Supermicro PWS-0060 *failure*, please advise
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    #41
    Re: Supermicro PWS-0060 *failure*, please advise
    About the revision question:
    I see where yours has "REV 3.0". My unit has nothing there, ie. just white space on the label.
    means either it is revision 1.0 or someone forgot to put the revision. if it was fake it would not have those caps.
    • Super Nade
      • Jun 2006
      • 294
      #42
      I was joking mate.
      I think the connection may have been loose. I'll have to check it again. Currently burning in components. Man, do I miss AMD or what. Stupid Multi locked Intel.
      Q6700 @ 3.6 GHz
      Zippy GSM-6600P
      Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
      Abit IP35Pro
      ATi HD4870
      • tiresias
        • Feb 2006
        • 489
        #43
        Hehe - funny expression. Sounds scary.
        • Super Nade
          • Jun 2006
          • 294
          #44
          O.K. Absolutely confirmed. The 12V line drops to 0.888 V and then I'm stuck in a reboot loop. The VCore I am applying is 1.55V. Now remember I have almost no load on the 5V and 3.3V lines.
          I'll add a few HDD's and see what happens.
          Q6700 @ 3.6 GHz
          Zippy GSM-6600P
          Abit IP35Pro
          ATi HD4870
          • tiresias
            • Feb 2006
            • 489
            #45
            Hmm... That's very odd! Wouldn't Jonny have noticed such a disastrous issue during his tests though?
            Also, hang on a minute...
            Why should a reboot have that effect on the PSU?
            • Super Nade
              • Jun 2006
              • 294
              #46
              I have to hurry home now. But here is a really bad video of what happens. Sorry I can't use lights as I'm working with IR lasers and I need to take data. I will take a better video when I get back from home.
              This happens as memtest is loading, not when it reboots. It reboots because of PSU failure, I think. It reboots exactly when the voltages start dropping like crazy. I hope this unit does not take out my mainboard.
              mvi_0048.avi
              Q6700 @ 3.6 GHz
              Zippy GSM-6600P
              Abit IP35Pro
              ATi HD4870
              • tiresias
                • Feb 2006
                • 489
                #47
                I see it! Bizarre - it's as if the PSU goes out for a moment.
                The strange thing is this:
                On the one hand:
                Many people, including a contact of Galvanized who owns a server farm, have seen these PSUs run dual Xeon servers 24-hours a day, with not so much as a hiccup. Supermicro themselves recommends these units for remarkably powerful and high-end workstations, such as FBDIMM equipped dual Woodcrest boards!
                And yet, on the other hand:
                I have a unit that fails after months of really light use (which could just be the odd lemon, OK).
                And now you're seeing something extremely odd yourself.
                Could this be some kind of incompatibility? As in, the PSUs are very solid, but don't entirely fit the EPS standard, and are specially designed for Supermicro boards, and can have problems in other setups?
                What do you think?
                • Galvanized
                  • Mar 2006
                  • 468
                  #48
                  Minerva has not answered my PM of a couple days ago...She has not been on.
                  There is a minimum load spec for the 3.3 & 5V lines. I want to see what happens when that's met. I got 15 of those 2ohm@25W ceramic ballasts here, wish I could toss you a few. bgmicro.com for $0.49 each.
                  • jonnyGURU
                    • Feb 2006
                    • 244
                    I think I had what could be considered at least minimum load on the 3.3V and 5V rails and saw that same drop in the 12V that Super-Nade is seeing.
                    Rest in peace BFG. You were... a job...
                    • tiresias
                      • Feb 2006
                      • 489
                      #50
                      All the way to zero? I know you mentioned there was a sharp 0.1V drop, but Super Nade's unit seems to be practically shutting off for a moment...
                      • jonnyGURU
                        • Feb 2006
                        • 244
                        No. Not all of the way to zero. But a significant drop just the same.
