I'm trying to fix an AcBel AP10PC24 - power supply, 344W from a Mac G4 circa 2002 (has PFC). Basically on power up the thing does the "chirp-chirp" thing as we know, it is trying to startup but its control circuit knows there is a problem. A resistor smokes which looks to be the current monitor for the main MOSFET. I have removed the PSU from the Mac and use a dummy load.
So far, I have tested all the power semis (removal), watty resistors, the caps look OK, so now I'm down to the control chips, ML4800CP (does the PFC and PWM) and a Weltrend WT7515 power monitor chip. There are a few LM339, as we know for comparator duties, do these go faulty?
All I can do is replace these chips but are they likely to be the culprits? The WT7515 comes in 3 types, the markings on the chips are not sufficint to identify the chip precisely for replacement, plus the chip is not readily available.
My first guess is there is a short in the output (LV rails), but all the semis test OK. Clues anyone?
