BENQ Q7C3 Need Help Identifying Proper Power Board
  • branko
    • Mar 2012
    • 11
    • Croatia
    Hey guys,
    a while back i diagnosed my cousin's Benq 17" FP767 ver.2 LCD monitor with a bad power board.
    here is a pic of the label on the back:
    http://i1174.photobucket.com/albums/...g?t=1330637387
    unfortunately, i made the mistake of ordering a replacement power board via ebay without first opening the monitor to verify the power board number. well anyways, the ebay seller assured me that the power board he was selling would be compatible with the LCD, unfortunately it was not(connectors do not fit). to cut the story short, my cousin wanted to return the incompatible power board to the ebay seller, and in doing so he accidentally returned his broken power board to the seller, and now we no longer have the original power board that came with the LCD. i recently ordered a 3rd power board, after being reassured by the ebay seller that it would be compatible , it arrived yesterday, and once again it is not compatible.
    the incompatible power boards that i have tried so far are:
    1) 48.L9002.A14 (size is ok, it fits in the case BUT it does not have the appropriate connectors for the LCD backlight, or in other words, the LCD backlight cables can not be plugged into the power board)
    2) 48.L5302.A00 (has the appropriate connectors, BUT its too big to fit in the case)
    If any one could PLEASE help me figure out the appropriate power board number for this LCD monitor I would really appreciate it. i can post more pics if necessary....? please help
  • gregniowa
    • Oct 2006
    Re: BENQ Q7C3 Need Help Identifying Proper Power Board
    I imagine this post has been long since dealt with, but for the reference of anyone else looking for this information, here is what I know:
    The power board is probably a 48-L9002.A02, (that is what is in the FP767 rev 2 in front of me) but the A03 or A04 revs will probably also work. The A14 rev which was tried is for a no audio version of the monitor, so it has different electrical connections.
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • Noodneek
      Replacing all the caps on the BenQ SW2700pt's power board didn't help...
      by Noodneek
      My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
      I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
      08-30-2024, 12:52 PM
    • ugamazing
      Assistance with identifying resistor value on 820-02918 A2992 board?
      by ugamazing
      Working on a 2023 M3 A2992 unit with 820-02918 board, and it uses a new USB-C power architecture, with rectangular controllers. I do not have a perfect-matching board, so have been repairing this one the old-fashioned way (slowly).
      I managed to blow-away a single resistor that I can't find and can't determine the value of. It connects to ground, so I went ahead and stuffed it with a 100K resistor in case it's a simple pull-up. But, I'm now having issues with that side of the board, and am curious if it's possibly related to this resistor! I have no schematics and no board view, so...
      09-06-2024, 08:33 AM