                        Perhaps Super-Nade's hard drop was, as GY stated, due to even less of a 3.3V and/or 5V load as me. But I had a load on all rails none the less.
                        • Super Nade
                          • Jun 2006
                          • 294
                          #52
                          Well, I've collected 4 HDD's and 2 Opticals so far. I'm gonna load up the 3.3 and 5V till she explodes. I'll be on pretty late tonight, gotto finish up a paper, so hopefully I can keep you lads posted.
                          Hey Galvo, it would be great if you could toss me a few of those resistors. Do I need to actively cool them?
                          Q6700 @ 3.6 GHz
                          Zippy GSM-6600P
                          Abit IP35Pro
                          ATi HD4870
                          • Galvanized
                            • Mar 2006
                            • 468
                            #53
                            Sure! PM me an address and I'll drop some in the mail. Two in parallel would load the 5V by 5A and the 3.3V by 3.3A.
                            PCP&C sells a resistor to load the 5V line by 1A/5W and that helps stabilize a lightly crossloaded PSU. I'm going to make a lite-duty load tester for PSUs out of some of them, just to bench check voltages. One might go on the Zippy because the 5V rail puts out 40A and the 12V rail is 30A. Might need to do this if the 12V rail ever needs to be fully loaded.
                            They are 15mm in dia., 50mm long and are hollow tubes. Yes, I would activly cool them. Mount them over the case exhaust fan or over the PSU exhaust fan. Best would be inside the case...over the exhaust fan, I guess.
                            Oh! They take blade connectors...and I don't have any.
                            Update your profile. Where are you located? PM the address.
                            • Super Nade
                              • Jun 2006
                              • 294
                              #54
                              yhpm.
                              I'm trying to rip out as many HDD's I can from the computers lying waste in the department at my Uni. It's gonna take a while.
                              Q6700 @ 3.6 GHz
                              Zippy GSM-6600P
                              Abit IP35Pro
                              ATi HD4870
                              • tiresias
                                • Feb 2006
                                • 489
                                #55
                                I've discovered something else in the last hour that may be of interest...
                                The fan control board, on the 0060, is indeed more complex than you would expect. The functioning of the PSU itself depends on the presence of a connected fan - it's able to "notice" this even when it's using a two-wired fan (ie. with no tach output), probably by measuring current draw.
                                - With no fan connected to the two-pin plug, the PSU will turn on for an instant and immediately cut off again.
                                - If the fan is at any point disconnected, the PSU shuts everything off, except 5Vsb.
                                This makes fan modding considerably more difficult.
                                PS. I guess the designers of the PSU felt that it's better that the machine should cut off in case of fan failure, rather than continue running and risking damage due to an overheated PSU. It could be a source of PSU problems though, what with not following the "KISS" principle.
                                • Super Nade
                                  • Jun 2006
                                  • 294
                                  #56
                                  Mate, there is a 4 pin connector as well (thin wire), where should I plug that in? I have not plugged in any fan wires from the PSU to the MB. All the MB headers are 3-pin. Which one should I leave out? I could try forcing it into the CPU fan header (but the notches don't line up) and move the CPU fan power elsewhere.
                                  Q6700 @ 3.6 GHz
                                  Zippy GSM-6600P
                                  Abit IP35Pro
                                  ATi HD4870
                                  • Super Nade
                                    • Jun 2006
                                    • 294
                                    #57
                                    Very very weird. Now this is worrying me a bit.
                                    I have now attached, 1 Raptor 36Gb, 2 Opticals, 1 IDE. On the first attempt, I saw no crazy drop to 0V. On a subsequent Reboot, this phenomenon is repeating itself. I'm gonna try adding a couple of more HDD's, a few PCI cards and see what happens.
                                    Interestingly, I witnessed NO such problems with the DFI setup I have:
                                    DFI NF4 SLI DR
                                    X1800xt
                                    1 Gb BH5
                                    2 x Raptors
                                    1 x 120mm and 2 x 82 mm fans
                                    1 SB Live PCI card
                                    Is it the ASUS board which is messing up??
