Ultra Xfinity 600w 5vsb mod
  • c_hegge
    replied
    Re: Ultra Xfinity 600w 5vsb mod
    Cool
  • ratdude747
    replied
    i have since gotten the system's board to work... and when used, the 5vsb noise disappears. it IS a load related issue.
    whew.
  • ratdude747
    replied
    Originally posted by ben7
    Get a straw and use it to listen to the power supply parts up close when its running, you wouldn't want to get shocked on the ear!
    Is it actually a steady hiss, or an arcing sound? Could be a falied ceramic capacitor on the primary flyback voltage suppressor circuit. I have found out before that cheapo ceramic caps dont like voltage near their max rating.
    I suppose it could be that you replaced the secondary caps with bigger ones too. I have noticed that, say, in 555 oscillator circuits, that a decoupling cap near the 555 makes the 555 output a slightly lower frequency than without the decoupling cap.
    -Ben
    it is like arcing...
    the caps (other than the 5vsb) are same values, bigger physical size. the 5vsb caps were per what i was told shoudl be swapped... but since the cap order somehow got doubled, I have the caps needed if I wanted to swap the 5vsb caps back to the stock values.
  • ben7
    replied
    it is more like an arcing noise than a squeal come to think of it. almost like a hiss.
    -Ben
  • ratdude747
    replied
    Originally posted by c_hegge
    It's probably feedback instability, which is often caused by either bad caps or just bad design. Someone who builds Power supplies (eg, Th3_un1qu3) would probably know more about how to fix it, but my guess is it's one of the small caps you didn't replace.
    I doubt if it would really be arcing. I have a Delta-built Antec that makes an arcing/buzzing noise, but runs just fine. If it really was arcing it would fail pretty quickly.
    i have a dead delta 200w microATX unit that does this too come to think of it. its a lot louder but then again, it is also dead.
  • c_hegge
    replied
    replied
    Ah ok. I think that's a different problem. The one and only PSU I had that made a hissing noise was a Bestec ATX-250 12Z. That one really stunk up my room when I tried to use it. I think one of the capacitors in it must have failed.
    Anyways, since you changed your caps, then I don't think that's the problem. Even though you didn't change the very small caps on the secondary, that should be fine as they are running on a low voltage and it's unlikely to hear any hissing from them.
    If anything, check the primary side - particularly look for long leads on neighbouring traces that look like they are very close together.
    Originally posted by c_hegger
    Disregard the noise? Impossible! It's REALLY, REALLY, REALLY annoying!
    Yeah, I hate high-pitched noises too.
    I can't hear my computers when I'm further than 3-5 feet away from them, though.
  • mockingbird
    replied
    Did you change every last cap?
  • ratdude747
    replied
    Originally posted by mockingbird
    Maybe you put one of the capacitors in the wrong way.
    then why did it do that before the recap? no change audio wise.
  • mockingbird
    replied
  • ratdude747
    replied
  • c_hegge
    replied
    replied
    i loaded the 5vsb with an old abit BH6 i had... the noise persists.
    Some PSUs just like to whine. Both the 200W Astec and the 185W Lite-ON in my computers produce a fairly loud squeal. Both of these PSUs have been running for close to 10 years now without problem, so I just disregard the noise.
    In any case, if you're worried about your motherboard being killed by the 5vsb, just install a 5.1v to 5.5v zener diode across the 5vsb. If something goes wrong with the 5vsb and the voltage on 5vsb goes over the zener diode's voltage, the zener diode will short out and kill the 5vsb. Not a very neat solution, but at least your motherboard won't die.
  • brethin
    replied
    Try loading the 5v rail heavy to test (at least 15 amps) and see if the noise goes away, my guess is it will.
  • c_hegge
    replied
    Did you replace -all- of the capacitors, including every tiny one? If not, then it could be that one of them is the culprit (assumming that the squeal was there before the recap). I used to have this issue with the Antec StupidPowers, where they would squeal even after replacing all of the major caps, but a complete recap (minus the primaries) seemed to fix it.
    You should probably find out where it's coming from as well (use the old straw to the ear trick). It will be one of the coils, or the feedback transformer (probably the middle one).
  • ratdude747
    replied
    Cool. Now you owe me the power supply. After all I did help you fix it Just kidding
    Try it with some load. I had the same issue with those Widetech/Great Wall power supplies. They had a slight squeal with no load, but they were fine as long as I loaded the 5vsb and 12V rails, it was fine.
    i unglued some things (yucky yellow glue)... i wonder if something is rattling?
