Delta DPS-800GB Power Supply No Power
  • mockingbird
    • Dec 2008
    • 5484
    Re: Delta DPS-800GB Power Supply No Power
    Maybe Delta underspec'd the parts required in that location... This is the first time I've heard about KZH and KZE not lasting...
    • Blerog
      • Nov 2011
      • 11
      I will have a look and see what the voltage across those caps is tomorrow. you could be right.
      • 261Jack
        Knowledge Seker
        • Dec 2015
        • 5
        Originally posted by Toasty
        Bad startup cap(s). First clue was NO standby voltage.
        Everything is Ruby's or Chemi-con's except the bloody one that fails which is an 100uF Ltec. Reads open, as in pF instead of uF...
        Nice job shootin' yerselves in the foot there Delta. jeeze...
        Fans need to be removed first. Then the power plug needs to be separated from the chassis. It is caulked in place -underneath- the socket. Joy. Xacto knife time. It then needs to be pulled out so its' wires can pass through the slot in the chassis while the main board is removed.
        It's a real bastard of a cap to get to because of the cramped conditions, and some super-fine wiring going to the daughter board. Trust me, you don't want to screw with them. (hair fine in Teflon® insulation)
        This is a double-sided board, so lots of heat (air) plus the hot vacuum desolder tool.
        The heat sink that needs to come out has a finned spreader that spans several components and must be removed first. Then the heatsink complete with the bridge, thermistor, and switchers on it. Once you get the thing loose and out a bit, loosen the bridge screw a bit and and swing it aside to expose the screw holding the thermistor. Remove the screw & nut and detach the thermistor so it does not get damaged.
        Replace both caps that are in the heat-shrink tubing, next to the daughterboard. (You're there, do you -really- wanna go back later for 50¢ worth of caps???)
        Reverse the above to reassemble.
        T
        T - My DPS-800GB turns on SOMETIMES - Pin 31 is connected to pin 34 - The fuse is good - I replaced the two [large] 270 mF caps - There is a click [I assume a relay] when the PS does start - I see only one cap [c232] next to the daughter board
        Your commits please, Jack
        • 261Jack
          Knowledge Seker
          • Dec 2015
          • 5
          T
          T - My DPS-800GB turns on SOMETIMES - Pin 31 is connected to pin 34 - The fuse and fans are good - I replaced the two [large] 270 mF caps [nothing changed] - There is a click [I assume a relay] when the PS 'does' start - I see only one cap [c232] next to the daughter board.
          • 261Jack
            Knowledge Seker
            • Dec 2015
            • 5
            Re: Delta DPS-800GB Power Supply comes on intermittendly
            [QUOTE=261Jack;619662]T - My DPS-800GB turns on SOMETIMES - Pin 31 is connected to pin 34 - The fuse and fans are good - I replaced the two [large] 270 mF caps [nothing changed] - There is a click [I assume a relay] when the PS 'does' start - I see only one cap [c232] next to the daughter board.
            More DPS-800GB prodding - - -
            I have the PS completely out of its case and sitting on my work bench - Every time I apply power I hear a faint click - If it does start, there is a much louder click [I think from a near-by relay] - Applying power from 80 to to 140 VAC makes no difference; neither does the line/neutral polarity - The PS starts an average of about 1 out of 4 attempts -
            All help is appreciated, Jack
            • Behemot
              • 4845
              • CZ
              #26
              Post some pics, there are none of this unit here.
              Do you have stable +5 V SB rail?
              • Toasty
                • Jul 2007
                • 4171
                #27
                Did you replace the cap that I wrote about in what you quoted...?
                T
                veritas odium parit
                • 261Jack
                  Knowledge Seker
                  • Dec 2015
                  • 5
                  T
                  Okay, I'm back on this project after a LONG recess. I have done every thing you mentioned down to removing the finned spreader. Neither one of the heatsinks will budge. Is there needed component desoldering that you did not mention?
                  • Toasty
                    • Jul 2007
                    • 4171
                    #29
                    IIRC - (It was 4 years ago...) The heatsinks have attachment points/legs that are soldered to/through the board. Did you unsolder those legs?
                    FWIW - $19 incl shipping on ebay with warranty. Nice to fix but... :P
                    T
                    veritas odium parit
                    • 261Jack
                      Knowledge Seker
                      • Dec 2015
                      • 5
                      T
                      Thanks, I'm looking for them now. How do I find you on ebay?
