Corsair HX-520W - orange glow results in burned components
  • retiredcaps
    • Apr 2010
    • 9271
    I got this used unknown condition Corsair HX-520W about 3 weeks ago. Since I didn't know if it was working or not (and out of warranty), I opened it up to look for bad caps and obvious signs of damage.
    I was excited to see that UCC KY caps were used throughout (after getting sick of seeing UCC KZGs on 3 motherboards - all non working of course). I also noticed the power supply looked like it was coated in fine sand? It wasn't normal dirt, but light brownish like sand.
    I cleaned it all out carefully and put the cover back. I hooked it up to my power bar (with on/off switch) with power off. I readied my multimeter to test the 5V SB rail. I put a paper clip in the green and black power connector. I double checked everything before hitting the power button.
    I put my safety glasses on and as soon as I hit the power on, the fan spun, and through the spinning blades I could see an orange glow. I immediately shutdown the power and about 1 second later I could smell the burnt electronic odor.
    In retrospect now, I should have been very suspicious of the glue that turned brown and scraped it off before power on. Anyway, you can see the damage to a resistor, coil, and possibly more items.
    Anyway, I would like to try and save this power supply if possible. A new 450W Corsair, on sale, will cost around $40 CDN. More importantly, this is an opportunity for me to learn more about ATX PS.
    I can provide more pictures to help id the components if required.
    --- begin sig file ---
    --- end sig file ---
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Corsair HX-520W - orange glow results in burned components
    might be as simple as scraping away the crud.be sure to get any carbon tracks while you are in there.
    i would have figured that the brown glue would have been dumped in the 70's when the first problems came up.
    like the quasar tv sets with huge globs of it on the crt socket board.and missing traces under it.
    • Toasty
      • Jul 2007
      • 4171
      Doesn't look like damage, per se. Looks more like it just flashed across the glue remains. Do what kc8adu said and clean it up. Then go and clean the rest of it out.
      veritas odium parit
      • retiredcaps
        • Apr 2010
        • 9271
        Okay, I finally got around to cleaning this out and I noticed:
        1) There is a nice crater (that isn't obvious in the pic) in the pcb right by the leg of the diode.
        2) The diode that was covered in black soot still tests good in circuit (.397V and 0L on diode check).
        3) I'm not sure if that is copper sitting behind the diode. It is almost like the top layer pcb peeled backwards to reveal copper?
        4) Because of the AC plug and modular connectors are soldered into the unit, it is almost impossible for me, but not others, to remove this board from the metal casing. Any work done by me will be very limited.
        Q1) Should I have take a chance of powering this thing up in the present condition?
        Q2) If the damage is beyond my repair skill level, does anyone want this? I can ship it from Canada, but the cost of shipping it may be unwarranted due to high costs.
        • hardwareguy
          • Jun 2006
          • 405
          The "sandy" material you speak of....could it be conductive metal oxide shavings? Check that before you apply power. Use high pressure air to clean it out. (take necessary personal protective precautions...its nasty to breathe and seems to love to get stuck in eyes)
          • Toasty
            • Jul 2007
            • 4171
            If shipping to the US could be kept reasonable, I'd take it on as a 'science project'.
            LOL
            veritas odium parit
            • retiredcaps
              • Apr 2010
              • 9271
              LOL
              Give me a few days to get an estimated shipping weight. I'll box it and take it to the post office. I don't have an accurate scale at home to weigh it myself.
              Should I even try to power it on again?
              • Toasty
                • Jul 2007
                • 4171
                >>Should I even try to power it on again?<<
                Why not? Just keep your distance...
                veritas odium parit
                • retiredcaps
                  • Apr 2010
                  • 9271
                  Looks like you and kc8adu were right (like there was any doubt?). I put on the safety glasses, plugged the psu into a power bar with finger ready to turn off, and turned on the psu.
                  No flames or burning smell so I started measuring voltages and got everything (3.3V 5.0V, and 12.0V DC).
                  I'm still not 100% comfortable with its operation so I will test it on a low end board and monitor it very carefully. I'll also do a bit more cleaning of the board.
                  Thanks for all the help.
                  • hardwareguy
                    • Jun 2006
                    • 405
                    Desolder the inductor and clean the brown glue off underneath the unit.
