FSP power brick
  • Khron
    • Sep 2006
    • 1350
    • Finland
    FSP power brick
    Hello "again", good people.
    Now, i've had this power brick made by FSP, with the intention of using it as a spare for my laptop. It's heftier than the "stock" one, but i wanna use it as the "home" PSU anyway. It says 19v / 10.53A max (200w).
    Last time i tried it out (after a re-cap) and modded the feedback for a 12v output (about 2 years ago), it worked fine. Granted, i didn't have the chance to REALLY put it to work, but it powered a couple fans without a hitch.
    But now, it seems to be oscillating from a certain load upwards.
    With a 12w/21w bulb in series with two 2R2/5w resistors on the output, which comes out at about 1,7A / 33w load (19v out), the output looks like this.
    With the same bulb, but only ONE 2R2/5w in series, which comes out at 1,95A / 38w, the output looks totally wrong (about 300mV ripple, and the "big" oscillation seems to be around 3.6kHz, with which my ears would agree, it just "sings").
    The main PWM is an ST L5991D, and it uses a TSM101.
    FWIW, on the output there are two Panasonic FR 470u/35v, a sort of "common mode choke", and an FC 470u/25v.
    If needed, i've lifted the schematic of the secondary, so i can post that as well. It has two optocouplers; the one i figure is for the voltage feedback is a straight-ahead output->opto->zener->resistor->ground affair, so it does NOT use the TSM101 for voltage feedback. The other one is hooked up to the TSM101 and most definitely deals with the current limiting, in some manner.
    I'd really appreciate some ideas how to stabilize this bugger
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: FSP power brick
    I did one extra test - i replaced the two 470u/35v FR's with two 680u/35v FM's. 32w also stable, 38w also unstable, although the waveform is slightly different.
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      Re: FSP power brick
      I don't know, but from what I have seen in other PSUs, 3x 470uF caps won't cut it for 10A output.
      Any chance you can post pictures of the power adapter? Is this a synchronous MOSFET rectifier power adapter or does it use just schottky diodes?
        Re: FSP power brick
        Also, in many types of power supplies you need a greater capacitance after the inductor than before it. At least, that is in my experience.
        • Khron
          • Sep 2006
          • 1350
          • Finland
          Re: FSP power brick
          Well, i definitely won't need the whole 10A; the power brick that came with my laptop is only 90w.
          And about pictures... The primary heatsink comes like a "shroud" over the whole primary section, and i'd really love to AVOID taking it off again.
          Regarding the output, it has three TO220 double diodes in parallel. Can't make out what model / type (due to the light-blue epoxy/glue that's holding the ferrite beads on the cathodes and has been smeared over the top of the casings), but there's an ST logo and "UOK 350", but that's most likely some fab/date code...
          I did manage to "lift" the schematic of the secondary, for what it's worth...
          • Khron
            • Sep 2006
            • 1350
            • Finland
            Re: FSP power brick
            I also traced most of the apparently-relevant part of the primary circuit.
            One or two of the diodes are zeners and/or bigger than 4148's, but i couldn't be bothered to "rename" them. Resistor values are what i could read off their tops.
            • FrancescoV
              Onkyo HT-R390 no sound output, video output ok
              by FrancescoV
              Good morning everyone,
              I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
              The firmware reported is the following:
              M:1.00/11107BLP
              D:?.??/????????
              O:1.00/11107AL
              The DSP firmware given the question marks seems corrupt.
              On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
              05-11-2025, 02:59 AM
            • repair-it
              TOSHIBA DLP 52HM95 How to reset timer module on bulb
              by repair-it
              I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
              Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
              10-11-2023, 07:18 PM
            • ezenia
              LUMIMAN Smart Bulb IC ID?
              by ezenia
              I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
              In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
              04-28-2025, 05:56 PM
              NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
              by sam_sam_sam
              I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
              I bought this from an eBay seller but unfortunately they only had one
              I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
              I bought three of from them to also make battery packs with this output power limit in mind
              I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
              04-23-2025, 05:50 AM
            • Dannyx
              UC3842 Power Adapter Blowing Fuse
              by Dannyx
              Good day folks......wow this new layout is weird. It's like I woke up one day and I'm no longer on Planet Earth or something
              Anyway....got this here power brick from a USB to SATA adapter which keeps blowing the fuse after I almost repaired it. The reason I even bother to fix a power brick (wall wart, whatever) in the first place is because this thing was really convenient to use: I'd just plug it and that's it. It's a dual output supply, for both 12v and 5v, which although I COULD easily obtain with a DC-DC converter from a standard 12v adapter, I thought I should crack open the...
              12-05-2023, 12:06 PM
