all ATX power supply lost power (aging)
  • laser
    • Jan 2009
    • 29
    I noted that all ATX power supply start to lost power after certain time
    in all cases all lost power in the 5v line and the 3v line and never lost power in the 12v line
    this aging issue makes the ATX power supply unusable due low voltage in those lines causing serious problems in the motherboard specially in the gfx card
    of course there are not the caps which filters 5v and 3.3 v lines because I replaced with good caps in all cases
    so which one is the guilty of this aging problem?
    -coils ???
    -small electrolytic caps (those rated from 1 mf to 220 mf) ???
    -the 2 big caps which generally are 200 v / 470mf or 560 mf ??
    can anyone explain plz
  • b700029
    Banned
    • Sep 2010
    • 640
    Re: all ATX power supply lost power (aging)
    Check the rectifiers.
    • laser
      • Jan 2009
      • 29
      they are always ok
      but... do you mean those rectifiers double diode which are fast and named schottky ?
      • Agent24
        I see dead caps
        • Oct 2007
        • 5096
        • New Zealand
        Originally posted by laser
        they are always ok
        Yes the output ones can fail.
        If the primary rectifiers\bridge fails, then nothing will work.
        -David VanHorn
        • laser
          • Jan 2009
          • 29
          the power supply I'm testing is working
          the problem is the output on 3.3v is 2.9v
          and on 5v is 4.6v
          there is something worn and the problem are not the caps ( I replaced all by good chemicons)
          maybe the problem is the schottky diodes which are fast and lost speed
          what do you think guys?
            and on 5v is 4.6v
            Possibly the primary-side capacitors, they went bad on a PSU of mine.
            • Agent24
              I see dead caps
              • Oct 2007
              • 5096
              • New Zealand
              and on 5v is 4.6v
              OK now that is a different story - when you said earlier that "in all cases all lost power in the 5v line and the 3v line" I took that (and I think most people would) that the 3.3 and 5v lines were completely dead.
              Now you're saying they are just low.
              In that case it could be the voltage regulation circuitry is faulty and keeping the voltage lower than normal.
              Post photos if you can, this can help a lot.
              Yeah they could be bad too
              -David VanHorn
