Samxon capacitors in Topfield TF4000PVRt PSU
  • japlytic
    • Oct 2005
    • 2086
    When I looked into the vents of a Topfield TF4000PVRt at an electronics store, I saw Samxon electrolytic capacitors in the power supply. There appears to be no known failures of this brand of capacitor. Does anyone have pictures of this power supply (with series of the capacitors as well)?
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Samxon capacitors in Topfield TF4000PVRt PSU
    Sorry to sink your ship
    https://www.badcaps.net/forum/showth...newpost&t=1753
    • Phil_123
      • Dec 2005
      • 21
      • Unknown
      That's a capacitor from a DVD player, not a PSU.
      • slybunda
        AA and AAA battery charger capacitors?
        by slybunda
        hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
        it has inside:
        2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
        2 x 470uf 16v LZ105c branded as G.Luxon
        not heard of these brands are they any good?
        iv attached photos of the charger and the board inside for an idea on the type of...
        12-24-2023, 04:41 AM
        by sam_sam_sam
        After all of...
        07-13-2024, 08:14 PM
      • Cama
        Solar Inverter - SMH-II - 2 missing capacitors
        by Cama
        I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
        My model is : EASUN SMH-II 7 KW
        Mother Board : P/N 18947-002401250250
        Maybe the EASUN SMH-II 4.2 KW have the same capacitors
        Thank you...
        09-12-2025, 02:50 AM
      • Ady2017
        Are there any datasheets available for Elna RJG capacitors?
        by Ady2017
        I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
        05-25-2025, 02:19 PM
      • xeos
        how often are bad capacitors responsible for LED monitor failures?
        by xeos
        I've had great luck repairing computer monitors and LCDs made in the 2000s when CFL backlights were the only option. In most cases it was easy to see leaking capacitors on the power supply and replace them, and at least 5 out of 6 displays were fixed successfully this way. I've recently taken apart a couple LED backlit TVs, expecting to continue my success, only to find capacitors that look completely fine. Is it still worth trying replacing them? Or are LED TVs, because of their lower power demands, no longer killing power supplies (or maybe caps have gotten a lot better)?
        sorry...
        03-07-2021, 08:38 PM
