3R Systems PSU on Hardware Secrets
  • Rulycat
    • Apr 2010
    • 724
    • United Kingdom
    Take a look at this:
    http://www.hardwaresecrets.com/artic...-Review/1408/2
    Good performance, but who's the OEM? Reminds me a bit of some Sunpro units, or maybe ATNG.
    Notice the "Kingcon" caps with the Suncon/Sanyo K-vent.
  • mariushm
    • May 2011
    • 3799
    Re: 3R Systems PSU on Hardware Secrets
    It's reported to be Golden Tiger GT-ATX-500-800
    I've noticed the Kingcon caps also, because Jonnyguru on his forum was asking about them a while ago and then this psu popped up.
    They're taiwanese but that's pretty much all that's known about those.
    • c_hegge
      • Sep 2009
      • 5219
      IMO, no PSU with anything non-japanese should even get a bronze award, let alone a silver, regardless of how well it performs.
      • Rulycat
        • Apr 2010
        • 724
        • United Kingdom
        Teapo seem to do okay in newer PSUs.
        • c_hegge
          • Sep 2009
          • 5219
          I frequently pull bulged teapos from 2 and 3 year old PSUs, even when they are decently cooled and appear to be the correct series for the application. For that reason, I always call them cheapo teapo
          • Rulycat
            • Apr 2010
            • 724
            • United Kingdom
            What makes of PSU? I know those crappy little FSP strips of alu don't exactly help.
            • c_hegge
              • Sep 2009
              • 5219
              I've seen it in PSUs made by HiPro, huntkey, CWT as well as FSP (and probably a few others) Even when they have massive heat sinks and run cool. Even OST and capxon seem to hold up better than teapo. In some cases, they had a mix of fuhjyyu and teapo, and the teapos failed before the fuhjyyus (even though neither were near any particularly hot components).
              • Rulycat
                • Apr 2010
                • 724
                • United Kingdom
                Ah righto. Run cool in Aus? You must be having a laugh.
                I'd be interested to see some long term stress tests of different brands in the same conditions. You can't go by MTBF.
                • c_hegge
                  • Sep 2009
                  • 5219
                  They can run cool when there's air conditioning. In any case, though, I've been replacing them with Nichicon HE. I've yet to have one come back.
                  • goodpsusearch
                    • Oct 2009
                    • 2850
                    • Greece
                    This is so not true!!!
                    • c_hegge
                      • Sep 2009
                      • 5219
                      I know capxon and OST have MUCH worse reputations (and I still trust them less), but I see at least twice as many teapo failures as OST and capxon combined.
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Even OST and capxon seem to hold up better than teapo. In some cases, they had a mix of fuhjyyu and teapo, and the teapos failed before the fuhjyyus.
                        No way. - Absolutely not what I see.
                        Teapo failures are rare compared to those other three brands.
                        If you see 1000 Teapos in PSU's and 10 OSTs or Fuhjyyu then quantitatively more bad Teapos doesn't make a worse 'rate' of failure.
                        Also if you are seeing them bad over and over in basically the same PSU's and that isn't necessarily the fault of the caps.
                        IOW:
                        If you see 50 Dell GX-2xx boards with some bad Rubycons and one Asus board with good OST that doesn't mean OST is better than Rubycon.
                        In my experience OST and Fuhjyyu are -at least- 10 times more likely to be bad than Teapo if you go by percentages instead of raw quantities.
                        In PSU's I see at the most 5% of Teapos are bad and OST/Fuhjyyu are easily 50% or more failed.
                        - That's with mixed PSUs though, which isn't a good way to compare.
                        [Capxon is somewhere in between but they seem to be getting worse as time goes on.]
                        There is a 460 watt Sparkle/FSP I like so I've easily done over 20 by now.
                        Heavy units, 3-Cap PI OP Filters.
                        I sometimes use them in 'light servers'. (3 or less hard drives.)
                        [It's a similar design to the AcBel unit people like for some reason but all the OP caps are 12.5mm so they are very easy to find choice replacement caps for compared to the AcBel with all those bastard 10mm OP caps.]
