The Power Supply Modding Guide (or TL494 -> Anything)
    replied
    Re: The Power Supply Modding Guide (or TL494 -> Anything)
    @PANOS1, if you do not want protection then you do not connect the feedback for the over current, just ground that sensing line. Since we do not have the diagram of the circuit you wan to build, then I gave example of the application notes of the IC, you will still need feedback control for voltage output regulation.
    App notes and spec sheet gives lots of info.
  • panos1
    replied
    thank you for your reply...
    i don't want any scheme...
    i just want someone to tell me where i will conect eror amp1-eror amp2-protection...
    for start i don't want any protection...
    i just want to make the smps work...
    after if everything is ok i will add protection....
  • mariushm
    replied
    Download the datasheet for TL494 , search the internet for combinations of "application note" and the word TL494, read how TL494 works.
    It won't help you at all if we just give you some schematic. Need to understand what the chip works and where each pin connects to, then you'll understand how to use it.
  • panos1
    replied
    hi...
    it's my firts post here...
    i have a pc psu with tl494....
    i want to make you board with tl494 but i dont know where i will conect it at the psu pcb...
    please can you help me?
    i mean that i don't know at which pins of tl494 i will conect your pcb..
    i want to convert the psu to an unregulated power supply for a class d amp...
  • Th3_uN1Qu3
    replied
    Originally posted by badcoils
    Hmm...wouldn't it be too "late" if the overpower protection is used for short circuit protection? It has a capacitor after the diode that samples the peak voltage from the base drive transformer, which will delay for quite some time before it shuts down the supply
    What value does the cap have? If there's no resistor in series with the diode, either on the transformer side or before the cap, and the cap is 10uF or under, that will react pretty quickly. The reason the cap is there is to prevent switching noise from falsely triggering the protection circuit.
  • badcoils
    replied
    Hmm...wouldn't it be too "late" if the overpower protection is used for short circuit protection? It has a capacitor after the diode that samples the peak voltage from the base drive transformer, which will delay for quite some time before it shuts down the supply I don't want to replace the transistors if the cheap power supply blows!
    Of course you can - just put the second RC pair over the top resistor in the feedback divider, it doesn't matter if it goes to the noninverting rather than the inverting input.
    In fact I already did so. But I thought there are some other ways that won't affect the bode plot of the stage...
  • Th3_uN1Qu3
    replied
    Tweaking the voltage divider at the pin 4 is not a good idea, the voltage there is already near the lower threshold of the Disable-UVP function. Lowering the voltage will only void the short circuit protection!
    Also, from what i see, unfortunately pin 12 only affects the powergood signal, so it would be no good for shutting down the supply. I don't think disabling the UVP would have any adverse effects - as long as a short on the output causes pin 4 to go above 1.25v, it will still trigger the OPP and in effect, do the same thing.
    Another thing, the error amp in the WT7520 has its inverting input biased to 2.5V, as mentioned in the datasheet. Dealing with this kind of error amp, what is the best approach to take? It doesn't seem feasible to apply the 2pole-2zero compensation circuit, or I missed something?
  • badcoils
    replied
    Yes, you are right, it is the pin 4 that controls the overpower protection. However, it serves two purposes in the SMPS: when the voltage crosses 1.25V it shuts down the supply(overpower protection), when the voltage is lower than about 0.6V it disables the undervoltage protection. I found some voltage divider (linked to the base drive transformer) and also a capacitor near that pin, presumably to provide the delay during startup before enabling the UVP.
    However, what I feel is that, the error amp responds to the transient drop in the output voltage too aggressively by commanding the switching transistor with high (very high) duty cycles and causes the over-power protection to trip too soon. I was able to reduce the occurrences of the undesirable tripping by adding some compensation circuitry, but still not very satisfying.
  • Th3_uN1Qu3
    replied
    I added the loop compensation components by adding the R and C components onto the error amplifier in the controller IC (WT7520), mainly to save cost. Perhaps I was not doing it correctly?
    But I have a question: How do you actually performed your loop compensation? Did you use a separate op-amp to do the compensation, and then connect its output directly to the PWM modulation voltage pin?
    That's what it's supposed to be done. Of course you can use an external opamp - you would do that when the one inside the IC doesn't fit your needs, for example if it is too slow (low bandwidth). But i suspect this is not the case here.
    Feedback loop compensation has nothing to do with the overpower protection. That's a different animal and is tweaked from a different place. It could be either on pin 4 or pin 12, but my guess is pin 12, which has a threshold of 0.62v. Follow the trace and you're likely to find a resistive divider fed by a diode coming from the driver transformer. Play around with that divider and see where you get.
  • badcoils
    replied
    I am also on the way of modding an 450W ATX Power supply into a +-40V dual power supply suitable for audio power amplifiers. The "normal" feedback is OK, and it is supplying the required voltage into a dummy load. However, the last thing I have yet to perform successfully, is the feedback loop compensation. I have tried the type III compensation but it is not working very well; the over-power protection circuit trips very often when the audio amplifier (which is powered by the power supply) is producing some bass. I added the loop compensation components by adding the R and C components onto the error amplifier in the controller IC (WT7520), mainly to save cost. Perhaps I was not doing it correctly?