                                    Q6700 @ 3.6 GHz
                                    Zippy GSM-6600P
                                    Abit IP35Pro
                                    ATi HD4870
                                    • tiresias
                                      • Feb 2006
                                      • 489
                                      #58
                                      You could perhaps check that (at least in part), by measuring potential between PS_ON and ground. Now while the motherboard and PSU are on, potential should be always low (zero, basically).
                                      If the motherboard, for some reason would be 'tripping up' the PSU during a reboot, you might see PS_ON go high (usually 5V) just before the voltage drop.
                                      About the little connector - the 0056 has it, but the single-fanned 0060 does not...
                                      • Rainbow
                                        • Aug 2005
                                        • 1374
                                        #59
                                        Yes, the board might turn off the PSU for a moment during reboot. Some boards do weird things...
                                        • Super Nade
                                          • Jun 2006
                                          • 294
                                          #60
                                          So do I go ahead and jam the connector into the header?
                                          Anyway, I made a few more videos.
                                          This is what I'm running:
                                          http://www.zippyvideos.com/672126498...44/*snocforums
                                          This is what happens:- [FF to the end to see the same effect]
                                          http://www.zippyvideos.com/971291187...46/*snocforums
                                          Now, I'm thinking, maybe the Presscot is overvolted a bit too much. But that does not explain why the hell the 12V line should drop to zero? Absolutely no probs with the DFI setup. I'm gonna unplug and reconnect everything again.
                                          Q6700 @ 3.6 GHz
                                          Zippy GSM-6600P
                                          Abit IP35Pro
                                          ATi HD4870
                                          • Sus256
                                            HISENSE 65E7KQ PRO - no boot
                                            by Sus256
                                            Hi all!
                                            HISENSE 65E7KQ PRO
                                            RSAG7.820.13512 - chassis
                                            MT9618BAATAB - cpu
                                            RSAG7.820.12059 - power
                                            HD650Y3U77 - panel
                                            KLM8G1GETF - emmc
                                            Replaced emmc.
                                            Terminal log
                                            UART
                                            AC_ON
                                            E-B
                                            FDE enabled
                                            06-01-2025, 02:11 AM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
                                          • ctroxtell
                                            Carrier HK50AA063 display controller common failure help
                                            by ctroxtell
                                            I've got a control display for a Carrier chiller that I'm trying to understand what the common failure with these boards are. This is the board in question https://www.supplyhouse.com/Carrier-...arquee-Display all of them seem to develop a failure with the up and down arrow buttons on the right side of the display, the esc and enter keys I've never seen fail. Once these boards are plugged in they run 24/7, you used to have to press extremely hard with the end of the blunt screwdriver and you could still get the arrows to work but now it has completely stopped working. The button...
                                            02-05-2025, 05:31 PM
                                          • howardc64
                                            Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                                            by howardc64
                                            Problem
                                            Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                                            Model & Board Pics
                                            Conflicting Spec
                                            Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                                            https://www.shopjimmy.com/vizio-gj-2k1...
                                            10-10-2024, 01:16 PM
                                          • Topcat
                                            Topcat's Supermicro X10DAI Build - Plus NVMe BIOS Mod Inside
                                            by Topcat
                                            Yes, I know I don't post this stuff much anymore....the only reason I'm posting this one is because of a NVMe adapter incompatibility; seems rather planned by Supermicro.....or I'm atleast a bit suspicious. It's plenty new enough to have a UEFI bios but a short 'happy list' of NVMe controllers that will work with this board, as if by some 'miracle', all Intel....so lets start at the beginning; we'll get back to this later.
                                            Of course the motherboard is as the thread title states; X10dai....but we'lre going to have some fun shoehorning this into a modern 'gamer case' that can actually...
                                            09-29-2024, 03:55 PM
