3R Systems PSU on Hardware Secrets
  • Rulycat
    • Apr 2010
    • 724
    Take a look at this:
    http://www.hardwaresecrets.com/artic...-Review/1408/2
    Good performance, but who's the OEM? Reminds me a bit of some Sunpro units, or maybe ATNG.
    Notice the "Kingcon" caps with the Suncon/Sanyo K-vent.
  • mariushm
    • May 2011
    • 3799
    Re: 3R Systems PSU on Hardware Secrets
    It's reported to be Golden Tiger GT-ATX-500-800
    I've noticed the Kingcon caps also, because Jonnyguru on his forum was asking about them a while ago and then this psu popped up.
    They're taiwanese but that's pretty much all that's known about those.
    • c_hegge
      • Sep 2009
      • 5219
      IMO, no PSU with anything non-japanese should even get a bronze award, let alone a silver, regardless of how well it performs.
      • Rulycat
        • Apr 2010
        • 724
        Teapo seem to do okay in newer PSUs.
        • c_hegge
          • Sep 2009
          • 5219
          I frequently pull bulged teapos from 2 and 3 year old PSUs, even when they are decently cooled and appear to be the correct series for the application. For that reason, I always call them cheapo teapo
          • Rulycat
            • Apr 2010
            • 724
            What makes of PSU? I know those crappy little FSP strips of alu don't exactly help.
            • c_hegge
              • Sep 2009
              • 5219
              I've seen it in PSUs made by HiPro, huntkey, CWT as well as FSP (and probably a few others) Even when they have massive heat sinks and run cool. Even OST and capxon seem to hold up better than teapo. In some cases, they had a mix of fuhjyyu and teapo, and the teapos failed before the fuhjyyus (even though neither were near any particularly hot components).
              • Rulycat
                • Apr 2010
                • 724
                Ah righto. Run cool in Aus? You must be having a laugh.
                I'd be interested to see some long term stress tests of different brands in the same conditions. You can't go by MTBF.
                • c_hegge
                  • Sep 2009
                  • 5219
                  They can run cool when there's air conditioning. In any case, though, I've been replacing them with Nichicon HE. I've yet to have one come back.
                  • goodpsusearch
                    • Oct 2009
                    • 2850
                    • Greece
                    This is so not true!!!
                    • c_hegge
                      • Sep 2009
                      • 5219
                      I know capxon and OST have MUCH worse reputations (and I still trust them less), but I see at least twice as many teapo failures as OST and capxon combined.
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Even OST and capxon seem to hold up better than teapo. In some cases, they had a mix of fuhjyyu and teapo, and the teapos failed before the fuhjyyus.
                        No way. - Absolutely not what I see.
                        Teapo failures are rare compared to those other three brands.
                        If you see 1000 Teapos in PSU's and 10 OSTs or Fuhjyyu then quantitatively more bad Teapos doesn't make a worse 'rate' of failure.
                        Also if you are seeing them bad over and over in basically the same PSU's and that isn't necessarily the fault of the caps.
                        IOW:
                        If you see 50 Dell GX-2xx boards with some bad Rubycons and one Asus board with good OST that doesn't mean OST is better than Rubycon.
                        In my experience OST and Fuhjyyu are -at least- 10 times more likely to be bad than Teapo if you go by percentages instead of raw quantities.
                        In PSU's I see at the most 5% of Teapos are bad and OST/Fuhjyyu are easily 50% or more failed.
                        - That's with mixed PSUs though, which isn't a good way to compare.
                        [Capxon is somewhere in between but they seem to be getting worse as time goes on.]
                        There is a 460 watt Sparkle/FSP I like so I've easily done over 20 by now.
                        Heavy units, 3-Cap PI OP Filters.
                        I sometimes use them in 'light servers'. (3 or less hard drives.)
                        [It's a similar design to the AcBel unit people like for some reason but all the OP caps are 12.5mm so they are very easy to find choice replacement caps for compared to the AcBel with all those bastard 10mm OP caps.]
                        The caps mix is ideal for a comparison here.
                        [Layout]
                        OP cap count - 5x Teapo [always] and 4x OST or Fuhjyyu.
                        [OST/Fuhjyyu brand used varies unit-unit with maybe 80% being OST.].
                        3x of the Teapo [on 3.3v OP, always Teapos] have iffy cooling.
                        2x of the Teapo and the 4x mixed brands have better cooling due to location.
                        [Of the 20+ Units]
                        - 3 bad Teapos total so far.
                        - 4 good OST total.
                        - Zero good Fuhjyyu.
                        [So, taking 20 PSUs.]
                        Out of 100 Teapos - 3 bad. [3%]
                        Out of 80 mixed OST/Fuhjyyu - 76 bad. [95%]
                        - - And that's mixed brands in as close to the same operating conditions and history [per unit] as you can possibly get without doing a formal test.
                        So, IMHO:
                        If those Teapo you are replacing were OST or Fuhjyyu instead the result would be the PSUs would fail much much sooner.
                        Mann-Made Global Warming.
                        - Dr Seuss
                        • BOSCHNJAK
                          by BOSCHNJAK
                          ABOUT ME INTRODUCTION FILE
                          2
                          024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                          2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                          2022 BEV, PROJECT ?
                          2021 BEV, PROJECT ?
                          2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                          2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                          12-28-2023, 02:09 PM
                        • edugimeno
                          Te systems tv stuck in startup logo
                          by edugimeno
                          Hi there!
                          This tv set (TD systems) is posted for sale with this issue.
                          Stuck in boot up logo
                          Is this something that can be fixed easily like an USB fw upgrade?
                          Or does it need any specific hardware programming adapter?
                          Thanks in advance!!...
                          06-27-2023, 09:02 AM
                        • nerdmafia
                          Broke off RTC Coin battery pin on HP EliteBook 840 G1 - Operating Systems do not load or install
                          by nerdmafia
                          Hi first question posting here, but no need to go easy on me!
                          I have an HP EliteBook 840 G1 non touchscreen. The symptoms are that: Repairing or reinstalling windows freezes no matter how i try it. Live Ubuntu that works on any other computer also freezes while trying to load it. The RAM sticks and the harddrive work fine in other computers. I broke off the connector by accident, CN4750 and was using the laptop for a while with no coin battery. According to this schematic I found on here, which I THINK is the correct schematic, pins 2, 3, and 4 should short to ground, and they do....
                          05-21-2025, 09:39 AM
                        • Raulnn
                          TD Systems K50DLG12US half black and half white screen
                          by Raulnn
                          good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
                          By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
                          01-20-2024, 04:49 PM
                        • edugimeno
                          Blinking stby led on a TD systems TV with 17IPS11 PS
                          by edugimeno
                          Hi There!
                          I have a TV set (model TD Systems K32DLV1H) which doesn't power up.
                          During power off, the stby red led is on, as it should, then I press power button on remote and the led starts blinking, endlessly.
                          Sounds to me like a PS problem. TV is kinda alive as it stays in Stand-by, recognizes power up button from remote, etc, but can't really power up.
                          Internal PS is a 17IPS11. First inspection shows no damaged components, no swollen caps, and multimeter shows all diodes are good. Also there's a dual diode transistor shaped component on a heatsink...
                          04-03-2022, 12:34 PM
