Supermicro PWS-0060 *failure*, please advise
  • Super Nade
    • Jun 2006
    • 294
    Re: Supermicro PWS-0060 *failure*, please advise
    When you open it up, do you see any bad soldering?
    Q6700 @ 3.6 GHz
    Zippy GSM-6600P
    Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
    Abit IP35Pro
    ATi HD4870
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      i have seen a few liteon units with very poor soldering.
      fixed a neighbors liteon and when i pulled the pcb i commented it looked like a 2 year old with a cold iron and plumbing solder had built it.
      he commented that it looked like a mud dauber had been working on it.
      had one in a hp that had missing +3.3
      bad solder joints and crap caps.
      stay tuned for a ablecom dissapointment i got in last week.looks like a deer board inside!
      • Super Nade
        • Jun 2006
        • 294
        Wow man...doesn't look like the insides of my unit?
        The winding on the toroidal inductor, in the last picture is just garbage. Who-ever winded that coil should be shot.
        Q6700 @ 3.6 GHz
        Zippy GSM-6600P
        Abit IP35Pro
        ATi HD4870
        • PeteS in CA
          • Aug 2005
          • 3581
          • USA, Unsure of Planet
          If the +3.3V O/P is mag-amp regulated, it sounds like the transistor driving the mag-amp inductor is either shorted or turned full on by whatever is driving it.
          PeteS in CA
          • arneson
            • Sep 2005
            • 1267
            Originally posted by kc8adu
            commented that it looked like a mud dauber had been working on it.!
            Ha hahaha, does everyone know what a "mud dauber" is? Ha haha
            Jim
            • tiresias
              • Feb 2006
              • 489
              #26
              LOL Arneson.
              I always thought it was one of these wasps but now you simply *have* to tell me what I'm missing
              • tiresias
                • Feb 2006
                • 489
                #27
                Both the 3.3v and 5v have sense wires running back from the EPS connector to the PCB - can we assume that both be mag-amp regulated, or is something else at play here?
                • PeteS in CA
                  • Aug 2005
                  • 3581
                  #28
                  T, I don't have specific knowledge of this P/S, but unless it's a fairly high-end supply, I'm assuming it has a single main regulator, usually sensing the +5V and +12V. The other O/Ps are post-regulated - the -5V (if it has it) and -12V by 3-T regulators and the +3.3V by a mag-amp regulator.
                  Winding toroidal inductor with multiple windings with different numbers of turns and different wire gauges is seldom neat; making 10s of thousands of inductors a month is no mean task, either.
                  PeteS in CA
                  • tiresias
                    • Feb 2006
                    • 489
                    #29
                    Thanks Pete for your advice... I'll be taking a look at it more closely now - componentwise it really seems *very* solid, I'm expecting a poor solder joint somewhere or other soldering-related issue as KC8 warned.
                    The inductors on my unit aren't badly wound at all, in fact. It's probably luck of the draw, as you said.
                    • arneson
                      • Sep 2005
                      • 1267
                      #30
                      The bug is not so funny, but the nest is a big wad of crap, filled with larvae.
                      I'm still LOL.
                      Jim
                      • jonnyGURU
                        • Feb 2006
                        • 244
                        No comment on the inductor windings since I've seen a lot worse on a lot more expensive units.
                        As long as there's no "slack"....
                        Rest in peace BFG. You were... a job...
                        • Super Nade
                          • Jun 2006
                          • 294
                          #32
                          Guys, this is my first server unit. Any ideas on why there is no power switch? I'm still a bit bummed by this.
                          Q6700 @ 3.6 GHz
                          Zippy GSM-6600P
                          Abit IP35Pro
                          ATi HD4870
                          • tiresias
                            • Feb 2006
                            • 489
                            #33
                            Hehe... because servers shouldn't be turned off?
                            It can be annoying, yes. I had a separate switch on my surge suppressor for the socket to which I connected it so it wasn't really a problem. Perhaps you could do the same?
                            A question: does your 0056 model also have the fan running (at low speed) all the time, even when it's only providing 5Vsb?
                            • jonnyGURU
                              • Feb 2006
                              • 244
                              I can answer that: Yes. The fan runs all of the time. Fire up the PC and it spins full RPM for about two seconds and then comes down to a bout 75% RPM.
