I didn't think this was possible - an 'explosive' Delta!
  • c_hegge
    • Sep 2009
    • 5219
    http://www.hardwaresecrets.com/artic...-Review/1500/9
    Antec's VP350 exploded when Hardware Secrets tried to overload it
    True, it did deliver 350W, but still, being a Delta, I would have expected OPP.
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: I didn't think this was possible - an 'explosive' Delta!
    Antec probably told them to cheap out on some parts here and there..
    The efficiency figure speaks for itself lol
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      It says in the review it's an FSP, not a Delta.
      • dmill89
        • Dec 2011
        • 2534
        Also while OPP would definitely be nice they pulled 475.3W from a 350W rated unit before it exploded which is well beyond a reasonably expected overload.
        Yes, I know that there are some real idiots out there that would try to run 2 high end video cards in SLI/Crossfire and a Quad core CPU off of a 350W PSU and Antec and their OEM should use OPP to cover their but in such a situation
        • c_hegge
          • Sep 2009
          • 5219
          They are wrong. It's a Delta. FSP never use those black transformers and they never use Taicon caps. Their low end capacitors are always Capxon and Teapo.
          • Scenic
            o.O
            • Sep 2007
            • 2642
            That thing doesn't look like a Fortron. At all..
            • PeteS in CA
              • Aug 2005
              • 3581
              • USA, Unsure of Planet
              I worked at Delta, 1998-2001. There are aspects of the construction of this P/S that are consistent with what I saw in our products (e.g. the green-painted toroid core in the I/P common mode inductors and some other I/P filter details). But the O/P cable doesn't look tight, usually one of the I/P common mode inductors used an E-core, and Delta used UC384X PWMs or an Delta-custom controller. I think two-switch forward converters were common, but I could be wrong on that. Things change in 10 years, but my guess is that this is not a Delta design.
              PeteS in CA
              • Rulycat
                • Apr 2010
                • 724
                • United Kingdom
                To be fair if you're daft enough to load a 350W power supply to 470W you shouldn't be surprised when it blows up, lack of OPP aside.
                • PeteS in CA
                  • Aug 2005
                  • 3581
                  After my post above, one thing I noticed nagged at me. While looking at the construction pix I noticed what looked like it might be a custom supervisory IC on the O/P side. This would be the analog equivalent of a gate array, a chip family with a bunch of uncommitted functional blocks (references, comparators, etc.) that a customer could connect to their specification. Delta had such a proprietary supervisory IC, either the DNA1001 or DNA1002 (don't remember which, the other P/N being a combo PFC controller, 384X-style PWM). The review identifies this supervisory IC as a "DWA106N161" (looking at a pic, it might also be a DWA106, with "N161" being either a customer identifier or part of factory/line/lot/date coding). Either way, this differs from Delta's part numbering scheme in two ways. As I said above, things change in 10 years, but this seems to support my guess that this Antec is not a Delta design.
                  Should a 35% overload trigger OPP? IMO, that's in a maybe area. OPP typically isn't very precise. I would expect a designer to pick a OPP threshold somewhere in the 25%-40% overload range.
                  As for an end user overloading their P/S by that much being daft ... well, some users are well-informed, and some see bright flashes, hear loud noises and smell bad smells in their electronics.
                  PeteS in CA
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    Well we do get CapXon primaries, so it could be a FSP... then again, with the Taicon secondaries, black transformers, and small PCB it looks so much like the Delta i have lying around in a corner somewhere.
                    A working TV? How boring!
                    • PeteS in CA
                      • Aug 2005
                      • 3581
                      Geez! If I had looked at the Intro page of the review, I would have found:
                      While the VP450 model is manufactured by FSP, the VP350 is manufactured by Delta. Therefore, they are based on different designs.
                      PeteS in CA
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5016
                        • New Zealand
                        Maybe the OPP was faulty on that unit
                        -David VanHorn
                        • c_hegge
                          • Sep 2009
                          • 5219
                          They changed it. It originally said that the VP350 was made by FSP.
                          • PeteS in CA
                            • Aug 2005
                            • 3581
                            I might have been able to use that excuse had I read it before it was changed. I only came across the statement that it was made by Delta when I was looking for pix or text that said/showed who made the fan and the IEC-320 inlet (I'm rather familiar with the Delta logo).
                            PeteS in CA
                            • ajcox1234
                              • Feb 2011
                              • 57
                              Did anyone notice the piece of crap Elite main capacitors?
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                That's CapXon not Elite... you were looking somewhere else.
                                • c_hegge
                                  • Sep 2009
                                  • 5219
                                  Capxon aren't much better, though.
                                  It drives me up the wall that Antec use non-japanese caps at all after the Stupidpower disaster. Personally, I don't think that bad caps should ever under any circimstances be used at all. It only saves like 50c, and if the manufacturer is really that desparate for it, I'll quite happily pay 50c more for the power supply.
                                  • shovenose
                                    Send Doge Memes
                                    • Aug 2010
                                    • 6575
                                    I'd even pay an exttra $5 if I knew it had popymer caps
                                    • c_hegge
                                      • Sep 2009
                                      • 5219
                                      Well, maybe that will be all it costs to get polys if my PSU polymod experiments work out.
                                        MSI Delta DELTA 15 A5EFK-008 Notebook 15 Specification for Upgrade or Repair
                                        This specification for the MSI Delta DELTA 15 A5EFK-008 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the DELTA 15 A5EFK-008 boardview and DELTA 15 A5EFK-008 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-07-2024, 03:40 AM
                                      • Junkrepair
                                        Calculating ESR from tan delta -- tan delta's dependence on capacitance
                                        by Junkrepair
                                        I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
                                        I found this nice little description of the conversion:
                                        Calculating capacitor ESR from Tan(delta)
                                        https://forum.digikey.com/t/calculat...-from-tan/2633
                                        It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...
                                        06-12-2023, 02:45 PM
                                        MSI Delta 15 A5EFK-081AU Notebook 15 Specification for Upgrade or Repair
                                        This specification for the MSI Delta 15 A5EFK-081AU Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 A5EFK-081AU boardview and 15 A5EFK-081AU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        09-07-2024, 06:11 AM
                                        MSI Delta 15 A5EFK-046UK Notebook 15 Specification for Upgrade or Repair
                                        This specification for the MSI Delta 15 A5EFK-046UK Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 A5EFK-046UK boardview and 15 A5EFK-046UK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        09-07-2024, 05:50 AM
                                        MSI Delta 15 A5EFK-088NL Notebook 15 Specification for Upgrade or Repair
                                        This specification for the MSI Delta 15 A5EFK-088NL Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 A5EFK-088NL boardview and 15 A5EFK-088NL schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        09-07-2024, 04:30 AM
