Need help identifiying resistor value on ATNG PSU
  • 2lazy
    • Feb 2009
    Unit - Coolmax CP-500T / Rosewill RP500 / ATNG AP-550T PFC / Cool CP500T
    (all same unit),
    I just had my 4 year old faithful psu go out of service. Upon opening I found a
    few bulged caps on the 5v line, and a exploded resistor on the bottom of the pcb. Seems there was only 1, and 1 diode that I can see...
    Anyone happen to know the value of the resistor? The caps I happen to have replacements for, and would love to try to recap this psu, but without this resistor, Im quite SOL....
    I've done tons of research but cannot find this value, even emailed the service dept's of all 4 manufactures to no avail...
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Need help identifiying resistor value on ATNG PSU
    is it the same/similar to this - pictures might help
    https://www.badcaps.net/forum/showthread.php?t=11935
    • 2lazy
      • Feb 2009
      It looks pretty darn close, even the heatsinks, only difference be the addition of the PFC circuit... Hrmm I'll take some pictures of mine for comparison..
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Pictures?
        • jinu_j
          by jinu_j
          Hi
          05-03-2025, 10:51 PM
        • mikey5791
          by mikey5791
          Hi to all forum members,
          12-26-2024, 04:55 AM
        • MidnightRoller
          Can a resistor lose resistance after hot air?
          by MidnightRoller
          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
          02-02-2022, 11:46 PM
        • artvandalai
          What resistor ohm will work better to repair this waterpik?
          by artvandalai
          The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
          01-05-2025, 04:10 PM
        • chth96
          Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
          by chth96
          I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
          Since then, This AC/DC adaptor have been out of order.
          But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
          After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
          And Is there any possibility that it will suddenly explode as well as to be out...
          12-03-2023, 04:40 AM
