Dell Dimension 2400 PSU?
  • bigbeark
    • Jan 2010
    • 661
    Is this a standard ATX PSU or Dell proprietary?
    Testing a Dimension 2400 motherboard, don't want to wreck it.
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Dell Dimension 2400 PSU?
    Standard ATX.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Correct.
      The proprietary ones are for some servers, socket 370 and possibly older.
      The socket 478 models used Standard ATX.
      I don't think there are any exceptions.
      Mann-Made Global Warming.
      - Dr Seuss
      • 370forlife
        Large Marge
        • Aug 2008
        • 3113
        I think some of their old slot 1 p2/p3 boards use the proprietary connectors. I know I have a whole boatload of them in a box to scavenge parts out of somewhere in the basement. They are really nicely built but only 200-250W each with limited connectors, not really good for anything but parts.
        • dmill89
          • Dec 2011
          • 2534
          Pretty much all the proprietary boards/PSUs are slot 1 or socket 370, pent 2 and Pent 3. Socket 7 and older Dell boards used AT PSUs. By the Pent 4 era (at least socket 478 ,not sure about 423 but that didn't last log so there aren't many 423 boards out there anyway)with atx 12v PSUs Dell had dropped the proprietary PSUs. Any Dell PSU with a 4 pin ATX 12v connector and any Dell board requireing a 4 pin ATX 12v connector is standard ATX.
          If you use a good PSU it won't fry a proprietary board even if not compatible as the faults caused by the incorrect circuits will instantly trip the PSU's protection circuits and prevent it from running. I made this mistake once years ago luckily the PSU (I believe it was an Antec SP-350) went into protect mode and did not damage the board. Cheaper PSUs lack these protections and can easily fry a board. That being said good PSU or not it is not wise to connect a non-compatible PSU to a board you know is proprietary, at best it won't run, at works it will fry the board.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Don't count on it... That's called luck.
            They are proprietary because the voltages are are on the wrong pins.
            Protection features don't anticipate that problem.
            - Dr Seuss
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
              Dell Dimension 8200 Schematic
              LA-1221...
              10-04-2024, 07:48 AM
            • Akhlz001
              by Akhlz001
              09-20-2025, 07:15 PM
            • master3112
              by master3112
              07-29-2025, 01:55 PM
              Dell Thunderbolt Firmware
              by SMDFlea
              Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
              Some models have a choice of 2 different firmwares, it depends on the dell SKU.
              The SKU is in brackets (****)
              EDIT: NVM65...
              01-26-2025, 06:22 AM
