FSP300-60THA - FSP 3528 datasheet equivalent
--- begin sig file ---
--- end sig file --- -
Re: FSP300-60THA - FSP 3528 datasheet equivalent
In many cases startup capacitors fail due to becoming leaky not due to high esr.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Hi all, mainly retiredcaps, I am from slovakia, my english is no so well, but I had similar problem with similar power suply (ATX-250PA with FSP3528) and I spent an all of day of searching for errors or damages, but no results. Power supply ran for the small time (fan get some turns) after I shorted green to ground. On the DTC pin stay 3,8V. After I shorted this pin, pulse width was very small. Without shorting DTC, pulse doesnt width. After next measurements I found out, that on 5V branch voltage doesnt jump up after shorting green with GND. On others branches Voltages jumping up at least small time. Finally I found, that latest 5V's coil (on rod ferrite) is worst soldered to PCB and no contact, because before this coil I measured 6,5V, which very slowly falling, and don't understand why. After I soldered coil to PCB, PS running as very well. I knew, that it would stupid thing, but this really no.
Your written English is better than probably 50% of most North American high school students today.
Cold, bad, cracked solder joints are difficult to find. I'm glad you got it running. I don't work much on ATX power supplies so I don't know if bad solder joints are common or not.Finally I found, that latest 5V's coil (on rod ferrite) is worst soldered to PCB and no contact, because before this coil I measured 6,5V, which very slowly falling, and don't understand why. After I soldered coil to PCB, PS running as very well.--- begin sig file ---
--- end sig file ---Comment
I didn't expect this, but I must using helpfull tools, eg. google translate. But at least I'm trying
I too don't work much on power supplies, but this was very interesting error and I had to solve it. I've thought, that FSP3528 is bad and almost I put PS in place with spare parts. Originnaly one of coil's contacts are no full moved through PCB, but only are touch with solder. After time, this weak joint cracked. Who would have saidCold, bad, cracked solder joints are difficult to find. I'm glad you got it running. I don't work much on ATX power supplies so I don't know if bad solder joints are common or not.
. I have repaired tens of PS, but such error I never not found. Still a lot to learn
Thank you very much!
thank you share this PDF documents.
upload my file:
https://www.badcaps.net/forum/album....&pictureid=518Comment
by AskicHello guys,
I'm trying to find an equivalant MOSFET of the following:
https://www.ruten.com.tw/item/show?21532307398856
I'm not able to find a datasheet for this A2719 MOSFET, and I'm not sure if this is equivalent http://www.datasheetcatalog.com/data...PA2719GR.shtml
Can you pleas confirm that A2719 M mosfet is actually UPA2719GR?
Thank you! -
This specification for the Acer Extensa EX215-52-3528 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EX215-52-3528 boardview and EX215-52-3528 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 08:40 PM
First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheetHi all,
I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if... -
I got a dead HD6950 on Ebay to try my luck and repair it. There were a few broken off capacitors that I already replaced.
Measuring the PCI-E lanes I got somewhat weird measurements, the gpu might or might not be dead.
If I plug the GPU in, the core heats up and I also get VCore but on two inductors that measure 16 and 60 Ohms respectively (Memory and PEX I guess) there is no voltage.
On one of the two buck-controllers (APW7165) the enable pin is pulled to GND and the other controller I just cannot find a datasheet for.
So if anyone has a datasheet or at least... -
TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...-
Channel: Common Parts Library - Datasheets
10-07-2024, 06:07 AM -
- Loading...
