Hipro D2537F3R - worth recap?
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Upon visual inspection it has a single bulged Teapo. It's a big mofo too...crammed in right by the secondard thingies...
    Worth replacing in this PSU?
    Came out of an HP Pavilion a510n - honestly I don't even know if the PSU worked fine as I didn't ever turn on the HP PC until I replaced it with a Dell PSU, upgraded the RAM, added an AGP video card, and put in a hard drive...
    So should I re-cap the PSU? or ditch it?
  • mockingbird
    • Dec 2008
    • 5484
    Re: Hipro D2537F3R - worth recap?
    I love the HiPros... So easy to recap... Lots of room to work, no high value caps in extra small sizes that are impossible to get...
    Yea, I've got two HiPros here... I'm waiting for Newark to get FKs in stock so I can order caps for a bunch of PSUs I need to recap.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      Lol so I should go ahead with it?
      it sucks they make such a good PSU...except with Teapo caps...
      • mockingbird
        • Dec 2008
        • 5484
        Some of the manufacturers learned their lesson... I'm seeing more and more UCC KY caps in newer models' reviews.
        • Behemot
          • 4845
          • CZ
          Yeah it definitelly is. I believe they desing their PSUs so even bad caps live long, but you never know. Beside the caps HiPros are pretty much decent.
          • c_hegge
            • Sep 2009
            • 5219
            Yup. go for it. I often see hipro PSUs with bulging teapos after only 2-3 years. I've never had one not work after a re-cap.
            • Cartel
              FORD 1996 ECU RECAP: Aluminum - Polymer worth bothering?
              by Cartel
              I will be pulling my crown vic ECU and recapping it. 3 in total, 47uf 16v x2 and a 10uf 63v
              I hope they havent puked yet. I was thinking of replacing them with Aluminum - Polymer thru hole caps. probably 47uf 25v and 10uf 80v
              They arent cheap. Anyone have any experience with them? Am I wasing my money on premium caps?
              Nichicon PLV series
              thanks
              06-01-2025, 04:58 AM
            • Bungz
              Morex Int'l ATX-300C, worth a recap?
              by Bungz
              Thought I would have a look inside this as I had a issue with a system freezing ( socket A Thunderbird system)
              Thought it was a odd design, what do people make of it?
              Edit - Nothing visual wrong, obviously may start with a recap but swapping the PSU solved the freezing issue.
              I like older socket A systems so these older PSU that are weighted towards the 5V rail always catch my eye....
              08-18-2021, 01:35 AM
            • varunviolin007
              Looking for someone to recap Dell XPS T450 motherboard (Live in suburbs outside of Philly)
              by varunviolin007
              Hi guys,
              I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
              I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
              Looking for someone experienced with older PC boards who uses...
              07-29-2025, 11:53 PM
            • Foetuss
              Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
              by Foetuss
              Hi all
              Hope this is in the correct place.
              I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
              Could use some double checking to see if I'm not doing something stupid .
              Pictures of the boards are attached.
              What I will be replacing with what : (planned)
              Soltek Golden ::
              4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
              6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
              01-18-2025, 11:44 AM
            • goodpsusearch
              Got 4 LG L222WS 22" for free - psu recap
              by goodpsusearch
              Got 4 CCFL 16/10 monitors for free.
              The resolution is almost Full HD (1680x1050)
              VGA Input only is a bummer though.
              Uses cheap TN panel with terrible viewing angles.
              Even though this is not 17" 5:4 screen, still has very low resell value here. Can be found for 15-20 euros.
              All the 4 monitors were not working and needed psu recap. Used mix of mediocre / junk caps to recap them, then donated 3 of them to friends/relatives and kept 1 for myself. Also like to install extra caps on empty spaces to help them last longer.
              01-15-2022, 05:36 PM