  • Th3_uN1Qu3
    replied
    Originally posted by Evil Lurker
    What is the correct configuration for driving a single mosfet? If I understand correctly, the TL494 has two outputs that can be configured in totem pole configuration or parallel by either connecting one of the pins that drive the internal flip-flop or whatever its
    For single ended output you wire the OUTPUT CTRL pin (pin 13) to GND instead of vref, and you can then parallel the outputs, collector or emitter, whatever you need. In that case the output frequency is the oscillator frequency, unlike the push-pull output case where output frequency is 1/2 fosc.
  • Evil Lurker
    replied
    Questions... its been a while since I tinkered with one of these IC's but I did get it to oscillate in open-loop mode using the on board voltage reference.
    What is the correct configuration for driving a single mosfet? If I understand correctly, the TL494 has two outputs that can be configured in totem pole configuration or parallel by either connecting one of the pins that drive the internal flip-flop or whatever its called either high or low. Could you please elaborate a bit on this?
    Also, with the two onboard comperators and feedback pin, how are they generally configured?
  • SuperDuty
    replied
    I just did a very basic mod : adding SATA connectors and a +4 ATX connector to a Fotron power supply. Removed the wiring from a crap power Heden power supply, and soldered in the right predrilled holes on the Fotron PCB. Nothing fancy, I don't have the tools and I do not have the knowledge to do something more complicated.
    I did this on two PSUs. I have plenty of power supplies, many crap ones, and the good ones are missing some connectors for modern computers.
  • Th3_uN1Qu3
    replied
    After a fairly long pause i'm back in business. This time we have a Powerlink "400W" unit which will go thru a radical transformation which will (hopefully) have as end result a split adjustable regulated supply. This PSU was recapped by me, but yes, that's still offbrand caps like G-Luxon and YC. Anyway, i just needed it to start up, not power a computer for any length of time.
    This PSU was originally controlled by a SG6105D. The 6105 is a TL494 + two TL431 + a preconfigured quad comparator (LM339). Since the voltage limits are configured internally, there is no way of drastically changing the voltage. So what i did was pull out the 6105 and install a daughterboard with a TL494 instead.
    But first things first. I took a couple measurements of the original configuration. I found the oscillating frequency of the 6105 to be 76kHz, which made the working frequency of the supply 38kHz (for half bridge, switching frequency is fosc/2). Since i am going to be using the original primary parts, i am going to keep the same switching frequency. Then i measured the peak voltage at the transformer secondary, this will be necessary later for calculating the compensation. Of course, the secondary voltage is going to change because i want higher voltage outputs, but the first step was to get the TL494 working with the existing circuitry.
    I found peak secondary voltage to be 27v at the 12v output and 11v at the 5v output.
    After i removed the SG6105D, the first thing i needed to do was install a TL431 to regulate the 5vsb. Since the SG has two onboard 431s, the 5vsb doesn't use a separate one and i had to supply my own. Then i wired up the 494.
    Also, an interesting piece of info: This supply had a 14v auxilary rail on the 5vsb transformer. In 494 based PSUs this is used for feeding the 494 and driver transistors. In this PSU, it wasn't used for anything! But it was complete with rectifier and output capacitor. So, there was no problem adapting a 494 to this design. I also found out that the SG6105 has built-in pull-up resistors for the outputs, so i had to wire those in as well before the 494 would start the supply. They are the 220 ohm resistors you see on the back, wired between the 494's collectors and the aforementioned 14v auxiliary.
    I'm going to be using a 5v not a 2.5v reference, so i only took feedback from the 12v rail. Please note: I have no intention of using this PSU to power a computer ever again, and it is no longer suited to do so. I just wanted to make sure it will run with the 494 before getting into the big mods. Obviously, i had to redo the compensation. I also added a 10k pot in series with a 10k resistor for some degree of control over the former 12v rail's output voltage. I can vary it from 11v to 16v without any issues. I'm not going beyond that yet, because the 12v output cap is 16v.
    The TL494 PCB that i made is missing a resistor btw. You should cut the trace going from Vref (pin 14) to the inverting input of the first error amp (pin 2) and install it on the back. It should be the same value as the upper resistor in the voltage divider that sets the output voltage. I finally figured out why my compensation wasn't working, and that was the issue.
    Attached pics, schematics and charts. In the last pic i'm charging a small SLA. Next up will be the big mods - replacing the diodes and caps and rewinding the transformer and inductor.
  • b700029
    replied
    By the way, there's a pair of 10 000u 50v caps in the supply. There are another three pairs, one for each amp (two bridges and one stereo module, all using TDA7294 ICs), so that's a total of 8 pairs of caps on the output. Divided by two (since they are in series across the +/- supply), that gives 40 000 uF with 70 volts across it. That can do some damage, believe me... If something shorts across that, it's more likely to blow to bits than to trip the protection.
    40,000uF @70V = 98 Joules.
