets)....
                03-27-2025, 07:35 AM
              • dougg3
                Faytech FT0150TM touchscreen turning on and off - fixed
                by dougg3
                I've been dealing with this 15" touchscreen monitor from the early 2010s. Over time, it has become more and more difficult to power on. As soon as a video signal comes in, the Faytech logo appears on the screen and then it goes black. Then a couple of seconds later the Faytech logo comes back up on the screen and it goes black again. This process repeats over and over again. Eventually if I leave it on long enough, the video display finally comes up and it works fine. The longer I leave it turned off, the longer it will boot loop before working correctly again. I tried a different AC adapter...
                02-03-2024, 03:04 PM
              • Reintar
                Dell Inspiron 15 7567 (LA-D993P) - No power after replacing blown inductor and shorted mosfet advice needed
                by Reintar
                First of all, I'd like to mention that I'm a novice when it comes to laptop repair, although I do have some experience with soldering.
                One day, my laptop experienced a severe stutter, and after rebooting, it failed to boot into Windows. I decided to disassemble it and found that the PL900 component was blown. Later, I came across a post (https://www.badcaps.net/forum/troubl...error%E2%80%99) with the same problem, where...
                08-30-2024, 06:13 AM
