Thermaltake TR2-500 Primary cap bad?
  • ben7
    replied
    Re: Thermaltake TR2-500 Primary cap bad?
    Originally posted by goodpsusearch
    I took out the Capxon primary caps and took more photos of that power supply trying to figure out why the primary capacitor in that specific spot keeps failing.
    There is some burnt glue on that bleeding resistor if I am correct. I don't remember those resistors to get hot.
    I also consider the possibility of the MOV getting hot, but is that possible?
    My last suspect is PPFC placed near the primaries. Do they get hot usually? Is it normal or a sign of failure?
    Meanwhile I had a look at the other parts of that power supply.
    The bridge rectifier is a 10A KBU10J.
    The PWM IC is UC3845B.
    The power supply uses C5353 NPN transistor on 5vsb and 2x W14NK50Z power mosfets rated for 14A continuous at 25°C and 7.6A continuous at 100°C.
    Now let's move to the secondary section:
    -5vsb: 1x 1N582 3A, 2x 1000uF 10V Teapo SC 8x20mm, ripple 1080, esr 0.065
    -3.3V: 1x STPS3045 30A,
    1x 3300uF 10V Teapo SEK general purpose 10x25mm, ripple 950 and 1x2200uF 6.3V Teapo SC 10x20mm, ripple 1220, esr 0.051
    -5V: 2x STPS3045 30A(60A total),
    -12V: 1x STPS3045 30A, 2x 2200uF 16V Teapo SC 10x30mm, ripple 1780, esr 0.032
    - -12V: 1x 470uF 16V Teapo SEK general purpose 8mm
    Teapo SEK datasheet
    Teapo SC datasheet
    The fact that they used GP caps explains the relatively high ripple those Thermaltake psus show when high loaded.
    Put two good caps in there for a moment, and power it on. Take note of the voltage across each primary cap. Occasionally, if there is a problem with the PSU, one cap will have a higher voltage across it that the other, sometimes enough (greater than 200v) to cause it to fail.
  • goodpsusearch
    replied
    Teapo SEK datasheet
    Teapo SC datasheet
  • dmill89
    replied
    This psu doesn't have active pfc. As far as I know passive PFC doesn't boost voltage neither stresses the cap.
    It doesn't boost voltage but the PFC coil can get rather hot and since this PSU (like most CWTs) has the coil right next to the primary caps this adds additional stress. Of course the primary heatsink on the other side of the caps gets hot when the PSU is loaded and the airflow is somewhat restricted in this area which is somewhat narrow with relatively large objects on both sides that block airflow, the PFC coil being a solid object isn't exactly good for airflow.
  • ben7
    replied
    Power up the PSU with good caps and see if the voltage across them is [roughly] the same. If they are not, then that is what caused the cap to bulge.
    You live in greece, so I beileve your power is 220v. That gets rectified and put across the two capacitors in series. If the voltage across them is uneven, one could possibly blow up (worst case would be about 300v across a 200v cap)
    replied
    The cap will still be under stress from the AC input ripple. If anything, active PFC is *kinder* as the current is typically sinusoidal, and the actual RMS current is lower than a non-PFC supply. Though in active-PFC designs, the cap is usually smaller, so its ripple current rating is lesser...
  • Pentium4
    replied
    Ohhh yeah, you're right. Good catch.
  • goodpsusearch
    replied
    Originally posted by Pentium4
    I wouldn't use CapXon caps as primaries in a PSU with PFC
  • Pentium4
    replied
  • dmill89
    replied
    It could be an underlying issue with the psu but those caps are in a bad location between the primary heatsink and PPFC coil. CapXons are not very durable so it wouldn't be unreasonable for them to have failed again after 5mos. especially if it was heavily loaded and/or poorly cooled. High quality japanese caps could posibly solve the issue.
  • goodpsusearch
    replied
    Originally posted by tom66
    It IS a CapXon. They can fail with no apparent cause...
    I wish you were right but I think it's the power supply, not the cap.
    Same brand, series and uF-V caps are running in Jou Jye power supplies without a problem for years.
    replied
  • goodpsusearch
    replied
    Impossible... My friend called me complaining that his computer would not start. I went there only to find that the psu acted weirdly and when I opened it I had a deja-vu. One of the 2 primary caps bulged again and drained to the point that it measures completely open at the ESR micro meter...
