Fake primary capacitors
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Re: Fake primary capacitors
    Someone trying to fake Capxon... Priceless
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      I know this is an old thread but wanted to share some...These caps came out of Coolmax, L&C, Sun Pro, and Logisys PSU's
        master hoarder
        • May 2008
        • 12175
        Wow, more fakery (is that even a word, btw?). I guess from now on, when I see primary caps from unknown Chinese manufacturer, I will just assume the capacitance is 1 level lower than what is printed on the sleeve. Even though it may not be the case for every cheap cap brand, I think it's a safe assumption regardless.
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          That's a good assumption. Unfortunately it depends...Another 470uF HEC input cap that was black instead of blue was actually 470uF. And a CS cap that I figured would be fake was its actual value. I wish they were more consistent!!!
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Weird!
            Or, WHAT THE HEC!
            Even the fuhjyyu is overrated! :P
            Muh-soggy-knee
            • Shocker
              Banned
              • Dec 2011
              • 635
              #26
              The Fuhjyyu is actually within tolerance (barely...), so it isn't necessarily fraudulently labelled.
              • Pentium4
                CapXon Be Gone
                • Sep 2011
                • 3741
                Originally posted by ben7
                Weird!
                Or, WHAT THE HEC!
                Yeah you're right. I measured the other one that ran along side it and it measured 433uF so I assumed they were really 470's I should have posted the picture of that one
                • Heihachi_73
                  • Jun 2012
                  • 713
                  No-one would be dumb enough to fake a Fuhjyyu. Although, one could probably dress up a Fuhjyyu as a KZG and no-one would know the difference.
                    People have to remember most manufacturers don't care about Fuhjyuu caps -- they use them because they're cheap. And I'll bet they're easier to fake as there's less vigilance over them. So if supplier X suddenly has a large supply of Fuhjuuu and the procurement manufacturer can get a raise by dropping the per-unit cost by 20 cents then you will see fake Fuhjyoo.
                    • japlytic
                      • Oct 2005
                      • 2086
                      I found these fake Rubycon snap-in units in two identical Chinese power supplies.
                      Officially, Rubycon USP only comes in 85C whereas these fakes (both USP series) were labelled 105C.
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        Haha well found!
                        Got any esr specs and capacitance specs for the fakes? (I.e., are they actually 100uF?)
                        Muh-soggy-knee
                        • Pentium4
                          CapXon Be Gone
                          • Sep 2011
                          • 3741
                          Those are some decent looking fakes. Also curious to know their actual capacitance
                          • ben7
                            Capaholic
                            • Jan 2011
                            • 4059
                            Notice the wacko vent shape on one of them!
                            Muh-soggy-knee
                            • Heihachi_73
                              • Jun 2012
                              • 713
                              The JEE 330uF 200V primaries which came out of this trashed King World ATX-250W PSU measured at 202.8uF and 198.8uF respectively, both with an ESR of 0.07 ohms and a date code of 9828. No doubt they are 220s with a 330uF label, as they are still in tolerance of said capacitance.
                              Same again with Su'scon. The two 470uF 200V LXs I ripped from an L&C LC-230ATX were measured at 312.0uF and 319.9uF respectively; both 0.06 ohms ESR. As with the above caps, they are well within tolerance... of a 330uF capacitor. This PSU was also from 1998.
                              • Pentium4
                                CapXon Be Gone
                                • Sep 2011
                                • 3741
                                Yeah true! But they probably had plastic discs over them though?
                                Wow that's crazy, doesn't surprise me though from L&C
                                • Heihachi_73
                                  • Jun 2012
                                  • 713
                                  That line through the side of the 'Mercedes' vent looks like they tried to turn it into a K shape to match what a Rubycon should have.
                                  • Pentium4
                                    CapXon Be Gone
                                    • Sep 2011
                                    • 3741
                                    They are still doing this. Cap was manufactured the first week of 2013.
                                    • ben7
                                      Capaholic
                                      • Jan 2011
                                      • 4059
                                      Get out the guns!
                                      Muh-soggy-knee
                                      • Pentium4
                                        CapXon Be Gone
                                        • Sep 2011
                                        • 3741
                                        I posted this in the hall of shame but figured might as well add it to this thread as well. Came out of a Leadman
                                        • ben7
                                          Capaholic
                                          • Jan 2011
                                          • 4059
                                          Fake one LOL
                                          KMG sleeves are supposed to be brown not black xD
                                          Muh-soggy-knee
                                          • eryjus
                                            by eryjus
                                            05-10-2023, 11:21 AM
                                            by momaka
                                            03-12-2025, 03:42 PM
                                          • Paxman_Swede
                                            by Paxman_Swede
                                            Hello!
                                            01-14-2025, 09:51 AM
                                          • Galraedia
                                            Fake Caps in Xbox 360
                                            by Galraedia
                                            I decided to take one of the Rubycon capacitors out of a phat Xbox 360 with a Zephyr motherboard and noticed that all the Rubycon capacitors near the CPU were fake. The capacitors in question are Rubycon MFZ 680uf 6.3V and they all have a bullseye bottom, something not found in genuine Rubycon capacitors. None of them were leaking, they all have the K top, and the system has never been opened before. It appears Microsoft was using fake capacitors in the Xbox 360, or the Chinese facility where the console was manufactured in was using them and passing them off a genuine. Just thought I'd share...
                                            02-04-2023, 09:55 PM
                                          • Foetuss
                                            Gigabyte GA-6OXT :: caps question
                                            by Foetuss
                                            Good evening
                                            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                                            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                                            But I was also suprised about the bigger boys, which are 330µF 25V.
                                            Could it be they used 25V caps because they were cheaper / available at that time?...
                                            02-11-2025, 12:22 PM
