Appropriate Fuses for ATX power supplies
  • Rulycat
    • Apr 2010
    • 724
    • United Kingdom
    I see a lot of cheap power supplies use crappy glass fuses. What's the fuse most suitable for an ATX PSU? I'm assuming you can't use the type you find in a plug?
    Perhaps a basic question but I think given this could prevent a fire it's best to ask...
  • Evil Lurker
    Warranty Voider
    • Feb 2011
    • 454
    Re: Appropriate Fuses for ATX power supplies
    I think in all my experience in dealing with computer supplies I have seen one fuse failure... in fact they are usually the last component to blow.
    I mean if you were anal and wanted to go ceramic you could but personally I don't think it really matters.
    • Rulycat
      • Apr 2010
      • 724
      • United Kingdom
      But if I'm designing my own circuit, can I use a 3amp or 5amp fuse like you'd get for a plug? Is it a different "type" of fuse for the PSU itself?
      • Heihachi_73
        • 713
        The only time I've blown an ATX power supply fuse (or three) is when I've plugged the AC cord into the rear of the PSU while the plug is still connected to mains; if you're really unlucky it will arc and kill the fuse immediately. Open up the box, find nothing wrong except a blackened fuse, swap out the fuse (if it's socketed and not soldered in a nigh-impossible position) and most of the time the machine will work again. Any PSU that has hardwired fuses, fan or AC power I normally chuck once they fail since they're usually junk anyway (seen/had enough of Teapo, OST, Fuhjyyu, CapXon, Su'scon and Viva caps).
        • larrymoencurly
          • Oct 2004
          • 960
          Aren't the fuses built into AC cord plugs rated for 13A? That's usually kind of high for a PSU.
          I thought the rule of thumb was for the fuse's amp rating to be about twice the watt rating, divided by the AC line voltage, so for a 500W PSU the fuse would be about 8A. OTOH I've never seen a fuse smaller than about 2.5A - 3.0A in any ATX PSU, even 200W models; maybe that's because of the surge of current from the big capacitors at turn-on time.
          Almost all ATX PSU fuses I've seen have been glass and fast-blow, but Delta used to always use ceramics, often slow-blow, but I think even Delta now sometimes uses glass.
          If you buy ceramic fuses, get major brands (LittleFuse, Bussman, Bel Fuse) from reputable dealers because I'd worry about Ebay mystery makes to be made for much higher amps than labelled. At least with a glass fuse you can look at the wire inside and kind of see if the amp rating is roughly correct.
          I've had only a couple of PSUs blow fuses, including an ancient Enermax, and every time it happened, the high voltage transistors shorted.
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
            Surface Mount Fuses Fundamentals Datasheet
            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
            10-07-2024, 06:07 AM
          • beetle1303
            Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
            by beetle1303
            I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
            On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
            01-13-2025, 08:49 PM
          • iMic
            Vintage AT Power Supplies - Selecting Capacitors
            by iMic
            Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
            The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
            02-19-2023, 06:45 PM
