Seasonic SS-200SFD
  • milesy
    • Aug 2012
    • 34
    Seasonic SS-200SFD
    Hi Guys
    well this is project number 2 - this PSU just stopped one evening after a brown out on the AC supply (tranformer somewhere died giving only 80v on the ac line)
    i opened it up and discovered
    1. The main fuse was blown
    2. a number of swollen caps on the secondary
    I thought that i measured the switching mosfet was short but it turns out its actually a diode across the mosfet that is shorted
    The diode is UGK10K (http://www.datasheetarchive.com/UGP10K-datasheet.html#)
    So my first question here is does anyone know of an equivalent of this diode as it doesnt seem to be available and the usuall places?
  • b700029
    Banned
    • Sep 2010
    • 640
    Re: Seasonic SS-200SFD
    Manufacturer: "Zowie Technology"
    You need to replace it with an 800V 1A ultrafast diode (<= 35ns recovery time).
    • milesy
      • Aug 2012
      • 34
      Yeah but i can only find reference to SMD packages when searching - any idea of a easy obtainable par number??
      • milesy
        • Aug 2012
        • 34
        do you think this one would be ok
        http://au.mouser.com/ProductDetail/V...yLbLFzY4NPx0k=
        • milesy
          • Aug 2012
          • 34
          even better can get this one at the local jaycar 4007
          • b700029
            Banned
            • Sep 2010
            • 640
            The original was max 35ns, so those are a bit slower. Might work, or might not, depending on how they spec'd the original circuit.
            • dj8452000
              How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
              by dj8452000
              I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
              02-18-2025, 08:28 AM
            • Jane
              How do you test MOSFET in laptops ?
              by Jane
              I tried to use this method:
              Testing an N-channel MOSFET:
              Step 1: Discharge the Gate (turn off the MOSFET)
              Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
              Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
              Step 2: Charge the Gate (turn on the MOSFET)
              Now, place the red probe on the Gate (G) and the black probe on the
              09-27-2024, 03:31 AM
            • Nooy
              VGA MOSfet permanently shorted and loss of MOSfet pad
              by Nooy
              Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
              I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
              02-14-2024, 02:26 AM
            • Tomylee
              HP 15-fc0007ca Charger Cycling On/Off with Hot MOSFET – Need Component Info
              by Tomylee
              I have an HP 15-fc0007ca that works normally, but when I plug in the charger while the laptop is powered on, the charging cycles on and off repeatedly—it starts charging, stops, then starts again.
              Using a thermal camera, I identified a MOSFET that is overheating, along with a small 2R2 resistor next to it that gets even hotter than the MOSFET.
              I also hear a “zpzpzpzp” type noise, but the noise is not coming from the same area as the hot MOSFET. I will include a photo with the exact spot where the noise is coming from highlighted.
              11-26-2025, 12:24 PM
            • redbaron1007
              Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
              by redbaron1007
              I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
              Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
              09-09-2025, 11:10 AM