                      Jack
                      • Toasty
                        • Jul 2007
                        • 4171
                        #31
                        Search: DPS-800GB
                        T
                        veritas odium parit
                        • Rainbow
                          • Aug 2005
                          • 1375
                          #32
                          I have this PSU but with a different problem. Standby works but main power does not start. With the PSU installed in a server (2nd PSU removed), power button lights orange. When pressed, power supply fault LED illuminates.
                          The two offending caps seem to have good ESR in circuit. Could they cause this problem?
                          • Rainbow
                            • Aug 2005
                            • 1375
                            #33
                            The answer is no. Removed the heatsink (soldered on both ends, also Q804 and Q808 must be desoldered as they're screwed on) only to find that the two hidden caps are not crap. C820 is Nichicon, C904 is Rubycon.
                            • Rainbow
                              • Aug 2005
                              • 1375
                              #34
                              I've also changed KN4401S (ZUA) transistor on control board as seen here:
                              https://www.rom.by/forum/Problema_s_...-800GB?page=16
                              (use Google Translate)
                              It tested bad (one PN joint open) before replacing. But replacing did not help. Server powered up for a moment, then shut down. Looking with cover open, saw that one fan does not spin!
                              Removed fans, connected to 12V - both worked fine. Connected back, tried again - server runs. The fans GND and 12V pins are connected in parallel on the control board - so it must be the fan, randomly not working.
                              • PeteS in CA
                                • Aug 2005
                                • 3581
                                • USA, Unsure of Planet
                                #35
                                If the PSU is controlled by a microcontroller, it might be sensing a fan failure and shutting down the PSU. Is the harness to the fan 4-wire (+12V, Return, PWM, and tachometer)? It may be that the fan is not receiving the PWM signal or is not providing a tachometer signal.
                                PeteS in CA
                                • Rainbow
                                  • Aug 2005
                                  • 1375
                                  #36
                                  Yes, most server PSUs have fan failure detection and will shutdown instead of overheating and catching fire. The fans are connected using 3 wires: 12V, GND and RPM sense (likely).
                                  • PeteS in CA
                                    • Aug 2005
                                    • 3581
                                    #37
                                    You probably could search that (Delta?) fan model and learn the function of that third wire.
                                    Modern server PSUs are basically microcontroller (uC) controlled. At least some have a uC on the primary side controlling the PFC and reporting status data to the uC on the secondary side (which controls regulation and monitors for fault conditions). Because these uCs are programmed by the PSU manufacturer, replacing a uC cannot fix this sort of PSU unless one has a programmed part.
                                    PeteS in CA
                                    • tomaxsas
                                      • Mar 2023
                                      • Lithuania
                                      #38
                                      Here is those 2 bad cap pins from bottom. no need to dissemble anything. One cap is easily visible from top and fairly easy to replace. other one (which goes bad more often) is harder to replace.
                                      I remove cap, put through some small wires through holes, solder those on new cap, and pull it through. New cap must be same or smaller, otherwise you wont able to remove, insert it.
                                      • Rainbow
                                        • Aug 2005
                                        • 1375
                                        #39
                                        One DPS-800GB A died after power outage. Stand-by works - both 5VSB and 3.3VSB are OK. That well-known capacitor has good ESR in-circuit (and looks like a Nippon chemicon from the top).
                                        Shorting pins 31 to 34 should power up the main supply but nothing happens. LED remains off. The output is not shorted, capacitors look good.
                                        • CapLeaker
                                          Leaking Member
                                          • Dec 2014
                                          • 8339
                                          If it ran before and the only difference is that it doesn’t power on after a power outage, check the starter cap near the PWM or the PWM died… sometimes they do just die.
                                          First take wifeys hair drier and warm the PSU up a little, but not that hot that you can’t touch it anymore. Then start it. If it does work, it’s the starter cap. If not figure out why the PWM doesn’t start, check the main filter capacitor for power, etc…
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                            03-31-2024, 02:12 PM
                                            07-01-2024, 06:34 AM
                                          • dragon3x
                                            >>> Troubleshooting Delta Power MAX 500ATX ATX power supply
                                            by dragon3x
                                            Hi, this is for troubleshooting and, hopefully, repairing a Delta Power psu
                                            that is still quite new, as it worked OK for some months until it failed.
                                            At the time I was not into power supply electronics; it was put
                                            aside and a new power supply installed inside the computer. Also at the time
                                            power supplies were half the price of today's.
                                            On the PCB there are a D339 and 7500B chips.
                                            I have found that schematics with these 2 chips (see included file).
                                            Does it represent the actual circuit of the MAX-500ATX, I cannot tell.
                                            Some measurements,...
                                            06-05-2024, 03:34 PM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
