AcBel 344W SMPSU repair clues and suggestions
  • itwentboom
    • Sep 2012
    • 6
    • England
    I'm trying to fix an AcBel AP10PC24 - power supply, 344W from a Mac G4 circa 2002 (has PFC). Basically on power up the thing does the "chirp-chirp" thing as we know, it is trying to startup but its control circuit knows there is a problem. A resistor smokes which looks to be the current monitor for the main MOSFET. I have removed the PSU from the Mac and use a dummy load.
    So far, I have tested all the power semis (removal), watty resistors, the caps look OK, so now I'm down to the control chips, ML4800CP (does the PFC and PWM) and a Weltrend WT7515 power monitor chip. There are a few LM339, as we know for comparator duties, do these go faulty?
    All I can do is replace these chips but are they likely to be the culprits? The WT7515 comes in 3 types, the markings on the chips are not sufficint to identify the chip precisely for replacement, plus the chip is not readily available.
    My first guess is there is a short in the output (LV rails), but all the semis test OK. Clues anyone?
  • itwentboom
    • Sep 2012
    • 6
    • England
    Re: AcBel 344W SMPSU repair clues and suggestions
    I just remembered, which might be a clue. The PSU goes into "chirp mode" from the instant on plugging into the mains (240V). The "Power On" signal to the PSU is open circuit (floating) as I have the unit on the bench.
      Check and/or replace the startup cap.
      • chipmunk
        • Sep 2014
        • Netherlands
        Which cap it the startup cap?
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          If unsure just replace all small caps.
          Photos would help...
            • 31304
            just for clarity,
            this is NOT an ATX psu.
            it could be, but the wires are in differnt places in the connector.
            thanks apple - for using the same connectors - you fucking bastards.
            i wonder how many pc's you may have killed with that stunt!!
            just because DELL did it does not mean you had to!
            • Rictech
              Panasonic SA-MAX770PU SMPSU board fault....
              by Rictech
              Hello everyone. 😀
              As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
              Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
              Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
              This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
              There are no devices that have exploded or otherwise show signs...
              08-26-2024, 01:05 AM
            • lpzrules
              Help with acbel pch018
              by lpzrules
              hello
              I have both the psu one is for lenovo other for hp
              my pch018 is blown but pch019 is functional and of no use to me
              actually on the psu board of both models the ps_on wire which has green black and yellow which goes into motherboard for supply is 4 pin soldered on it has 4 squares and wires soldered together
              the pch018 uses 3 slots one is empty all blacks and yellows are separate and one gree separate pch019 uses all 4 slots with mix of yello black and green
              there are 9 wires inpch018 and 10 in pch019
              the pch018 has output from...
              06-20-2025, 04:21 AM
            • jetblue
              need help with Apple AcBel 1PC36
              by jetblue
              hi,i recently recapped a non responsive acbel 1pc36 power supply. i need to know what is the plugged in state for this supply with no jumper wire on the on plug pins.
              is it normal for the fans to come on and meter readings on the plug to be normal? or does the start pin need to be bridged to get any readings from the plug?
              it seems like its stuck on on and not standby from what i read on the threads.
              its not cycloning only when i bridge the other set of pins will it do that but im not sure if its because im not plugging the pins right because after a while it stops....
              09-06-2022, 11:51 AM
            • dcbw
              PowerMac G5 ACBel 614-0303 buzzing
              by dcbw
              The PSU works, but shortly after powering on (either in the G5, or by shorting the power-on pin to ground) it begins buzzing loudly. It also makes the LED lights connected to the same circuit flicker. It's definitely a buzzing, not a high pitched whine.
              The buzzing seems to come from the high voltage side of the board, perhaps from the white relay. Could the relay be bad, or could the 5V supply be bad enough that it's unable to keep the relay on? Any pointers to help isolate the issue? Thanks!
              Other info: API2FS34, ID 291, Date B0404
              05-31-2024, 07:13 AM
            • Dannyx
              Another water pump automation project (suggestions ?)
              by Dannyx
              Good day folks. Some of you may recall that a while ago I was struggling to put together what I considered to be a very basic automation for a water supply system. It didn't work out the way I intended and I learned my lesson to do it properly from the start, rather than try to reinvent the wheel and patch something together myself from scratch, so I'll stick to commercial alternatives for future projects and such a project just came in today !
              This one is easier simply because this time the pump and level sensors are in the same place, so they don't require a remote connection....
              07-26-2022, 11:39 AM
