Pictured below and with drawing is my 5VSB Load Tester. It uses four 10 ohm 5 watt load resistors which can be switched in separately, and a switch to turn the power supply on and off. A 20 pin connector was removed from a “throw away” mother board. Load resistors and switch were soldered to this connector. The power supply then connects to this connector.
When the power supply is plugged into the wall outlet (power switch is in off position) the 5VSB must work, or the power supply won't turn on when the power switch is turned on. This is true regardless of amount of load on the 5VSB rail. So with power switch off, measure the voltage on the 5VSB rail as load resistors are switched in one at a time. Voltage measured should remain at 5 volts +/- 5%.
No resistors “in” is no loading
1 resistor “in” loads to 0.5 amp
2 resistors “in” loads to 1.0 amp
3 resistors “in” loads to 1.5 amp
4 resistors “in” loads to 2.0 amp
I am using only four resistors because any ATX power supply 5VSB should be able to deliver 2.0 amps. Otherwise there is a problem to be resolved. More resistors can be added, but would be destructive testing. My intent was to make sure the 5VSB rail could and would deliver up to 2 amps. I am not as interested in finding at what point the power supply fails and self destructs.
For the second part of the test, switch all four resistors “out”. Then turn the power switch ON. The power supply should come on, and the fan should start turning. Now switch the four resistors in one at a time while measuring the voltage on the 5VSB rail. Once again, the voltage should measure 5 volts +/- 5%.
This is an easy test for a good power supply to pass. Failing either test means trouble. The power supply may stop, or act erratic and unpredictable. This can cause a computer to stop, then restart, or go into blue screen mode. Bulging capacitors and other defects in the 5VSB circuit is a COMMON problem with computer power supplies. Using this Load Tester as a first test will flush out a lot of problems and save a lot of time.
of course
