Need Help, First time Ordering a Cap for a PSU for a Computer
  • Xtremepayne
    • Jul 2011
    • 6
    A freind at work recently had a PSU go on her and Best Buy replaced it with a new one. I asked her for the old supply to see if I could fix it. I found a bad capacitor in it. I have since got it removed and here is the all the information off the side of it
    Teapo 2200uf 10v sj105c 04/08 T3
    I have never ordered a capacitor but I have been reading here about making sure to order low ESR Capacitors.
    The Power Supply is a Bestec ATX0300D5WC Rev. A
    I am repairing for the experience of it as I have never repaired a PSU before. What I am looking for help on is how to order thru Digi-Key, its kinda confusing. I wanted to learn because from what I have read here I get better quality if I order online.
    I await your wisdom.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Need Help, First time Ordering a Cap for a PSU for a Computer
    I know it often runs together but the SJ isn't supposed be part of the 105C.
    That is a Teapo SJ series but it's not likely the only cap that's on it's way out.
    ESR = .021 ohms [Want the same or a little less. - Without going nuts.]
    Ripple = 2360 mA [Want the same or more. - Can go nuts.]
    13x20mm
    Standard Procedure:
    List the caps.
    Include - Make / Series / uF / Volts / Diameter / Approximate Length
    From that I/we/you can find the Ripple and ESR specs.
    While you are at it make a map of the PCB and mark where all the caps are including their polarity. [Cap Map]
    It will come in handy later when you forget what came from where or which side of some cap was negative.
    On PSU's it's easier if you draw it life-size.
    - Tip -
    Lacking a tiny inspection mirror. [Which are near impossible to find small enough.]
    ... For those buggers you can't read the back of take a butter, steak, or exacto knife and polish the 2" of blade nearest the tip up all nice and pretty with some gritty toothpaste. Then use it for a mirror.
    A small flashlight helps too.
    And an artist paint brush [or cue-tips sometimes] to wipe dust off the markings.
    Mann-Made Global Warming.
    - Dr Seuss
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      When you search at digikey, once you are at the caps search screen...
      Select:
      "In Stock"
      "+/-20%"
      "Radial, Can"
      And then using the "Ctrl" key select all the Operating Temps that end in 105C.
      - Then click "Apply Filters"
      That will get rid of like 90% of the caps you don't want to look at.
      - Dr Seuss
      • Jidis
        Need T-Con Advice (Vizio P602ui-B3)
        by Jidis
        I made a big-ass mess here of my father's beloved P602, and I'm trying to figure out if I should order a batch of overpriced ribbons or if I'd just be throwing more good money at the bad.
        He woke up recently to a bunch of white bars going down the right side of the screen. From what I'd seen in these places, I figured the T-con board has gone out or has a bad connection. I took the back off and gently poked at the socketed ribbons and sure enough, got the image back. It was mainly the far left ribbon, and it would snap back to stripes if I let off the pressure....
        09-22-2025, 05:10 PM
      • titomno2
        Gaming Laptop Zephyrus S17 TFT not detected every time !
        by titomno2
        Hi guys,
        I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
        So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
        On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
        Then the screen won't work for a long period of time.
        If I wait 1 or 2 hours it work again most of the time.
        When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated...
        01-19-2025, 08:27 AM
      • Foetuss
        Gigabyte GA-6OXT :: caps question
        by Foetuss
        Good evening
        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
        But I was also suprised about the bigger boys, which are 330µF 25V.
        Could it be they used 25V caps because they were cheaper / available at that time?...
        02-11-2025, 12:22 PM
      • flat-earther
        Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
        by flat-earther
        I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
        To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
        I have opened the camera and I think there is enough room to add something inside to accomplish this:
        The camera is powered by a 3.7V nominal single cell lithium ion battery.
        So I need to connect another battery in...
        06-08-2025, 02:00 AM
        DVR recorder Switching power supply Failure
        When I originally started with my DVR recorder it had 4 individual switching switching power supply’s that were sh*t so I bought a 7 amp 12 volt switching power supply and modified the output plug and put a four output power supply cable to match the input power supply cable inputs
        Which worked for over 14 years until a few days ago when the cameras went dark no picture anymore well it turns out now the switching power supply has stopped working altogether now so I have to troubleshoot what has happened to this power supply more later on today what I found
        This...
        05-27-2023, 03:03 AM