  • c_hegge
    replied
    Don't worry. It took me ages to find the short on the rexpower.
  • ratdude747
    replied
    Keep an eye on them once you have some more load. Those heat sinks are fairly chunky, so it wouldn't surprise me at all if the fans don't spin when the power supply is cold. If you do think it has problems, though, it looks like an add-on daughterboard, so scavenging one from another PSU slould be easy.
    i do have a partial spare from a junked 550w ultra... but it is missing most of the circuit (much more basic)
    once I get the board for the project in and i get it recapped, then I can put some REAL load on it...
    ps- I still feel like a .
  • c_hegge
    replied
  • ratdude747
    replied
    all i have for load is a dead sata hdd... and the 4 fans in the case. currently i have all of those running, no noticeale ripple on the analog meter. the voltages are also in spec.
    oddly, the fans have yet to turn on... everell, the original owner, noted that the fans never turned on for him either... the stock fans were wasted, and i replaced them... either the thing hasn't gotten hot enough or the fan controller has issues.
  • mrcliem
    CM V700 no +5vsb, ICE2QR4765 low VCC in... Need guidance please...
    by mrcliem
    Hello...
    I got my self a dead CM V700 PSU, with nothing on +5vsb
    I have tried to fix it for the past 2 week, and I'm stuck... so i guess i post it here to get some pointer before i scrap it..
    As you can see in photo, the psu still pretty clean, no visible damage or bulging cap.. when i got it, it still has CM seal on it
    The +5vsb system use ICE2QR4765, I have trace and measure the voltage on ICE2QR4765 and the only voltage reading i got is in VCC 4.8v, Drain 310v and FB 3v.
    I have read the datasheet and and still can not...
    06-29-2023, 08:18 AM
  • socketa
    Zalman ZM500-GV stops after 40s and 5VSB drops to 2.5V
    by socketa
    Rescued this one
    Started it up in the computer case, and noticed that it would shut down after about 10s in the BIOS
    Took it out, connected to hard drive and it loses all power on all rails (except for 5VSB) after about 40s or so. (the same result happens without a hard drive connected)
    The 5VSB drops to 2.5V when it 'shuts down'
    And the voltage across the primary cap falls from 335V to 330V at the same moment
    I think that the 5VSB is regulated by an A6069H PWM chip (which was initially dropping to 2.5V even before the the PS-ON was grounded - but it now stays at...
    12-20-2022, 03:06 AM
  • Bugman1400
    Vizio E470VL got +5VSB, but no 12V
    by Bugman1400
    EDITED: I thought my Vizio E470VL has +5VSB and no 12v on the PS board, but after plugging the cable back in and testing the pins on the Main board I realized that I do have 12V. I assume the 12V is turned on when the ON/OFF switch is pressed. The Vizio light in front does go from Standby Orange to White when ON. But, I still have no picture or sound. Test values of PS board are below.
    +5VSB= +5.09
    12V= +12.18
    PS_ON= +2.25
    I_ON/OFF= +3.27
    LAMP= +3.18
    DIM= +2.97
    Any more testing I can do on Main board or is it just a replacement?...
    09-04-2022, 09:19 AM
  • keldeo
    Ultra low ESR. Much confusion!
    by keldeo
    Hi badcaps! So recently, me being a butterfingers, resulted in me dropping a graphics card and having the corner land directly onto a capacitor directly above the pcie slot on my Asus p5gc 775 board. Now this caused a pretty decent dent in the top of the can, so I've decided it'd ve best to replace it. However, I've ran into an issue. The current caps are Panasonic FJS, 820μf 6.3v. These are apparently "ultra low ESR" and these aren't manufactured anymore. So it seems I'm left with a few options. Put the dented cap back in, apparently it's ESR is 0.24 ohms, but the capacitance is...
    09-03-2022, 12:56 AM
  • delturcious
    Thermaltake ATX TR2-430 Turns on by itself, squeals, & has 0.9V on +5VSB
    by delturcious
    I have an older Thermaltake PSU that has a squealing noise whenever it's plugged in, even when totally disconnected from everything else. It automatically powers on the 5V and 12V rails with full voltage, but the +5VSB circuit only has 0.9V on it. I would assume this is my first place to start troubleshooting?
    There is nothing obviously burnt/leaking that I can identify.
    I've tried to take some decent photos of the 5VSB area. Components of notes:
    • U8 at the back is marked AZ431
    • C38 is 102
    • C47 is 104
    • C34 is a Teapo 330uF 16V (I think all the cylindrical caps are
    02-11-2021, 11:26 AM