                    Use a non-acid curing silicone such as GE Silicone II to replace the glue.
                    • Toasty
                      • Jul 2007
                      • 4171
                      I am concerned with the foil you may have lifted:
                      >>3) I'm not sure if that is copper sitting behind the diode. It is almost like the top layer pcb peeled backwards to reveal copper?<<
                      Clean the area well with isopropyl alcohol and an old toothbrush. Use silicone caulk to fix/insulate the board 'crater' area too.
                      Get the rest of that glue out of there!
                      Good work!
                      veritas odium parit
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        Okay, I finally got around to do all the suggestions with the isopropyl alcohol, silicone caulk, and old glue removal. I let everything dry for 3 or 4 days (even though I didn't have to) and let the silicone caulk sit for 36 hours.
                        I also lubricated the fan bearing with 5W30 motor oil so it runs a lot quieter now.
                        I put the cover on and all voltages appear within spec. No burning smell or glowing components.
                        I need to run some longer tests on it before I gain confidence in my repair job.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          It has been over a year and the PSU is in daily use now and things are still fine. The PSU isn't very stressed though.
                          Thanks again to kc8adu, Toasty and hardwareguy for all the feedback and help.
                          • Behemot
                            • 4845
                            • CZ
                            Interesting to see something like that happening in Seasonic PSU's.
                            Anybody else encountered this in PSU's from this era? S12II/M12II, OEM models?
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              Maybe a bug walked inside of it. Not uncommon
                              Muh-soggy-knee
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                Since I buy used stuff or get them for free, I'm very careful to check for unwanted visitors before I bring them into the house. There was no visitor on this one.
                                • ben7
                                  Capaholic
                                  • Jan 2011
                                  • 4059
                                  Maybe there was a 'visitor' inside, hidden behind the PFC choke
                                  Muh-soggy-knee
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    That is a possibility since these PSUs are all tightly packed and I can't see/clean every crevice.
                                    I did find an unwanted visitor in an old Fluke 25+ year multimeter.
                                    I realize, buying new, is also no guarantee.
                                    • ben7
                                      Capaholic
                                      • Jan 2011
                                      • 4059
                                      I once had a pioneer radio/amplifier which all of a sudden started sizzling and popping. Under the circuitboard was a well toasted cockroach! It must have already been dead, so no roaches in my house!
                                      Muh-soggy-knee
                                        I have had an insect invite itself onto a plasma TV buffer board (high voltage... around 500Vp-p.) This lead to the insect's unfortunate cooking, and also that of the buffer board. Luckily a new board was cheap.
                                          Corsair CX750M [Model 75-002019] - burned output toroid inductor
                                          by momaka
                                          Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                                          So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                                          09-19-2021, 08:44 PM
                                        • mikey5791
                                          Need help to replace burned resistor in 350w atx psu
                                          by mikey5791
                                          Hi to all forum members,
                                          Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                          The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                          Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                          Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                          12-26-2024, 04:55 AM
                                        • serious_electron
                                          Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                                          by serious_electron
                                          Hello Everyone!
                                          I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                                          Yesterday, 02:57 PM
                                        • h0m3w0rk
                                          Random Shutdowns/Startup Failure with Corsair SFX 450
                                          by h0m3w0rk
                                          I'm encountering a frustrating issue with my Corsair SFX 450 power supply. After an undefined period of operation, my PC will either suddenly restart or, in some cases, it won't start at all until I disconnect the power cable and reconnect it. This erratic behavior occurs intermittently, making it difficult to pinpoint the exact conditions under which it happens.
                                          For context, I have tested the PSU using an electronic load at 150W, and under those controlled conditions, it functions flawlessly. This leads me to...
                                          02-09-2025, 03:19 AM
                                        • mosfetratus
                                          macbook A2918, orange light off when shut off
                                          by mosfetratus
                                          When i fully shut off mac, orange light goes off and wont react to power button. I have difficult time resetting with combination "shift+control+option and power button", because it rarely works (reason unknown), when i manage to get orange light and then press power button macbook wont turn on and orange light goes off. When i hold combination with power button it turns on, and works fine if put it to sleep mode.
                                          Works with battery and charges, but when i shut off i get this problem.
                                          It had liquid spill. Board has no corrosion, keyboard is working, power button...
                                          05-31-2024, 03:34 AM
