Acbel (from Intel iMac) power supply dead -- any hope?
  • melb
    • Jun 2015
    • NZ
    Re: Acbel (from Intel iMac) power supply dead -- any hope?
    HI, we have an identical PSU in our MAC and it has a blown resisitor (R050) 5W 0.05 ohm i beleive. Could be other issues but this was standout obvious. This is the SMD shown in the board underside of the photos at beginnning of this thread (near top right) As it was such a low value I chose to temporaoily replace it with some resistance wire to act as a fuse and see what happens - it blew again when powered up.
    So I have 2 questions:
    1. on the PSU it implies it is 12V out put (15 A) - does anyone know the pinout of the 5 pin outlet connector (I am wondering if I can temporarily replace with an external 12V PSU just to prove the rest of PC is OK - it's been sat around a couple of years)
    2. Any ideas on what else might have failed on PSU or if my 'fuse' wire concept was a bad one... I just don't want to invest a lot of time/money on futile exercises (we live in New Zealand)
    Thanks in advance
      • 31247
      check if the fet on the heatsink above the resistor is shorted.
      • Toasty
        • Jul 2007
        • 4171
        Welcome!
        See post 20. 12v is the only output, grey(+) & black(-). Brown is "sense". Replacement PSU should work for testing.
        Main switcher FET is bad. Resistor is in the path to it from the bridge rectifier. Your main cap could have failed or the PWM switcher IC or both.
        T
        veritas odium parit
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • Andreas_de
          Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
          by Andreas_de
          Hello!
          i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
          Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
          Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
          04-12-2025, 10:38 AM
          03-31-2024, 02:12 PM
        • kevin_allein
          Samsung QE 75 Q 7 FGMTZG Power Supply dead
          by kevin_allein
          Hi, have this Samsung QE 75 Q 7 FGMTZG TV with no function. First analysis shows the power supply board is dead and fuse blown. Power Supply has the number BN94-11439A. I did short circuit test transistor and diodes and those do not appear to have shorts. I must admit I did not look at every single data sheet.
          In the TV was some black dust residue, so probably one of the electrolytic caps blew, but they do not show short either.
          Does anyone have schematics for that board ?
          Any good tip, what could be the issue ?
          02-27-2025, 12:15 PM
        • khalillll
          maxipower 400W Dead power supply repair
          by khalillll
          The power supply was completely dead. Voltage reached the main capacitors, but nothing after that.
          After checking, I replaced the UTC7606D IC to restore the 5VSB.
          I using SDC606U as a replacement, but it didn’t work — possibly the IC itself was faulty.
          Replaced it again with another UTC7606D.
          Result: 5VSB came back, but still nothing — no 12V, 5V, or 3.3V.
          After checking again, I think the issue was with the UTC7520D IC.
          Replaced it with a WT7520.
          Result: PSU fully working again
          09-27-2025, 05:06 AM
