Replacement Caps, Elektrolyt vers Foil
  • arrudi
    • Jun 2010
    • 8
    Hallo,
    is it advisable to replace an Eletroytic Cap with a Foil Cap?
    I am replacesing E-Caps in a switching PS used in a DBVT-Receiver.
    Next to the 10µf 400V Cap is a 2.2 µf 50V E-Cap RM 5mm located.
    Can I exchange this one with a 2.2 uF 50V MK Polyester Foil Cap, or is an E-Cap mandatory?
    The switching device is a 8 pin DIP socket 5H02659R (VE25) device.
    Does anyone know a replacement device? The unit has 10W.
    Thank You very much.
    arrudi
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Replacement Caps, Elektrolyt vers Foil
    Compare Ripple and ESR.
    Mann-Made Global Warming.
    - Dr Seuss
    • Longbow
      • Jun 2011
      • 623
      If possible, could you post a schematic of this unit? Capacitors that we call polyester types use foil and a dialectric rolled up together. These caps are usually found below 1 uF and are used mostly in audio applications due to inductance and dialectric loss at high frequency.
      Multi-layer ceramic capacitors might be a good solution for replacing 1 uF and below.
      Is it plugged in?
      • arrudi
        • Jun 2010
        • 8
        Hallo,
        sorry, I do not have a schematic.
        The IC is a Fairchild KA5H02659RN Power Switch. The capacitor is connected between Pin 2 (GND) and Pin 3 (Vcc). I think, I will stay with an Eletrolytic Capacitor.
        Changing the value from 2.2 uF to 3.3 uF should be ok.
        The old capacitor is a NIC Components NRSA type.
        Thank You for the answer.
        arrudi
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          NIC Components is one of the 'good brands', why are you changing it?
          - Dr Seuss
          • the_rem
            Unknown transformer : how to find a good replacement part ?
            by the_rem
            Hello guys,
            I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
            I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
            04-23-2025, 01:48 AM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • ezenia
            PS4 controller left stick potentiometer replacement issue
            by ezenia
            Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
            So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
            I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
            09-30-2023, 02:19 PM
          • boosti45
            Macbook pro logic board replacement parts quesion
            by boosti45
            i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
            08-21-2024, 05:23 AM
          • r2digital
            klipsch kda-500 amplifier suitable power supply capacitor replacement ?
            by r2digital
            I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
            04-18-2024, 03:50 PM
