Re: Need help on this lenovon Power supply
Hi guys; i don't think that's that easy to activate the window key for what i read here!
http://windows.microsoft.com/en-US/w...-this-computer
Looks like you'll need to contact a moderator. Many forums have edit buttons in your own posts but here I don't see one.Leave a comment:
As tom said, delete that image you posted. You got it, the product key, win 7 pro 64 is the download you want.
As rogfan said download and burn to a DVD, (double layer DVD, I read somewhere) pop it in your machine and reboot. Win 7 should be able to recognize all your hardware but just in case after the reinstall I'd go to the device manager and check.
I have not had to use this yet so I really can't give you step by step. I'm absolutely certain the info is good as Jack would have taken it down pronto if it were bogus. Easiest thing for you would be to sign up over there and ask directly. I've been @ anand for a long time and have never gotten bad advice without someone jumping up and shouting real quick.Leave a comment:
Be careful on posting that product key... someone else could use it to register a copy of Windows and then you might not be able to use it.Leave a comment:
Download the correct image from the site, burn it to a dvd, then boot the computer with it and when asked, enter the key in the sticker.Leave a comment:
If you have the original win 7 key on the computer maybe this will help,
http://forums.anandtech.com/showthread.php?t=2225273
windows7?and can you lead me the way step by step.thanks in advance.Leave a comment:
http://forums.anandtech.com/showthread.php?t=2225273Leave a comment:
I found this site will this software work on my problem or is just a blunt to take your money they talk about reset password but about the name,
//www.pcunlock.com/m/outLeave a comment:
off.
The others were just some things people use as user names and passwords
could be either.
I still think the idea of booting from a cd into linux might be the way to go as rogfanter suggestedLeave a comment:
or i type (administrator/ admin/ qwerty/ lenovo/ovonel) and leave password blank?Leave a comment:
if you turn on the machine while holding F11, what does happen ?Leave a comment:
does it use Lenovo password manager?
If you can get into the bios you may be able to switch it off?
Have you tried the usual administrator/ admin/ qwerty/ lenovo/ovonelLeave a comment:
I checked on support and there is some solftware for this modle#!
http://support.lenovo.com/en_US/Supp...n7+recovery+cdLeave a comment:
I suspect it's made in Mexico because they might be using IBM's old factories.Leave a comment:
Hi - can you update your profile with the country and your mains voltage.
It is a Lenovo - made in Mexico? Windows sticker singapore?Leave a comment:
If the machine has windows 7 from the factory, that is what the restore cd would install.
But is it a Lenovo ( ex-IBM ) machine, or is it brand really LenovoN, ( with that "N" in the end ) and so being some little unknown chinese notebook ?
Lenovo would have a web page and the cd´s. Other obscure, one-model brands doesn´t even use to have a homepage.
Thanks rgfather: i send some pics.
http://www.directron.com/3134c6u.htmlLeave a comment:
Lenovo would have a web page and the cd´s. Other obscure, one-model brands doesn´t even use to have a homepage.Leave a comment:
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
Opened it up and discovered the power supply is making a faint clicking or ticking sound.
I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
by Gust zhangI have a 15 - inch Retina MacBook Pro from the mid - 2014 model. Here is the link: https://www.badcaps.net/forum/showth...light=820-3662 . The battery broke some time ago. After I removed the battery and plugged in the original power adapter, the MBP could boot up normally. However, when I checked with IntelPowerGadget, I found that the CPU speed was limited to 0.8 GHz, and it ran very slowly. Later, I found a solution on GitHub. There is an open - source project called cputune that can set the CPU running speed. So I can now run the MBP at full speed. But another problem...
- Loading...