  • Th3_uN1Qu3
    replied
    I did a lot of talk with no pics, so now i provide pics of an actual working unregulated supply built by yours truly. It has the following specs:
    • 600W continuous power output
    • +/-35v and +/-20v output voltages, unregulated
    • Undervoltage (serving as short circuit) and overtemperature protection
    • Full range thermal fan control, fan is OFF until temperature reaches 40C.
    A few clarifications are in order. First of all, don't ask me about the obvious bad brands on the caps. The small Fuhjyyus you see on the board aren't even used anymore. As for the others, an audio amplifier supply stresses them a lot less than a computer supply. And most are in non-critical places which put almost zero load on them. Exception to that are the 1000uF Jakec caps filtering the +/-20v supply, but even that is going to 7815/7915 regs so there's no problem.
    And yes, i know those Chemicons aren't genuine. But i don't care who made them as long as they do their job.
    That input filter is way too close to the stripboard with the protection circuit. I know, but that was the only place i could put it, the layout of this power supply case is horrible. It has no chance to touch that board, and it doesn't disturb the comparator with interference, so i'm alright with that. In fact, it originally was soldered to the power connector, so i couldn't have even fit the modded board in place at all!
    There should have been overpower protection. I was too lazy. In a real situation i wasn't even able to trip the undervoltage protection with shorts - the huge output capacitance simply blew the wires to bits, while the maximum current drawn from the mains (my meter has a peak hold function) never exceeded 0.33A. The only way to short this would be if someone dropped a screwdriver on the outputs, and then if that's the case the protection will step in and do its job.
    The 40v output is with zero load (other than the fan, which hadn't even turned on at that time). As soon as even a small load is put on it, it'll drop to the designed 35v. The idle consumption of the amplifier ICs alone is enough to do that.
    Awaiting your questions.
  • Th3_uN1Qu3
    replied
    Now it's time for another talk, this time we'll cover unregulated supplies.
    Why unregulated? Because they're simple. There's no feedback loop to compensate, no worries about interference within the power supply itself (since the control IC is basically turned into a dumb pulse generator), and no big and expensive output inductor! There is a lot of stuff that runs on unregulated supplies with mains transformers, wouldn't it be nice if we could shrink that transformer to, let's say, 1/10th the size? The lack of a sensitive feedback loop also makes them trivial to build - if you've wired it right, it's guaranteed to work.
    Audio amplifiers in particular have almost always used unregulated supplies. So let's talk about audio SMPS.
    One of the most important differences is that since there is no feedback loop to eat the mains frequency ripple, the primary capacitors have to be much larger than in a regulated one. For a regular half bridge with the primary caps in series for 230v, or in doubler configuration for 120v, i recommend 2x 1000uF at the very minimum. Otherwise you'll end up with a lovely hum in your speakers.
    Again, since there is no feedback loop, the secondary capacitors will also have to be big. In fact, they will have to be as big as they would be if you were using a mains transformer. Basically, the only thing that shrinks is the transformer - but i feel this is entirely worth it.
    Now that i mentioned the transformer, it too needs special precautions. Since the power supply will run at maximum duty cycle all the time, the transformer will have to be designed with nominal line in mind, instead of minimum line for a regulated supply. That means there will be more turns in the primary. This is to some degree offset by the fact that the current will be lower (if mains voltage drops output voltage drops too, so current does not increase), so you can use thinner wire.
    Also, since the PWM IC runs at maximum duty cycle, there is no need for overvoltage protection. For an audio amp supply, primary overcurrent protection (also called overpower protection) and thermal protection are all that is needed.
    There is a way to get line regulation and small primary capacitors in an unregulated SMPS: By adding an active PFC stage in front of it. Depending on the ripple rating of the cap, it may be made 3 times smaller. Since the active PFC stage keeps the voltage on the primary cap constant, you now also have immunity to changes in line.
    That's all for today.
  • Th3_uN1Qu3
    replied
    Coming with a rectification of what i said earlier: The time constant needs to be on the Vcc input of the comparator, not on any of the dividers. The reason is that since the power supply is off, there's no voltage to charge that cap in the first place. And so it'll stay off.
    The resistor you choose needs to supply 10-15mA. The comparator and TL494 will run on a lot less, but i decided to have a safety margin, so they're more resistant to interference.
  • Th3_uN1Qu3
    replied
    Originally posted by everell
    Both pc boards seem to me to be looking at them from the perspective of the top or component side of the pc board. This would mean that to etch the boards, the mirror image would have to be used. Is that correct?
    That's why i gave the .pcb file. You just open it in ExpressPCB, go to File -> Print, select Bottom Layer, and it'll do the rest of the work for you.
    Would you give a simple explanation of the difference between a half bridge psu and a full bridge psu.
    In the half bridge, the voltage applied to the primary is Vin/2. In the full bridge, the voltage applied to the primary is Vin. Which means primary current is now half of what it would be in the half bridge. So, given the same transistor current ratings the full bridge can offer twice the power. The transformer does need double the primary turns because you have double the primary voltage - but with half the wire thickness, you end up with the same size transformer as for the half bridge.
  • everell
    replied
    (I am still sitting in the dummies section)