                        The caps mix is ideal for a comparison here.
                        [Layout]
                        OP cap count - 5x Teapo [always] and 4x OST or Fuhjyyu.
                        [OST/Fuhjyyu brand used varies unit-unit with maybe 80% being OST.].
                        3x of the Teapo [on 3.3v OP, always Teapos] have iffy cooling.
                        2x of the Teapo and the 4x mixed brands have better cooling due to location.
                        [Of the 20+ Units]
                        - 3 bad Teapos total so far.
                        - 4 good OST total.
                        - Zero good Fuhjyyu.
                        [So, taking 20 PSUs.]
                        Out of 100 Teapos - 3 bad. [3%]
                        Out of 80 mixed OST/Fuhjyyu - 76 bad. [95%]
                        - - And that's mixed brands in as close to the same operating conditions and history [per unit] as you can possibly get without doing a formal test.
                        So, IMHO:
                        If those Teapo you are replacing were OST or Fuhjyyu instead the result would be the PSUs would fail much much sooner.
                        Mann-Made Global Warming.
                        - Dr Seuss
                        • BOSCHNJAK
                          by BOSCHNJAK
                          ABOUT ME INTRODUCTION FILE
                          2
                          024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                          2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                          2022 BEV, PROJECT ?
                          2021 BEV, PROJECT ?
                          2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                          2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                          12-28-2023, 02:09 PM
                        • Hondaman
                          Hardware firewall to block ad servers?
                          by Hondaman
                          I found an interesting summary on a wiki that Youtube "right to repair" enthusiast Louis Rossman put up. He suggested I could use a hardware firewall and pfSense as a firewall, and use pfSenseNG as an ad blocker. Or use OPNSense as a similar alternative. Seems like it would be easy to set up, but it only runs on the hardware supported by BSD. (I'm sure the developers and maintainers of BSD are super-busy and cannot support every single piece of hardware out there, so I can't fault them.)
                          The trick, apparently, is to "assign IP address lists from sites like I-blocklist...
                          02-05-2025, 05:04 AM
                        • nobbnobb1
                          DIY NAS Service Life (Hardware)
                          by nobbnobb1
                          So I'm probably a decade behind on this, but my current NAS is a low power machine I built in 2009. It was originally running Windows Home Server, then eventually I migrated to Windows 10 using Storage Spaces for my drive expandability and redundancy. Despite being slow for W10, I love the familiarity and functionality so I never bothered getting into NAS specific OS.
                          Hardware wise, it's got 4x drives but the hardware is all super low draw, so the Antec EarthWatts EA380D power supply is barely above ambient. This PSU is apparently known for capacitor issues but when I went in to...
                          09-25-2023, 04:35 PM
                          Fintek F71868A Super I/O and Hardware Monitor Datasheet
                          The F71868A which is the featured IO chip for PC system is equipped with one IEEE 1284
                          Parallel Port, two UART Ports, one 80 port (multi with COM2), Hardware Keyboard Controller, and SIR. The F71868A integrates with hardware monitor, 9 sets of voltage sensor, 3 sets of creative auto-controlling fans and 3 temperature sensor pins for the accurate dual current type temperature measurement for CPU thermal diode or external transistors 2N3906. Others, the F71868A supports newest AMD TSI and Intel PECI 3.0 interfaces and INTEL Ibex...
                          10-23-2024, 02:26 AM
                          Post your Microsoft Automatic bios Update Hardware ID`s
                          by SMDFlea
                          Some of the newest laptops have the capability to automatically update the bios from Microsoft update.
                          If its enabled there will be Hardware ID listed in device manager under
                          Firmware - System Firmware - Details - Property - Hardware ID`s - UEFI\RES_
                          Example: UEFI\RES_{5E28725C-AA01-4AAA-9E44-414B5EE2EA44}
                          Entering the hardware ID {without the curly brackets} at https://www.catalog.update.microsoft.com/Home.aspx
                          will show a list of available updates.The downloads are cab files,they can be extracted with winrar or 7-zip.
                          Each extracted cab...
                          08-04-2022, 12:30 PM