                              • Super Nade
                                • Jun 2006
                                • 294
                                #35
                                Roger that. Exactly as Jonny said. It is whisper quiet, when compared to my x1800xl's scramjet HSF. That thing (x1800xl) is so loud at start up that I could hear it outside my lab.
                                Jonny, do you think I would trip something up if I unhook the fans and rewire it so that both fans are being used? This redunantant fan stuff is not my style. If there is a fan I see, it should be spinning. I hate lazy ass fans.
                                Q6700 @ 3.6 GHz
                                Zippy GSM-6600P
                                Abit IP35Pro
                                ATi HD4870
                                • jonnyGURU
                                  • Feb 2006
                                  • 244
                                  I actually took one of eVGA 7800GTX's out of my machine simply because of noise. I'm eventually going to water cool the other.
                                  • Super Nade
                                    • Jun 2006
                                    • 294
                                    #37
                                    How long have you had the GTX? Maybe you can step it up to the 79xxx ?
                                    Q6700 @ 3.6 GHz
                                    Zippy GSM-6600P
                                    Abit IP35Pro
                                    ATi HD4870
                                    • tiresias
                                      • Feb 2006
                                      • 489
                                      #38
                                      About the revision question:
                                      I see where yours has "REV 3.0". My unit has nothing there, ie. just white space on the label.
                                      • Super Nade
                                        • Jun 2006
                                        • 294
                                        #39
                                        Fake! Fake Fake!!!
                                        Another very very strange thing I noticed. The 12V line dropped to almost 0V for a fraction of a second, when I rebooted the now OC'ed Prescott !!
                                        Config:
                                        1 stick of 1Gb DDR2
                                        1 7800GT
                                        1 Presscot @ 1.5125V VCore, 4160 MHz.
                                        WTF is going on here?
                                        Q6700 @ 3.6 GHz
                                        Zippy GSM-6600P
                                        Abit IP35Pro
                                        ATi HD4870
                                        • tiresias
                                          • Feb 2006
                                          • 489
                                          #40
                                          Surely it would have gone out had that been the case? Are you sure your multimeter/oscilloscope connection didn't come loose for a moment?
                                          • npielawski
                                            MacBook Pro late 2016 (820-00239) with multiple failure modes.
                                            by npielawski
                                            I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
                                            I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
                                            10-15-2025, 01:53 AM
                                          • puccovelli
                                            Dell 9310 Memory or RAM (Random-Access Memory) failure (2,4)
                                            by puccovelli
                                            Hi all, I hope this is the right place to post.
                                            I'm having a problem with a Dell 9310 which is posting 2 orange, 4 white lights on startup (hangs on Dell BIOS logo). The service manual says its a RAM failure.
                                            I've taken the motherboard out and noticed that one of what looks like an SMA 0805 resistor has blown (see photo). The board is an LA-J144P Rev 2.0(A01).
                                            1] Could someone confirm what the component that has blow actually is (and where I could get another from).
                                            2] Whether this component is likely to cause the RAM failure issue, and if replacing...
                                            10-11-2025, 06:30 AM
                                          • Sus256
                                            HISENSE 65E7KQ PRO - no boot
                                            by Sus256
                                            Hi all!
                                            HISENSE 65E7KQ PRO
                                            RSAG7.820.13512 - chassis
                                            MT9618BAATAB - cpu
                                            RSAG7.820.12059 - power
                                            HD650Y3U77 - panel
                                            KLM8G1GETF - emmc
                                            Replaced emmc.
                                            Terminal log
                                            UART
                                            AC_ON
                                            E-B
                                            FDE enabled
                                            06-01-2025, 02:11 AM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
                                          • ctroxtell
                                            Carrier HK50AA063 display controller common failure help
                                            by ctroxtell
                                            I've got a control display for a Carrier chiller that I'm trying to understand what the common failure with these boards are. This is the board in question https://www.supplyhouse.com/Carrier-...arquee-Display all of them seem to develop a failure with the up and down arrow buttons on the right side of the display, the esc and enter keys I've never seen fail. Once these boards are plugged in they run 24/7, you used to have to press extremely hard with the end of the blunt screwdriver and you could still get the arrows to work but now it has completely stopped working. The button...
                                            02-05-2025, 05:31 PM
