Just as the title asks. Are quality parts readily available for this kind of project? I imagine the main problem would be designing the PCB... which begs the question, is it possible to buy pre-designed PCBs from manufacturers? What would you use if you could design your own PSU?
Has anyone here built their own PSU?
Re: Has anyone here built their own PSU?
it would probably end up costing more than buying one ready made and changing the caps.
i can think of more fulfilling projects like nixie clock, headphone amp or tube amp -
Hi Cayse,
That's a really great idea for a project actually - it's one I've been considering for some time. Among IT-related 'parts', a PSU has the unique advantage that it doesn't rely on any particularly sophisticated ICs, so the choice/layout of components is largely up to the designer.
Another huge advantage in building your PSU is that you're sure that all the components used are of good quality, and, even more importantly, rated well in excess of the current you're actually going to be drawing. You'd also have excellent reliability, something which is often sorely lacking in many modern ATX power supplies.
It may cost more, but it would the best PSU on the market! An official Badcaps.net PSU, built without cutting corners, and designed by all the electronics gurus/veterans this forum has to offer.Originally posted by willawakeIt would probably end up costing more than buying one ready made and changing the caps.
The "ultimate" PC power supply, made "like they used to", and, as a "pièce de resistance", Topcat's Rubycon MCZ as output caps.
would there be benefits to using toroid transformer? probably not feasible though due to dimensions.Comment
Cayse (and others),
I found a schematic on my hard disk for a switching PSU that I had downloaded some time ago (from the page
www.ludens.cl). It's designed to give a single 13.8V output at 40A, but you'll notice the circuit's similarity to
that found in your classic ATX power supply.
It isn't easy to build a switching PSU with all the protection and compliance mechanisms. The transformer(s) also pose a problem. You also need decent measuring equipment, including a clip-on current probe, a HV probe, and a storage scope. In general, the first few months of prototyping will involve busting dozens of primary-side switching transistors and bridge rectifiers, often within a few 100 milliseconds after powering up. Add to that, the very real danger of electrocution from accidental contact with the primary side circuitry.
The largest I've built is a 100 W unit, +5v,10A and +12v, 4A; which took all of 6 months way back in 1987. It's easier now, because better transistors, rectifiers and ferrites are available. Also convenient power ICs like the TOP-series and a whole bunch of integrated controllers. It simplifies the design effort, but doesn't change the basic engineering effort to prototype one, including fabrication, test and validation. Not generally worth it unless you're going to sell at least a 1000 units.Comment
I think I'll have to stick to building little PSUs with old transformers and linear regulators. Not the kind of thing one would power a PC with though - if I wanted that kind of (in)efficiency, I'd use an overclocked 130nm Pentium D and a case full of tacky neon lighting.Originally posted by linuxguruThe largest I've built is a 100 W unit, +5v,10A and +12v, 4A; which took all of 6 months way back in 1987.
I guess you're right about that. On the other hand, something which I've found to very cost efficient is to string together your own surge suppressors, which avoids one having to buy those glorified powerstrips to connect your PSU/UPS to.Originally posted by linuxguruNot generally worth it unless you're going to sell at least a 1000 units.
Up to now, my "designs" have been nothing more than a bunch of MOVs, coils and a fuse strung together in a little black box, but I'm sure an expert in the field could suggest some improvements. Hmm - could be material for a new thread...Comment
Some may want to build one which can run off a vehicle or boat supply. Jaycar now stocks a 250W 12V input ATX power supply (XC-4875) for these applications. There are also units for 24V input, as well as 42V input (if you can find one!
Recently, I've been learning how to modify an old PC power supply for 12-13.8V output (no coil rewinds required!).My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
E-core transformers are much easier to wind than toroidal. It's also easier to comply with safety regs. And if copper foil is used for the +5V and +3.3V windings (not sure if that's still common practice), well, that just wouldn't work with a toroid core.PeteS in CA
****************************Comment
by nikola386Hey BadCaps community, I built Repair Assistant, a management system for electronics repair shops. It covers tickets, customers, inventory, expenses, and reporting. What it does:
- Repair ticket management — Track repairs with device details, status, priority, and notes
- Expense & profit tracking — Track parts and labor per ticket with automatic profit calculations
- Customer management — Database with contact info and repair history
- Inventory tracking — Manage parts and components
- Business analytics — Real-time stats, financial overview, profit margins, and trend charts
- Professional
Channel: Announcements & Related News
Today, 02:52 PM -
by BOSCHNJAKABOUT ME INTRODUCTION FILE
2024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
2022 BEV, PROJECT ?
2021 BEV, PROJECT ?
2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...-
Channel: Visitor Messages
12-28-2023, 02:09 PM -
by Smartec82Hello,
Does anyone know the Project ID of the Thomson 55UC6406 , panel: LSC550FN11-906? The picture appears duplicated and I can't change it in the service menu. I can only change the Project ID by pressing 062598, pressing 3 dashes, ID.10-03-2025, 11:30 AM -
by sam_sam_samRight now Battery Hookup has these e-bike battery packs that are used but I am going to remove them and test them and see how good they are and maybe resell or reused them for another project this is for another day
When I get the rack mounted enclosure that I mentioned in another post I will see how well they fit in the enclosure and how much room I will have left
https://batteryhookup.com/products/3...ttery-with-bms
These battery packs are a little bit hard to get out of the enclosure because they were a little bit glue... -
by BladibladI have an interesting project here. I have a HP RTX 3060 12GB VRAM GPU with a shortcircuit between a (what I believe is) a coil and a cap. The short circuit is so bad that it will trigger a failsafe on the PSU.
I'm a beginner in this field and have managed to do only very simple board repairs so far. I have basic understanding of the components (mosfets, caps, nand chips) but completely diagnosing a board with schematics would be challenging. In this case though, I'm going to hope that replacing only the two shorted components will bring the card back to life (if none of the IC's... - Loading...