    This is very strange, primary caps rarely fail, especially without APFC. All I can think is that something in the power supply makes that primary capacitor bulge.
    Sorry, didn't take pics of it yet.
    replied
    I had a similar PSU (I think 480W, I gave it to my friend). It was even worse, because there's a secondary board crammed with an active PFC stage. Almost no space in it for airflow.
  • goodpsusearch
    replied
    Here it is, powering again my friend's PC. Thank you for your help
  • dmill89
    replied
    So long as the blades are not obstructed and it spins freely you should be ok. I have a TR2-550w (not currently in a computer, kept as a spare), it has Rubycons on the primary but JunFu (rebranded Fuhjyyu) on the secondary. I'd probably rather have it all Teapo like the one you have since Teapos tend to be more reliable than JunFus, of course 100% Japanese Caps would be even better. What is it with CWT, so many of their PSUs are good designs but are let down by the crap caps they use.
  • goodpsusearch
    replied
    I have recapped the power supply and it is now working, but.. the plastic holder of the fan is touching the top of the caps.. I managed to close the case and didn't tighten the screws too much... I hope it's ok.
    Some photos attached
  • mariushm
    replied
    Yes, you can replace them with 1000uF, won't be any problems.
  • goodpsusearch
    replied
    Can I replace the Teapo primary caps with Capxon? Those caps are really expensive and I thought that the primary caps don't fail often...
    Going up from 820uF to 1000uF, will it hurt?
  • goodpsusearch
    replied
    Just measured the Teapo 820uF 200V Primary caps:
    non bulging: esr: 0.05 capacity: 812uF
    bulging: esr: 0.64 capacity: 772uF
  • goodpsusearch
    replied
    They used 85C caps in a psu
    2x 47uF Teapo SK 85C
  • bauto601
    KDM 480W PSU upgrade succes! (opinions?)
    by bauto601
    Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
    A "nice" YoungYear unit? - Badcaps
    The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
    12-26-2023, 03:05 PM
  • iMic
    IBM NetVista Pentium III - USI Motherboard w/ Teapo SC
    by iMic
    Hi folks,
    I have a couple of IBM NetVista desktop computers from around 2000-2001. They have Universal Scientific Industrial (USI) Pro286i motherboards, 733MHz Pentium III processors, and a whole bunch of bad Teapo capacitors. One board has visibly bad and venting capacitors, while the other doesn't look too bad so far.
    The board with venting caps works fine, while the good looking board occasionally refuses to power on unless it's left for about 30 seconds after connecting the power - even with a known good power supply. (I am however aware I'll need to check the PSU...
    11-29-2023, 06:44 AM
    by momaka
    03-15-2023, 10:17 PM
  • dicky96
    Xilence XP600 600w ATX PSU - No PWM Controller on primary side - how does it work?
    by dicky96
    Hi guys
    I have a faulty Xilence ATX PSU here
    The fault basically is I have two short circuit power transistors on the primary side of the large SMPS transformer - they are 2SC3320.
    There is another smaller transistor on the primary side C3866 which tests ok
    The PSU has three transformers - it looks like the 2SC3320's drive the big one and the C3866 drives one of the small ones. There is a separate PFC PCB with it's own controller and MoSFETS
    There is also a short on the 3.3V output and a near short on 5V - I suspect this probably blew...
    05-11-2021, 07:55 AM
    ThermalTake Smart M Series M850W – blown primary cap and fuse
    by momaka
    I recently acquired a ThermalTake Smart M Series M850W (model SP-850AH3CCB) power supply. It has a blown primary cap, blown fuse, and shorted 5VSB MOSFET. Now, if the primary cap was a cheap Chinese or Taiwanese brand, I wouldn’t have been surprised. But the primary cap is a Panasonic HD 400V, 470 uF cap and the rest of the PSU also has quality caps (mostly Chemicon KY and KZE). The PSU barely has any dust in it as well. It looks almost new, actually.
    So, has anyone seen this type of failure before? Did the APFC overshoot and cause the 5VSB FET and fuse to blow? Or was...
    06-17-2017, 11:56 AM
