Enermax Liberty ELT400AWT making clicking noise but still running
  • Behemot
    • 4845
    • CZ
    #41
    Re: Enermax Liberty ELT400AWT making clicking noise but still running
    First generation of this PSU got problem with this shit going conductive over time…maybe that's it, try to clean the PSU from it…
    • Behemot
      • 4845
      • CZ
      #42
      I got the very same problem with 500W version now. There are two 0,168ohm (brown, blue, silver, gold, green) resistors in parallel in PFC. There also seems to be one hidden under heatsink, according to diode setting on DMM, they are all 0. So if all three in parallel, that makes 0,056 ohm. ESR Micro reads 0,03-0,04 ohm.
      There is no glue on primary at all, there was only soem lackuer holding ferrite rings on FETs legs, I scraped it from one place where it was touchign heatsink. It still clicks. All capacitors were replaced.
      My only bet is input cap as it has somewhat low capacitance (284 uF, rated 330), but ESR is OK, 0,11 or so ohm. Besides the cap, I think that only bad component may be the PFC coil.
      ADD// I tried paper tube and I think it's the PFC coil
      ADD2// replaced PFC coil, the bloody thing still clicks!
      • Behemot
        • 4845
        • CZ
        #43
        Also changed input cap, still clicking. The frequency is different, but it clicks.
        Do you think it's safe to leave it be? I've read that quite many of 620W Liberties which suffered heavily by clicking also often burned in flames and killed components in computer. But I ckeched everything, replaced most parts and no change.
        • Agent24
          I see dead caps
          • Oct 2007
          • 4960
          • New Zealand
          #44
          Interesting. Mine started doing it again. No obvious problems but I don't want to use it.
          I expect if we checked the output on an oscilloscope it will probably show some spikes\crap at the same frequency of the clicking. I don't think it would be a good idea to use them in that state on hardware you care about. I'll have a look but I don't have a decent load tester so I don't know how accurate the results would be, though.
          I didn't check the primary capacitor on mine but if you tried replacing and it made no difference then I suppose that's not it.
          I still suspect the PFC control circuitry\diode. If the PFC coil is making the noise but a replacement doesn't help.
          Since mine started clicking again (it stopped for no apparent reason) I am tempted to try it again. Maybe swap the PFC control board from another I have which blew a transistor.
          -David VanHorn
          • Behemot
            • 4845
            • CZ
            #45
            I don't have x100 probe for oscilloscope and using just x10 would blast it off but let me order one, wanted anyway for the 24'' Samsung I've been troubleshooting.
            OK, hopefuly it will be here in a couple of weeks.
            • Agent24
              I see dead caps
              • Oct 2007
              • 4960
              • New Zealand
              #46
              I was thinking of checking the secondary output, wouldn't need a x100 for that.
              But regardless if there are spikes or noise in the outputs, it's obviously faulty and shouldn't be running in that state. I know I don't want to use mine like this anyway.
              I do have an old x1000 one, for checking EHT on CRTs I think? - not sure it would be much use here though. The tip is probably too big! Plus I think it's just for voltmeters.
              -David VanHorn
              • Behemot
                • 4845
                • CZ
                #47
                If the problem is in PFC, it probably would not propagate through capacitor and switching transistors to secondary.
                  Enermax Liberty ECO 400W [ELT400AWT] - from scraped to serviced
                  by momaka
                  Remember this pile of junk electronics I got last year? Well, that's where this Enermax Liberty ECO 400 Watt PSU came from. Like I mentioned, it had cut cables and many bulged caps on the DC output side. I stripped a few cables and did a quick temporary recap with whatever junk (but still reading OK) caps I could find, then performed a basic power test – the PSU passed. Thus, I knew I'd eventually go around to repairing it. One year later and we're here.
                  First shown is the label below, so anyone reading can see what PSU we're dealing with here.
                  02-15-2021, 01:05 AM
                • NConstantinou
                  HP Z840 workstation power supply clicking noise
                  by NConstantinou
                  No power
                  i have the above ps which i change the TOP258eg ic.
                  Now i have power but is clicking and voltages are flutuating. I change all capacitors, i test all mosfets and all are ok.
                  i am wondering what is the value of R901! I am getting 0.5Ohms. Is that correct!
                  the colours look like R,R,W or silver,G Bl.
                  Thanks...
                  12-25-2024, 02:24 AM
                • tony359
                  by tony359
                  11-28-2023, 05:18 AM
                • MegaZAC
                  Onkyo TX-SR805 noise in one channel
                  by MegaZAC
                  Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                  Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                  There's some logic behind it. As soon as I select an input I get only left...
                  04-23-2025, 10:09 PM
                • courtcircuit
                  Philips HTS8000 home cinema noise problem
                  by courtcircuit
                  Hello
                  I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                  Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                  Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                  I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                  Removed each of tyhe boards
                  02-08-2025, 08:22 AM
