Philips 47" 47PFL3704D/F7 - Wii Accident, No Video
  • jonyoungyi
    • Oct 2011
    Hi guys, recently my son threw a wii controller at our TV and the screen just doesn't display anything any more (no power to the screen, just black). The screen itself seems fine, as nothing was cracked or damaged upon impact. I was wondering if anything else could have caused this TV not to work after the Wii incident. Is there any hope for my TV?
    All your inputs/suggestions/comments are appreciated. Thank you!
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: Philips 47" 47PFL3704D/F7 - Wii Accident, No Video
    If it worked sometime after the accident then yes, there is hope. If you do research here on just philips TV's, you'll find that they have lots of problems. Search here and if you dont find a solution that fits your description then post pictures of your boards and go from there. Search for "philips" and see if there is a related TV. I didnt see the exact model.
    • b700029
      Banned
      • Sep 2010
      • 640
      A sheet of plexiglas will protect the screen should he again fail to put on the controller strap before flinging it around.
        May one of the CCFLs was cracked although I find it surprising it wouldn't crack the LCD!
        • iZakre
          HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
          by iZakre
          Hello everybody!
          To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
          The thing is that I had installed TeamViewer and could log into the computer...
          02-19-2023, 02:27 PM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • ferah831208
          HP gaming 15-0013dx quanta G3HA no video, screen polarize on and off loop
          by ferah831208
          I have an HP gaming 15-0013dx laptop , motherboard quanta G3HA with AMD Ryzen 5 cpu and Nvidia discrete grsphics card. The laptop turns on and u can see the screen polarizing on and off in a loop but no video signal. All voltages are ok measured and stable (I checked all with oscilloscope). This schematics don't have power sequence but I'm using a similar sequence from another laptop with AMD CPU and I get all to the point CPU must release apu_pwrok and apu_rst#, this signal comes valid only for the period of time the screen is polarized and they disappear and same loop behaviour (active/inactive)....
          12-07-2024, 04:02 PM
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
        • smic717394
          by smic717394
          07-25-2024, 10:16 AM
